Auto Trans. Limit - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-10-2006, 04:28 PM   #41
Oshin02
My Ride: turbo E46/M3/MCoupe
Send a message via AIM to Oshin02
Originally Posted by xxe46xx
damn torque sensor someone should do make up a project to figure out how to remove this or mod it
You could easily remove the torque sensor but why would you want to do such an stupied thing like that? Thats there to save your transmision from falling into pieces. ESS Tuning (I think Technik as well) can program your trans. ECU/DME to accept X amount of torque without going into "limp mode". So by removign the torque sensor your really
I am, CARBON MAN.....
Oshin02 is offline   Reply With Quote
Old 03-10-2006, 08:31 PM   #42
malakia12
My Ride: 05 Xterra, 05 Sentra
Send a message via AIM to malakia12
well fellas, I sold my car about 6 months ago, and I just got word from the guy I sold it to that the tranny went on it. I had 325ci step with the following mods: AA supercharger, technik headers, technik cams, RE DMS exhaust. I personally never had trouble with the tranny, not once did it go into limp mode, but I guess over time the tranny was starting to go. So for everyone in a 325, I guess that is pretty much the limit of the trans. I am not sure how much power that car was putting out, but I guess it was close to that 300 limit. just a heads up
Blown by AA :) SOLD!!!!
malakia12 is offline   Reply With Quote
Old 03-11-2006, 10:11 PM   #43
sheltbh
My Ride: 2000 323i sedan
So i was bored as usual and surfing the web and saw that the new GTI has better performance stats on their auto than the manual. Can someone explain this one? I think it was almost .3 seconds difference to 60
sheltbh is offline   Reply With Quote
Old 03-11-2006, 10:31 PM   #44
BimmerDude18
My Ride: 1998 528i
The corvette is faster in auto for striaght line too, at least the C5's were. The reason is that the auto is set up differently than on the BMW's, harder shifts, a different torque converter, and the clutch packs are tightened up more. This means that the tranny shifts faster than a manual and holds the power where the tranny in a BMW is set too smoothly and wastes power after a shift to keep it smooth.
-Tyler
1998 528i 5-speed Work in progress
1988 Toyota Pickup (4WD 5-speed) daily
2007 San Marino Blue 350z 6-speed sold
1996 328i 5-speed sold
www.e46nonM.com - www.precision-sport.com - www.flyingwindowtinters.com - www.techniquetuning.com
BimmerDude18 is offline   Reply With Quote
Old 03-11-2006, 11:41 PM   #45
Shinobi
Addicted to Autocross
Shinobi's Avatar
My Ride: 2001 Jet Black 330Ci
Quick little update here...I have had the S/C on for a few months - 330Ci with ASA S/C @6.5 PSI, steptronic with 330 crank HP. I have only put on about 5,000 miles with it for various reasons (car in shop, I have a 2nd car, short commute to work, etc.), but its still going. I have attended several autoxes now, and have been driving her very hard...redlining the $hit out of it.
I have had 1 tranny problem so far - occassionally when cruising in 5th gear, the tranny will downshift to 4th all of a sudden and I can't upshift until I get off the gas for a moment and then shift back up. I spoke to a BMW mechanic, who gave my tranny error data to BMW's ZF transmission specialist. He said it is not slipping...nothing wrong with the transmission - that he believes its a software issue. Reverse, and 1st through 4th are no problem. This problem hasn't happened since my shop reset the tranny adaptions recently.
I got myself a video camera finally, and I need to get a video capture card so I can post some videos for you guys.
Shinobi is offline   Reply With Quote
Old 03-12-2006, 01:08 AM   #46
Oshin02
There is one way which I figured out how to make my/E46 trans. shift harder. Funny to say but it was mistakinly discovered. I have an Apex'i S-AFC 2 on the car and by having that, I was able to adjust the A/F ratios to my needs (running lean) . Also, to the ones which are unaware. The Auto trans. reads off the MAF to select a specific shift point during WOT or econ. driving. How this was done is by rapidly changing the A/F ratio with the S-AFC during idle and setting it back to stock(I was testing to see if the unit was installed correctly). The gear warning icon appeared along the clusters. The trans. ECU/DME thought something was wrong due to low RPM and rapid A/F ratio changes which set off the trans warning light. By all this, the trans. started shifting extremely hard. Even at low RPM's. Also, during shifts the car would leap forward. I didn't know if this was healty/safe for the trans so I reset the trans ECU/DME. To do this you turn off the car and set the key in the second position and place the shifter in nutral. Roll the car forward and back for about 5-4 ft. each way and the trans. warning light will disappear. A lot of trial and error to figure this out but once again. I don't know if this is safe/health for the car. I will do some more research to find out if this "self mod" is efficient.
