Thread Tools Search this Thread Rating: Thread Rating: 4 votes, 4.75 average. Display Modes
Old 04-22-2006, 08:44 AM   #1
Surk
My Ride: C Blk E46///M3
DIY->> Diff flange's swap
After doing several friends diff swaps.I decided to get a 3.38 from a 330 auto to replace my 2.93 oem in my 328i.. For diff removal DIY follow Syce46 excellent DIY. In my case, since a 330 has a 6 bolt front flange and longer..it was necessary to swap front flanges.
http://forum.e46fanatics.com/showthr...ghlight=syce46
http://forum.e46fanatics.com/showpos...0&postcount=32
Tools: I am fortunate enough to work at a dealer, but this can be done with these tools:
a) 1 1-1/4" 1/2 drive socket (or 30mm)
b) Flat screw driver
c) Slidehammer
1) After removal, I marked the front nbut and pinion with Red paint to re-align correct position upon re-install and proper torque so that I wouldn't damage crush collar
2) Pry over the lock ring tabs on front flange with a med screwdriver.. remove with needle nose pliers.. I had a airgun avail, so I simply removed the front 30mm pinion nut ( if you don't have avail..loosen this nut while diff is still in car with handbrake on after fr driveshaft removal)
3) Gentle tap with a hammer and woodblock front flange will slide off, also have a rags avail as diff fluid will leak
4) Perform same on new differental as described. retorque front nut to line up with the red marking you make prior to removal.. then install a NEW lock ring and peen the edges over to secure
5) For those who need to swap side output flanges also. 2 methods are avail
a) Use 2 med length prybars covered with rags to not damage side seals.. have someone secure the diff while gently prying outwards..these are simply held in wih internal spring lock clips..
b) Bolt up a small slide hammer with I believe a 10mm bolt.. pull back on the slide hammer and they come out easier..again have rags avail for spillage
Re-assemble and your ready to re-install your new diff ratio back into your car!! *** PLZ make sure you use proper jacks while under car***
ID:	176810   Click image for larger version
ID:	176811   Click image for larger version
ID:	176812   Click image for larger version
Surk is offline   Reply With Quote
Old 04-22-2006, 08:49 AM   #2
Surk
A few more pics
ID:	176815   Click image for larger version
ID:	176816   Click image for larger version
Old 04-24-2006, 12:06 AM   #3
sycE46
My Ride: 323ci
Nice write up!
sycE46 is offline   Reply With Quote
Old 04-24-2006, 10:37 AM   #4
Surk
Good supplement to your diff DIY for those who need to swap flanges
Originally Posted by sycE46
Nice write up!
Old 04-25-2006, 01:50 PM   #5
rx729
My Ride: GSX-R 600
Good write up, very detailed and useful...
rx729 is offline   Reply With Quote
Old 04-25-2006, 03:24 PM   #6
Surk
Forgot to also mention, you can also put a small amt of Loctite Blue on pinion shaft threads during nut re-torque.
Old 04-25-2006, 07:56 PM   #7
shortyz918
My Ride: 328ci
i did all of this and im hearing alittle bit of banging...it happens only once....when i go from forward to revers it will do it, and the same when going from reverse to forward....my tranny is manual...and its not the subframe problem, i checked.
Active 3 Supercharger - Blistein PSS9 Coilovers
Dinan Exhaust - UUC Sways - No CDV, Resonator - 3.15 Rear Diff
shortyz918 is offline   Reply With Quote
Old 04-26-2006, 12:50 PM   #8
Surk
Then you either have to re-check torque on your driveshaft & halfshaft bolts, or front flange needs to be re-torgued more to take up pinion free play.. or if diff is used..has excess play\backlash and requires adjustments.
Old 02-27-2007, 12:42 AM   #9
EIAlfonso
My Ride: 2011 535xi M Sport
I'm thinking about going from the 3.38 that I have now to a 3.15, will I need to do this swap?
I originally had the 2.93
EIAlfonso is offline   Reply With Quote
Old 02-27-2007, 11:18 AM   #10
brosher
My Ride: 04 325XI
Thanks a lot for the info!
brosher is offline   Reply With Quote
Old 02-27-2007, 12:43 PM   #11
Limited_Slip
Banned
My Ride: e30
how long did the DIY take you?
Limited_Slip is offline   Reply With Quote
Old 07-01-2008, 10:11 AM   #12
SeanC
My Ride: 330i
nice info for those who are swapping their diffs nowadays..
Black Sapphire MetallicNatural BrownSilver Cube e46 330i ZHP/6MT - Sold
HellrotDove Grey e36///M3 - RIP
Black Sapphire MetallicNevada BrownDark Bamboo e70 X5 xDrive4.8
Alpine WhiteCoral RedAluminum f30 328i Sportline/6MT
Imola RedBlackBlack Aluminum e46 330i ZHP/6MT
SeanC is offline   Reply With Quote
Old 05-10-2009, 06:21 PM   #13
juvi925
My Ride: AW ZSP 325i
Send a message via AIM to juvi925
thanks for the info this is so useful.
[CENTER]
juvi925 is offline   Reply With Quote
Old 10-15-2014, 09:50 AM   #14
erickrayos
My Ride: 2004 BMW M3
I know this thread is probably burried down already, but I just got a question... to remove those flanges all you need to do is pry them off? any other things should I do before doing so? like i.e. draining the fluid or removing some seals (coz if I remember it right there's a seal in there), need to replace mine coz the bolts sheered off on it coz the previous owner didn't use the right bolts and now parts of the bolts is stuck on the flange.
erickrayos is offline   Reply With Quote
