Thread Tools Search this Thread Rating: Thread Rating: 239 votes, 4.97 average. Display Modes
Old 03-09-2013, 02:41 PM   #101
joshevans2008
My Ride: 01 330CI Convertible
I dont have my charts in front of me but it sounds like a evap problem.. sounds like a hole in the hose.. thats what my problem was I went through the same scenario as u did last month.. it was inspeftion time and a pain in my ____ lol a new hose fixed it and now I have a trans idle problem
joshevans2008 is offline   Reply With Quote
Old 03-09-2013, 04:09 PM   #102
tkxallday
My Ride: BMW 330ci
^ where was the hose located?
tkxallday is offline   Reply With Quote
Old 04-24-2013, 06:55 PM   #103
Rotten Robbie
My Ride: 01 325i
code P0414
After putting my car back together since replacing the head gasket I'm getting code P0414 "Secondary Air Injection System Switching Valve A Circuit Shorted" -anyone know what the secondary air injection valve is, or where it is(?) I'm hoping I just got something plugged in wrong, but my car runs fine...
Rotten Robbie is offline   Reply With Quote
Old 05-29-2013, 10:39 AM   #104
psk
My Ride: 2003 BMW 325sulev
Great App and a vast wealth of relevant knowledge
2003 bmw 325i SULEV... Anybody have a guesstimate on how much brake pads+rotors would be for the rear set of wheels?
psk is offline   Reply With Quote
Old 06-20-2013, 06:47 PM   #105
Drako06
My Ride: 330i
Awesome!!!
Drako06 is offline   Reply With Quote
Old 06-21-2013, 02:05 PM   #106
Rotten Robbie
My Ride: 01 325i
I bougtht 4 loaded calipers, and paid around $100/ea. at a local parts store, and they turned my rotors for free.
-I think I like Pellican Parts. They were the best price on a real Bosch fan when I needed one.
Old 01-01-2014, 05:49 AM   #107
Nedroo
My Ride: bmw e46 325i 2005
hi, my e46 325i 2005 is drivimg me crazy,i started it today and the engine start to shake and run hardly and the check engine lamp is on, i step little on gas it is not functioning normaly its making sound like " tefffftefffteffff" waited it to get warm and turn it off and on again, check engine lamp is gone and the engine is runing normaly.any body has answeres?i have changed plugs amd coils a week ago due to same reason but that didint help.please help me and im waiting ur reply thankfully
Nedroo is offline   Reply With Quote
Old 01-03-2014, 07:51 PM   #108
Rotten Robbie
My Ride: 01 325i
Hmmm, I had the exact same problem on my 01. I think it was a gummed up (varnished) fuel injector... I poured in a can of SeaFoam, filled up with gas and drove, and the problem hasn't occurred again.
Old 03-14-2014, 08:03 AM   #109
martincrams
My Ride: BMW SUV 2010
That you for the fault list guys
Need for Speed
martincrams is offline   Reply With Quote
Old 03-19-2014, 11:05 PM   #110
Matt.Marson
My Ride: 2002 BMW 325it
Anybody know what needs to be replaced to clear "P0056 HO2S Heater Circuit Bank 2 Sensor 2" from the scan
Matt.Marson is offline   Reply With Quote
Old 08-12-2014, 06:07 AM   #111
mickegun800
My Ride: BMW 325Xi Touring
Smile I'll get the same codes as you on my 325Xi
Dit you get you car running again withouts the codes comming up? Replaced some parts? if you did...what parts?
Originally Posted by had a 2002Tii View Post
This seem to be the place to ask for help. I have the following codes:
P0171 System too Lean (Bank 1)
P0174 System too Lean (Bank 2)
P0313 Misfire Detected With Low Fuel Level
P1083 Fuel Control Mixture Lean (Bank 1 Sensor 1)
P1085 Fuel Control Mixture Lean (Bank 2 Sensor 1)
P1345 Misfire Cylinder 2 With Fuel Cut-off
P1351 Misfire Cylinder 5 With Fuel Cut-off
P1353 Misfire Cylinder 6 With Fuel Cut-off
mickegun800 is offline   Reply With Quote
Old 08-22-2014, 06:28 PM   #112
beemernee
My Ride: 320d touring
Top man Warren , quality stuff here time consuming too , thanks , Nee .
beemernee is offline   Reply With Quote
Old 10-15-2014, 10:50 AM   #113
Jib01
My Ride: 2003 M3 Convertible
Thumbs Up Better OBD-II code descriptions
Here is a very good reference with a more in depth description of what the problem might be....
http://www.obd-codes.com/trouble_codes/
http://www.obd-codes.com/P0012
Put the number of the code after the URL for a more detailed description of the problem and fix.
Jib01 is offline   Reply With Quote
