Thread Tools Search this Thread Rating: Thread Rating: 239 votes, 4.97 average. Display Modes
Old 10-23-2007, 01:30 PM   #61
MarvelPhx
www.my330i.com
My Ride: E92335i,04ZHP,99M3
Send a message via AIM to MarvelPhx
P0313 is Misfire Detection with Low Fuel
MarvelPhx is offline   Reply With Quote
Old 10-23-2007, 05:43 PM   #62
steveneth
My Ride: 2001 330Ci
I know, I'm wondering if anyone knows how to make this code go away. The car has plenty of fuel. I'm wondering if the fuel filter is clogged or if the injectors might be clogged.
steveneth is offline   Reply With Quote
Old 12-29-2007, 02:24 PM   #63
wolfman
My Ride: 2003 325i
P2231 & P2234?
Erm, I'm getting a P2231 O2 Bank 1 Sensor 1 & P2234 O2 Bank 2 Sensor 1
error...
Signal CKT Shorted to Heater CKT
Car's running fine though
Anyone?!
wolfman is offline   Reply With Quote
Old 04-22-2008, 08:21 PM   #64
JapanRed
My Ride: 325CI
My car went into limp mode. I read the error p1633. Throttle Valve Adaptation; Limp Home Position (BMW) anyway to find out why it went into limp mode to begin with. thanks.
JapanRed is offline   Reply With Quote
Old 04-22-2008, 08:27 PM   #65
Autobot325i
My Ride: 2003 325i E46
Send a message via AIM to Autobot325i
P0012 A Camshaft Position - Timing Over-Retarded (Bank 1) is over retarded really a fault
***NEW UPDATE***
1985 318i E30
Autobot325i is offline   Reply With Quote
Old 05-07-2008, 10:22 PM   #66
alexdny
My Ride: 2001 bmw 325I
very nice..........I'm caming from bimmerforum just to get this code list!
alexdny is offline   Reply With Quote
Old 07-01-2008, 01:34 PM   #67
mands9988
My Ride: 318ti Compact
Red face
Is there a way you can locate these codes other than using a diagnostics machine??
any
mands9988 is offline   Reply With Quote
Old 08-18-2008, 11:51 PM   #68
freshprince2421
My Ride: 325ci
interesting...
freshprince2421 is offline   Reply With Quote
Old 09-18-2008, 02:28 PM   #69
dvd64
My Ride: bmw e46 CI
HI
i have this code: P0169
what is it?????????
regards
dvd64 is offline   Reply With Quote
Old 10-21-2008, 09:21 PM   #70
Skoo
My Ride: 325 Ci
I got an unknown code number come up P0316 anyone kno where i can find that description at?
Skoo is offline   Reply With Quote
Old 11-20-2008, 10:01 PM   #71
throttlehead
My Ride: 330i Imola ZHP 6MT
code 2240 330i zhp
my car dropped me a SES. only one code posted as 2240
-O2 sensor positive current circuit/open Bank 2 sensor 1
so with some looking it appears to be the pre-cat O2 getting stupid at only 52K miles.
so the question is: is replacing this sensor the solution? what are the other things that could give the ECU to through this code? intake, coil, injectors?
my symptoms are what feels like misfiring...or stumbling upon accelerartion in 3-6th gears- its a slight stuttering that appears to quiet down or disappear with reduced(minimal) throttle input.
plugs have been replaced
thoughts on solution or problem track down...for this new owner ?>
thanks
throttlehead is offline   Reply With Quote
Old 12-02-2008, 12:53 AM   #72
sakums20
My Ride: 02 330ci
anyone solve this problem yet? and how did u guys solve them?
codes:
p0050 oxygen sensor heater control circuit (bank 2, sensor 1)
p0036 oxygen sensor heater control circuit (bank 1, sensor 2)
p0134 oxygen sensor circuit no activity detected (bank 1, sensor 1)
sakums20 is offline   Reply With Quote
Old 12-13-2008, 09:26 PM   #73
E46 Fan61
My Ride: 2000 BMW 323i
I got a code # P1250 can't find it in here. can some one help me, thanks
E46 Fan61 is offline   Reply With Quote
Old 12-15-2008, 10:35 AM   #74
dvd64
My Ride: bmw e46 CI
Originally Posted by dvd64 View Post
HI
what is it?????????
regards
i search and i found it with this error code:
169 CODE THROTLE VALVE SWICH OFF
169 (Idle Air Control Closing Coil
Old 07-09-2009, 01:13 PM   #75
BrianLeveille
My Ride: 325xi
I just got a P1011 read from AutoZone.
Anyone know what that means? I can't find it anywhere in the interwebs...
-BL
BrianLeveille is offline   Reply With Quote
Old 07-11-2009, 07:49 PM   #76
zake92
My Ride: BMW 325i
same problem
I know is old post but I have same problem. What did you have to do to fix it? Thank you,
error...
Anyone?!
zake92 is offline   Reply With Quote
Old 10-28-2009, 07:15 PM   #77
XtraVert
My Ride: 330ci Convertible
This is a great aid. What would be reeeeeeeeeeeeally good would be to have listed against each code the probable causes as a % of probabilty. Bit of an ask I know, but maybe someone has this information?
XtraVert is offline   Reply With Quote
Old 12-10-2009, 04:42 PM   #78
s_vang18
My Ride: 99 323i
i need some help...i got a bunch of codes...and i seen what it was ...but what do i need to fix??...can i get some help....??...the codes are P1250...0300,0301,0303,0304 and 0441......what does it mean....and how can it be fixed??..IN NEED OF HELP..............
s_vang18 is offline   Reply With Quote
Old 12-31-2009, 06:22 PM   #79
mrkedmnd
My Ride: "03 325i- 19" ST160
a must keep. thanks
mrkedmnd is offline   Reply With Quote
Old 02-10-2010, 06:47 PM   #80
tapatio
My Ride: bmw 323i 1999
P0169
hello, i have a 1999 323i and i have the code p0169 thats anybody knows whats that means and how can i fix it? thanks
tapatio is offline   Reply With Quote
