Sponsored by BAVSOUND
Old 09-22-2002, 08:21 PM   #1
NiTE
My Ride: M3
Installing Aftermarket Head Unit
What are the exact parts that I need to install an aftermarket head unit into my 328i? The unit is an Alpine 7894, this should be an easy DIY, right? If I need certain OEM parts could someone please post the part numbers for them. Thanks in advance.
-Sid
'99 Cosmos E36 M3
'02 TitanSilver E46 325xi
NiTE is offline   Reply With Quote
Old 09-23-2002, 12:41 PM   #2
Delirium
yo mama
My Ride: -
I think this is what you need:
Face plate adaptor
Wiring harness
antenna adaptor
The think i dont get is that if your speakers are already amplified by the factory amp how do you hook up the head unit to the wiring harness? Wont the speakers be double amplified because the Head unit also has an amp? Which amp will you be using when you do this?
Delirium is offline   Reply With Quote
Old 09-23-2002, 02:00 PM   #3
NiTE
My Ride: M3
im pretty sure the audio will not be amplified by the head unit, it will just pass through to the amp that is already in the car.
-Sid
'99 Cosmos E36 M3
Old 09-23-2002, 03:04 PM   #4
Derek330xi
My Ride: E46 330xi
Send a message via ICQ to Derek330xi
anyone have a site that show the DIY for headunit? i am planning to install a panasonic mp3 headunit but don't know how
Derek330xi is offline   Reply With Quote
Old 09-25-2002, 05:16 PM   #5
ZzyZx
My Ride: 04 Silver Gray 325Ci
I have this setup in my car now. PM me if you have any questons or need any help.
ZzyZx is offline   Reply With Quote
Old 10-21-2002, 03:18 PM   #6
LfeStylez
My Ride: '99 323i
hey derek, did you ever find a d.i.y. site on how to install the alpine head unit? i wanna do the same set up, but don't know much about the wiring...do you have HK system? if so, do you know if there's any different special wiring?
LfeStylez is offline   Reply With Quote
Old 10-22-2002, 10:15 AM   #7
guest1016
fanatical
My Ride: .
Send a message via AIM to guest1016
when you hook up the output of your alpine to the wiring harness it goes directly into the amplifier, not the speakers. this is known as a high level input. Amps either take a hi-level (speaker level) or low-level (rca's)input Therefore your speakers will still be using the factory amp for power & crossover duties. There is nothing that will be doubly amplified. the Factory amps use high level input, VS. most aftermarket amps have input's for both. You have nothing to worry about just wire the plug up correctly and plug it in...
guest1016 is offline   Reply With Quote
