Old 10-23-2005, 03:33 PM   #1
MITE46
My Ride: 323i
Euro Bluetooth Module Installed on 04 M3cic...
I've always wanted to do the bluetooth module, but wanted to wait until bluetooth matured a bit more...and I guess that time came yesterday...
I've heard a lot about BMW's bluetooth module and finally decided to try it out on the 04 M3 convertible w/ Assist...BMW says bluetooth doesn't work in conjunction with Assist...which is true for 04's...but who really wants assist anyways? BMW also says bluetooth doesn't work with convertibles...but what's the sense in that? Why Euro? I've heard a lot about incompatible phones...but i've also heard that the Euro module is supposed to work with a lot more phones...I've compared both modules...both made in spain by the same company...We've got 4 BT phones...so we'll see =)
Anyway here's my install...remember its very specific to convertibles and assist pre installed....that means the mic is prewired and also the car is coded for telephone already...
You'll need the bluetooth install kit...actually you only need the BT antenna, the pairing button, and the pairing button adapter...
And of course...the Euro BT Module...
MITE46 is offline   Reply With Quote
Old 10-23-2005, 03:33 PM   #2
MITE46
My Ride: 323i
I realized that working on a convertible is so nice...don't have to worry about hitting your head on the roof...
Remove the center piece...
I didn't even know there was a compartment back here...
Pull up and remove the seats...
Remove the two hex nuts that hold down the back rests...
Push the tabs and lift up the head rests...
Pull out the seatbelts...
Push up on the backrests and pull them out...
Remove the driver side panel with 13mm
This is the suggested location for the BT module...but mine didn't really fit here well...
Old 10-23-2005, 03:33 PM   #3
MITE46
My Ride: 323i
Look behind the side panel...there are supposed to be a few wires...I think these are for a signal booster...you won't need these...
You are looking for the white with purple clip which is the BT antenna line that routes to the rear ash tray in the center...
I couldn't find where the assist module so I took apart a lot of stuff...
My next guess was the trunk area...
I've taken apart the trunk just about a million times so it was cake this time around...
Still no assist module...back to the side panel idea...If my mom comes home and sees her car like this...she's gonna kill me =p
Arg...still no assist module...but here's the the vert control module...and also the AMP for the speaker system...learn something new everyday I guess...=)
Old 10-23-2005, 03:34 PM   #4
MITE46
My Ride: 323i
I heard it might be behind the NAV DVD drive...no such luck...
Everything on the convertible is much more crowded...things like radio antenna are all crammed into the rear fenders...but finally...removing the rest of the carpet...the assist module was behind the driver side rear seat...
All I had to do is fish the BT antenna from inside to the trunk area and piggy back the BT module to the assist module...the assist antenna is not used...
Okay the hard part is over now to install the BT antenna...
Old 10-23-2005, 03:34 PM   #5
MITE46
My Ride: 323i
BT antenna...
Pairing button...I decided not to go for a cradle because we have so many different types of phones...plus the cradle only charges the phone and boosts cellphone antenna...its not really worth the extra $100...plus you loose can holders...definately not worth it...
Button adapter...
Pairing Button...
Old 10-23-2005, 03:35 PM   #6
MITE46
My Ride: 323i
Attached...
The instructions insist that you dremel a square to fit the button...there's no way i would ever do that...I came up with this solution instead...you only use the pairing button when you pair a phone...
The coin holder is spring loaded so it doesn't affect the arm rest from closing all the way...
Now to see if it all works...push and hold down the pairing button and turn on the car...
Yay it works...Blackberry pairs perfectly...
The sound is crystal clear and I am quite impressed with the integration...it has last dialed and most frequent numbers dialed...You can also use the nav to initiate the call...now I just have to wait until the others come home with their BT phones...
Anyone have a phone that they know that doesn't work with the US BMW module?
Old 10-23-2005, 03:41 PM   #7
Bimmer-freak19
My Ride: Bmw 525i exe 04'
looks verry good!
Bimmer-freak19 is offline   Reply With Quote
Old 10-23-2005, 03:45 PM   #8
rusty0099
My Ride: Steel Grey M3
Man big props to you for your awesome works! How is your 323 M3 doing?
What kind of phone do you have? I just got a Samsung D500 and not sure if the phone will work with BMW bluetooth
rusty0099 is offline   Reply With Quote
Old 10-23-2005, 03:55 PM   #9
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Old 10-23-2005, 04:01 PM   #10
Prelude528
My Ride: my bicycle
Nice
///M - Eric
Prelude528 is offline   Reply With Quote
Old 10-23-2005, 04:04 PM   #11
simsima325
'a certain moderator'
simsima325's Avatar
My Ride: Honda Civic
wow, its LIKE an update, but different!
how much for the whole job? getting a bluetooth phone soon
-Brendan
Old 10-23-2005, 05:09 PM   #12
MITE46
My Ride: 323i
i spent about $400...im not sure how much list is...I don't have a D500...we have a blackberry, v710, razr, and some sony ericson phone...
Old 10-23-2005, 06:45 PM   #13
peppernick
My Ride: MB CLK350
Get the specific phone holder/charger as well. My old SIEMENS S55.
peppernick is offline   Reply With Quote
Old 10-23-2005, 06:59 PM   #14
sheefo2k
sheefo2k's Avatar
My Ride: vrm psh - 02 325ci
i installed one of these like a year and a half ago in my buddy's 330i and the isntructions suck
Performance BMW car
Sponsored by :
www.euro-spec.net
www.bimmian.com
BMW Motorwerks
support:
www.vmwerks.com
www.esstuning.com
www.my330i.com
sheefo2k is offline   Reply With Quote
Old 10-23-2005, 07:10 PM   #15
ILLCOMM
like ma bell, i got the...
My Ride: 911 GT2
I have to say, that's pretty hot.
ILLCOMM is offline   Reply With Quote
Old 10-23-2005, 07:38 PM   #16
rusty0099
is the pairing button a part of the holder? Damn, it's pretty cool. but I have to lose cup holders I can't manage to live without them.
Old 10-23-2005, 07:38 PM   #17
Choson1
Owner
My Ride: Keepin' it Real
Choson1 is offline   Reply With Quote
Old 10-23-2005, 07:40 PM   #18
nojoda
My Ride: 06 M3Vert 6MT JB/CIN
you are the master of DIY
2006 BMW M3 VERT 6MT S/C VF570 (CURRENT)
2007 B7 AUDI A4 2.0T CVT FWD (BRILLIANT BLACK) TRADED
2002 E46 BMW M3 SMG II (TIAG) RIP
INSTAGRAM : @itsjorgebrah
nojoda is offline   Reply With Quote
Old 10-23-2005, 08:41 PM   #19
edrock200
My Ride: M3
Send a message via AIM to edrock200
Thats pretty slick man. I have an after market voice activated BT kit in my '04 M3. It came with the car. Is the OEM BT kit voice activated and controlled? Can you go over some highlights of how it works if you don't mind?
edrock200 is offline   Reply With Quote
Old 10-23-2005, 09:04 PM   #20
djray
djray's Avatar
My Ride: 01 BMW325CI
Where can I buy that and how much for everything?
djray is offline   Reply With Quote
