Old 10-20-2005, 08:45 AM   #1
tblue3cibm
My Ride: allroad / Hayabusa
Quick question about the radiator bleed screw
Is it supposed to be tightened during normal vehicle operation?
tblue3cibm is offline   Reply With Quote
Old 10-20-2005, 09:05 AM   #2
Ivegotissues666
My Ride: 88' BMW E30 SETA
Send a message via AIM to Ivegotissues666
Yes! Why wouldnt it be? You wouldn't want coolant leaking out would you?
Ivegotissues666 is offline   Reply With Quote
Old 10-20-2005, 09:10 AM   #3
tblue3cibm
True; It just seems to build up so much pressure, how often shouls I bleed?
Old 10-20-2005, 10:15 AM   #4
nEVERCLEAR
My Ride: 323
It is there to bleed the system when you change the fluid or open the sytem. It is a pressurized system, unless you are overheating due to air pockets in the system I see no reason to routinely bleed the system. My plastic screw broke and no one had touched it for 10K miles.
If you do tighten it make sure it is just enough to stop it from leaking they can break.
Thinking about a Honda or VW Dont buy from East Coast Honda - VW Read about my experience here
Some people dream of speed-others create a damn jet powered shopping cart.
Curious about VoIP and Vonage click here
nEVERCLEAR is offline   Reply With Quote
Old 10-20-2005, 02:42 PM   #5
greenohawk69
My Ride: SCHWINN
Yes, be careful when tightening.....they do break.
greenohawk69 is offline   Reply With Quote
Old 10-20-2005, 07:42 PM   #6
tblue3cibm
How do I know if I have air pockets in my cooling system; also how do I get rid of them?
Old 10-20-2005, 09:46 PM   #7
nEVERCLEAR
My Ride: 323
If you changed your coolant or waterpump/ thermostat you would have air pockets. If your car is not overheating I would not worry about it.
With the car running you crack the bleeder screw just a little till either pressurized air/ steam or coolant comes out. If air comes out keep it cracked till coolant(Liquid) comes out and you are set.
When you change the coolant you open the bleeder screw and fill till coolant comes out then you close the screw.
It is not really a maintenance issue more or a necessity to make the system work properly if you open it up (Drain it)
If your car has been serviced and it overheats immediately (less then approx. 5 minutes at idle) the system has air pockets and needs to be bleed.
This information is accurate from knowledge gained servicing my car, it may not work for you or be the "Correct diagnosis or procedure" but it worked for me
Old 10-20-2005, 09:48 PM   #8
tblue3cibm
Thanks buddy
Old 10-21-2005, 07:56 AM   #9
tblue3cibm
I think it was air pockets, car began overheating after being driven hard.
Old 10-21-2005, 11:21 PM   #10
Commander FAT
Network Analyst
My Ride: 2002 330Ci
Only bleed after doing a coolant flush.
The filler neck cap will relieve excess pressure. I found that out after an autocross run. I had the needle pegged way high in first gear for nearly the whole run. A minute afterwards coolant was pouring out from underneath the cap.
Because the B isn't for bling.
Commander FAT is offline   Reply With Quote
