Thread Tools Search this Thread Rating: Thread Rating: 239 votes, 4.97 average. Display Modes
Old 10-30-2006, 08:41 PM   #41
Permaulj
My Ride: 325CI
Incredible
Nice work. This is gonna help a lot of fanatics out.....
Thanks much, I just asked about codes couple days ago!!!
YUNG1
Permaulj is offline   Reply With Quote
Old 01-22-2007, 03:44 PM   #42
vids_blk323Ci
DFW
My Ride: JB 323Ci SP PP
Send a message via AIM to vids_blk323Ci
P0491 and P0492 >> http://forum.e46fanatics.com/showthread.php?t=433872
Dinan Stage I S/W | ACS RSB | ///M FSB |UUC TMEs & Pulleys |Ate Slotted Discs | ScanGuageII | RockyMounts MTB Carrrier | OEM Rear Clears | LED Euro City Lights & Rear Fogs | Two-Tone Suede DIY | ACS Pedals | Bimmian Gauge Rings & M3 Face | Smoked Frnt Corners w/ Luxeon LEDs | EAS CF Roundels | JLevi Ti CF trim | Blk Suede shift/ e-brake boots | ECS Smoked Frnt Bumper Reflectors | DICE Duo
vids_blk323Ci is offline   Reply With Quote
Old 01-22-2007, 03:58 PM   #43
MarvelPhx
www.my330i.com
My Ride: E92335i,04ZHP,99M3
Send a message via AIM to MarvelPhx
P0491 Secondary Air Injection System Insufficient Flow (Bank 1)
P0492 Secondary Air Injection System Insufficient Flow (Bank 2)
Sounds like the pump failed.
MarvelPhx is offline   Reply With Quote
Old 01-22-2007, 04:00 PM   #44
vids_blk323Ci
DFW
Also some good info at
http://www.troublecodes.net/OBD2/
Old 04-06-2007, 11:34 AM   #45
dambro24
My Ride: 330ci
WHAT DOES PO STAND FOR ? i use carsoft and i get error 106 vanos. there is a code on the list po106 is thi the same thing?
dambro24 is offline   Reply With Quote
Old 04-06-2007, 12:27 PM   #46
MarvelPhx
www.my330i.com
There is no P0106 code for your 323, but there is an internal BMW-FC 106 that returns:
'A' Camshaft Position Actuator Signal Low (Bank 1)
M52: 'B' Camshaft Position Actuator Tight or Jammed
That is probably what CarSoft is referring to.
Old 04-07-2007, 12:10 AM   #47
id11
My Ride: 1999 323i
For quick and easy reference, go to:
http://www.iequus.com/support/obd2_definitions.php
If it's not on there, just call them and ask a tech and they will tell you.
This is the MFG of the code reader that I own.
id11 is offline   Reply With Quote
Old 04-17-2007, 07:41 PM   #48
Elusive
My Ride: '02 325i, '04 ZX-10R
Hey everyone has anyone gotton the code P1351, I know its suppose to be a misfire in C5 but, I reset the code and haven't had it come back up as a "service engine soon". So looking for the positive in everything, what do I need to do to fix the problem when it DOES come back??
Elusive is offline   Reply With Quote
Old 05-18-2007, 11:20 PM   #49
id11
My Ride: 1999 323i
Misfire
I had the same problem about a year ago. It was the spark plug wires in my car.
Old 05-19-2007, 07:35 AM   #50
dambro24
My Ride: 330ci
IT IS B WHAT DOES THIS MEAN , IT ALLWAYS says stiff.
how do i fix it?
Old 06-02-2007, 09:32 AM   #51
DarkRyan323
Banned
My Ride: 2000 323i
Send a message via ICQ to DarkRyan323 Send a message via AIM to DarkRyan323
Anyone know what an E code means?
I got E1510 and P0303 on the autozone scanner. P0303 is cylinder 3 misfire and I don't know what the E code means. I know P1510 is idle speed control valve but I know it said E on the scan tool. Any ideas??
DarkRyan323 is offline   Reply With Quote
Old 06-04-2007, 01:11 AM   #52
DarkRyan323
Banned
My Ride: 2000 323i
^^^nevermind, i re-read the codes today and got P1510...but now i also have P1421 and P1423...bah!!! oh well i still love my bimmer
Old 06-12-2007, 09:08 AM   #53
ghui99ss
My Ride: 2001 bmw 325i
Hey everyone, I just got the p0313 and p1093. I was wondering if anyone else ever had these codes and if its just a simple o2 sensor? Thanks
ghui99ss is offline   Reply With Quote
Old 06-12-2007, 10:52 AM   #54
had a 2002Tii
My Ride: 03 330Ci
This seem to be the place to ask for help. I have the following codes:
P0171 System too Lean (Bank 1)
P0174 System too Lean (Bank 2)
P0313 Misfire Detected With Low Fuel Level
P1083 Fuel Control Mixture Lean (Bank 1 Sensor 1)
P1085 Fuel Control Mixture Lean (Bank 2 Sensor 1)
P1345 Misfire Cylinder 2 With Fuel Cut-off
P1351 Misfire Cylinder 5 With Fuel Cut-off
P1353 Misfire Cylinder 6 With Fuel Cut-off
had a 2002Tii is offline   Reply With Quote
Old 07-01-2007, 08:09 AM   #55
had a 2002Tii
My Ride: 03 330Ci
I guess i should have started my own post about the misfire. However I replaced my fuel filter yesterday and the problem went away. I will give it a few days to see if any codes reappear.
Old 08-22-2007, 07:32 PM   #56
kaotek323i
My Ride: red 1999 323i
damnit i have a grip of codes like fuel trim control lean bank one and two! can any body help with diag procedures?
kaotek323i is offline   Reply With Quote
Old 09-19-2007, 07:14 AM   #57
vids_blk323Ci
DFW
N E 1 know what a code P0000 means???
Old 09-19-2007, 12:22 PM   #58
MarvelPhx
www.my330i.com
P0000 is usually the code that exists when everything works. Kinda like an -All Pass- report.
Old 10-01-2007, 03:56 PM   #59
SmoKeNfLY
My Ride: AW ///M3 & SLK350
I just found out that my car was spitting out the P0070 code, which is an Ambient Air Temperature Sensor Circuit issue. Can anyone tell me what the part number is and where it is located so I can check whether or not I can salvage the existing part? Thanks, and oh pictures of where it is would be a GREAT help.
SmoKeNfLY is offline   Reply With Quote
Old 10-23-2007, 12:27 PM   #60
steveneth
My Ride: 2001 330Ci
I too have the PO313 code. Anyone that has a cure should could help us out here.
steveneth is offline   Reply With Quote
