Old 10-27-2005, 12:01 AM   #21
xmltok
UCLA
My Ride: Boosted 330Ci
Send a message via AIM to xmltok
dont take those 3 hex screws in the photo out though
xmltok is offline   Reply With Quote
Old 10-27-2005, 12:36 AM   #22
ChrisMT79
Here
ChrisMT79's Avatar
My Ride: Audi R8/BMW X6
No Im not going to take them out. But are those the ones that tighten the window?
ChrisMT79 is offline   Reply With Quote
Old 10-27-2005, 01:25 AM   #23
xmltok
UCLA
nope, those run perpendicular to the ones you want to tighten
take off the door panel and peel back the side of the foam near those bolts and you will find a hole that you will move the window up/down to align the bolt to
Old 10-27-2005, 05:07 PM   #24
///Mechanic
My Ride: None currently
DO NOT TAKE THE DOOR PANEL OFF TO TIGHTEN/ADJUST THESE BOLTS!!!
It is the exterior trim that runs horizontal........geez.....
Open your door, and grab hold of the end of this molding closest to your door handle. Gently pull away from the door to pop the first clip out. Using your finger on one hand, slide it between the molding and the door to seperate the two pieces.......keep doing this until you have completely popped all of the clips (there are like 5 in all). You will see the holes in the door now, follow my steps above to adjust.
YOU BOUGHT A BMW, IF YOU CANT AFFORD TO MAINTAIN IT............SELL IT.
///Mechanic is offline   Reply With Quote
Old 10-27-2005, 05:46 PM   #25
xmltok
UCLA
thats all you had to say
Old 10-30-2005, 09:58 PM   #26
ChrisMT79
Here
ChrisMT79's Avatar
OHHH.. lol.. duh..
