Old 10-21-2005, 12:37 PM   #1
GatorManJoe
My Ride: 1999 328i Sp/Pr 5sp
Headlight Power Chain Possible?
Hey guys, a few days ago my right HID headlight (Proxenon 9000 series) went out and when I went to my shop to get it fixed, they said the power to the right headlight was dead and there was a short causing it. The guy at teh BMW dealership who didnt seem to know much suggested daisy chaining the power from the one still working headlight over to the dead one. The shop refused to do this so they wouldnt be liable. Anyone have any comments on this idea? Am I going to short out the ECU or anything? Any help would be much appreciated.
-Joe
GatorManJoe is offline   Reply With Quote
Old 10-21-2005, 01:44 PM   #2
Canuck328i
My Ride: 09 Altima Cpe
Each light in an E46 receives its own individual power from the LCU which are all switched by transistors, so I would be concerned about overloading that branches transistor and causing more damage. Did it blow a fuse? If the failed circuit is truly shorted out you'd think it would, and take the other headlight with it. Plus in the end you'll have the headlight-out lights on all the time due to the unbalanced load.
You'd be better off getting that wire and/or circuit fixed properly. It is the smarter and safer way to do it. And good tech should be able to figure that out.
Mark
Canuck328i is offline   Reply With Quote
Old 10-24-2005, 11:18 PM   #3
nEVERCLEAR
My Ride: 323
Did you do anything recently that would pinch a wire?
Try tracking the problem yourself, with a volt meter is there continuity between the wire and a grounded source.
If all else fails you could use a relay and the other headlight as the trigger.
Thinking about a Honda or VW Dont buy from East Coast Honda - VW Read about my experience here
Some people dream of speed-others create a damn jet powered shopping cart.
Curious about VoIP and Vonage click here
nEVERCLEAR is offline   Reply With Quote