Old 03-13-2006, 05:04 PM   #47
xxe46xx
My Ride: '03 CB M3
bump
xxe46xx is offline   Reply With Quote
Old 05-30-2006, 09:21 PM   #48
xxe46xx
My Ride: '03 CB M3
bumpin this **** again
Old 05-30-2006, 09:40 PM   #49
BayerischeMW
Man with No Name
BayerischeMW's Avatar
My Ride: '07 E92 335i
what are you wondering about?
BBS | ACS
"if you wanna be king of the ring, this is the kind of car you should get" -M3 CSL
"there's no replacement for displacement" - only BMW ///M
BayerischeMW is offline   Reply With Quote
Old 05-31-2006, 08:35 AM   #50
HIGH_HEAT
Formerly DINAN_3er
HIGH_HEAT's Avatar
My Ride: Was DINAN_3er NOw SC
Send a message via AIM to HIGH_HEAT
i have a 330ci step with 75,500 on my car .. 36,700 miles with the supercharger. i have dinan tranny software , full Supersprint exhaust and a 6.5 lb asa kit.. i had the tranny go into limp mode 2 times .. but retarted the car and it was all good. the lights went on when i was cursing about 40 mph.
http://www.asasuperchargers.com/forum
Speakeasy Speed Test
HIGH_HEAT is offline   Reply With Quote
Old 05-31-2006, 09:41 AM   #51
faded67
My Ride: 2004 330CI
I have a 2004 330 CI Step running 8 psi on an ASA blower. I have now roughly 2700 miles on the SC with zero issues on the tranny.
BLACK BIMMER
faded67 is offline   Reply With Quote
Old 06-02-2006, 06:07 PM   #52
Mike Benvo
Past Site Sponsor
My Ride: Dinan E60 ///M5
Send a message via AIM to Mike Benvo
That's what happened to my 1990 735i right before the tranny blew. This was with 3rd and 4th gear though since it doesn't have 5th. It's also happening to my friends stock 1995 325is and I can tell the tranny is starting to go, even though there is hardly slippage.
Mike Benvo is offline   Reply With Quote
Old 06-02-2006, 09:13 PM   #53
BmwPerfection
BmwPerfection's Avatar
My Ride: 3.5 M3 & 00 323ci
Send a message via AIM to BmwPerfection
Oshin all you did was put the transmission in 'safe mode' this is what the ecu/dme does to prevent further damage to the transmission. Did you try putting it in sport manual? after 1st or 2nd gear it will shift it self back to automatic and it will remain in 3rd gear which is the mid ratio "safest gear" I wouldn't recommend messing with it, that is why you can buy tuned chips for your tranny so it shifts @ higher rpms...
BmwPerfection is offline   Reply With Quote
Old 06-03-2006, 12:35 AM   #54
Mike Benvo
Past Site Sponsor
What he is describing is not limp mode. The car goes into limp mode (tranny wise) when the explanation point is on the cluster where it indicates the gear selection.
Old 06-03-2006, 01:43 AM   #55
HighBoostin330
My Ride: 2002 Stock 330Ci
When it hits that exclamation point, you better be very careful. If it gets any worse, the car will not unlock the gear unless you restart the car. And if it gets any worse, carry an OBD-II reader because the tranny will throw a SES light that locks the tranny. When you get the random downshifting and locking is when you should be careful. Ask me how I know?
HighBoostin330 is offline   Reply With Quote
Old 12-31-2012, 08:32 PM   #56
jdmad
My Ride: 2005 325xi
Anybody know the limits of an XI with F/I? I figured i'd ask since we seem to be on the general topic.
jdmad is offline   Reply With Quote
Old 01-02-2013, 02:26 PM   #57
Jim Murphy
My Ride: 2006 E46 330Ci ZHP
As you can see in my garage I have reached the limit and now my ZF transmission started slipping in 2/3 and 3/4 shifts thus going into limp mode and turning off the car and restarting it. The answer is to get an upgrade from IPT - you will see several threads here about upgrading and IPT. IPT said to do a complete upgrade of the torque converter, valvebody and transmission drive components (see their website) to withstand what I have in my car. Buckhead Import Performance (does a lot of FI installations) agrees.
Now waiting on back-ordered BMW parts to finish upgrade.
Jim
Jim Murphy is offline   Reply With Quote
Old 01-03-2013, 03:24 AM   #58
daniel_f.
My Ride: 330iC
contact phil, hes at ~320hp right now and the tranny holds fine
http://forum.e46fanatics.com/showthr...762&highlight=
Old 01-12-2013, 01:06 PM   #59
Jim Murphy
Transmission was delivered late Friday afternoon at BIP. I should know more next week.
Old 01-12-2013, 07:18 PM   #60
WALKD U
My Ride: Just Fast!
WOOT!
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
