Old 11-24-2012, 04:37 AM   #1
daniel_f.
My Ride: 330iC
How to upgrade auto tranny?
hello guys,
iīm curious about all those forced induction guys running auto trannys and sometimes even run shorter diffs.
how to those guys prevent their transmission from going into limp mode at high speeds?
i dynoed my car (2002 330iCA with 3.91 diff) yesterday at 236hp in fourth gear were torque isnīt limited and when measured in fifth gear the transmission ecu lowers the power to 204hp.
thats exactly why the car feels awefull in fifth gear at speeds over 200km/h. It accelerates easily to 200km/h in fourth gear just to flatten out at 220 in fifth gear.
is there some tuner able to unlock this limiter? i really want to get rid of it
Old 11-24-2012, 09:37 AM   #2
BDUB328I
My Ride: bmw 328i S54 sedan (
swap it for a manual? i sold my complete swap for $1000. im sure the guy who bought it was very happy with it
BDUB328I is offline   Reply With Quote
Old 11-24-2012, 10:26 AM   #3
daniel_f.
My Ride: 330iC
Nope, will stick with auto as iīm driving in traffic jam to often.
Old 11-24-2012, 10:37 AM   #4
TrippinBimmer
My Ride: Just Fast!
any tranny mods?
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 11-24-2012, 11:13 AM   #5
daniel_f.
My Ride: 330iC
the tranny itself is stock, overhauled at 99.000km with now 24.000km used. iīm running Z4 Software and the egs was upgraded with the economy mod from eduard aka megawatt. the diff was changed from 3.38 to 3.91 which gives much better response.
just to be precise: i donīt want to go FI, iīm just curious if the FI guys have the same problem like i have right now.
5600rpm in fifth gear, everything is well.
5700rpm in fifth gear and the tranny goes into limp mode.
I just want to get rid of that secondary speed limiter in the tranny ecu
Old 11-24-2012, 11:18 AM   #6
NFSx328ci
My Ride: TiAg E46
Im new to the Force induction myself but I am doing a complete ZHP manual tranny conversion swap, including drive shaft and differential and with UUC lightweight flywheel and clutch setups. I pretty much have everything now. Yesterday was my go crazy and purchase and pick it all up day.
My babies; Supercharged 328ci, 2009 Alpine White 135i.
625awhp 99 GSX(SOLD), Straight Piped 2011 Grand Cherokee (SOLD)
NFSx328ci is offline   Reply With Quote
Old 11-24-2012, 11:28 AM   #7
NFSx328ci
My Ride: TiAg E46
I was having trouble finding everything to upgrade my steptronic so manual was the next best thing.
Old 11-24-2012, 02:01 PM   #8
TrippinBimmer
My Ride: Just Fast!
I have hit 155 on my step with no issues. But that before the eco mod.
Alpine White M3
MaximumPSI Stage4
Old 11-25-2012, 03:13 AM   #9
daniel_f.
My Ride: 330iC
Well, ZHP uses GM tranny, maybe the limits are different to my ZF.
It seems to depend on the rpmīs rather then the speed itself. the car made 240km/h with the long diff, and now it goes 220-225km/h with the short diff, as the tranny ecu lowers the power to around 200hp
Old 11-25-2012, 06:25 AM   #10
TrippinBimmer
My Ride: Just Fast!
I am using a 3.64 diff. hmmm
Alpine White M3
MaximumPSI Stage4
Old 11-25-2012, 08:57 AM   #11
daniel_f.
My Ride: 330iC
well, 155mph is pretty much 250km/h which is reached at 5700rpm. i guess the zhp egs is limited to higher rpms due to the shorter diff.
Old 11-28-2012, 04:03 PM   #12
Jim Murphy
My Ride: 2006 E46 330Ci ZHP
My ZF tranny out of my ZHP is sitting up at IPT getting the complete upgrade overhaul as it started slipping in 2/3 and 3/4 shifts. The OS Giken also set off the codes about "wrong wheel speeds". I should have it back end of next week. We will see.
Jim
My garage tells you what has been done to this ZHP
Jim Murphy is offline   Reply With Quote
Old 11-28-2012, 05:53 PM   #13
BDUB328I
about how much is the cost of having one of these auto tranny's built? and what is included
Old 11-28-2012, 11:48 PM   #14
TrippinBimmer
My Ride: Just Fast!
5 Grand
Alpine White M3
MaximumPSI Stage4
Old 11-29-2012, 05:39 AM   #15
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Jim
Finally! Someone else takes the plunge.
I was getting tired of fielding questions when all I have is a lump in the corner of my shop for 2 years without any use.
Old 11-29-2012, 06:34 AM   #16
soneracar
My Ride: 323IAC Vert
If you can find it at dealer cost it is around 1500-1800 to rebuild. Mine was $1550 on my 323ci.
Sent from my NexusHD2 using Bimmer App
soneracar is offline   Reply With Quote
Old 11-29-2012, 07:25 AM   #17
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
In my case, I needed something to handle more power....a lot more power.
I think the OP's issue is software related.
Old 11-29-2012, 02:12 PM   #18
Jim Murphy
Originally Posted by TrippinBimmer View Post
5 Grand
Yep, the old charge card took a big hit. Back to selling more stuff to pay it off.
Jim
Old 11-29-2012, 02:37 PM   #19
A4RingedONE8T
My Ride: Turbo ///M Roadster
Level 10 can build the auto's for up to 750tq
http://www.levelten.com/SearchResults.asp?Cat=29
-Shawn-
A4RingedONE8T is offline   Reply With Quote
Old 11-29-2012, 02:42 PM   #20
A4RingedONE8T
I am just getting started with a build using a Level 10 tranny, upgraded with every option they have. You can follow the results in the thread here ... http://forum.e46fanatics.com/showthread.php?t=958415
