Old 11-01-2005, 08:39 AM   #1
ylwmonkee13
My Ride: 2003 E46 M3
can i tap the power from the front?
i am installing a valentine1 near the rear view mirror. Could i just tap the power wire to the lights in the upper middle console by the sunroof switch?
What would be the pros and cons of this?
ylwmonkee13 is offline   Reply With Quote
Old 11-03-2005, 03:15 PM   #2
jason 77
My Ride: 2007 E92 335i AT
I would think you would risk overloading the circuit for the lights? I don't know how much power the V1 draws?
jason 77 is offline   Reply With Quote
Old 11-10-2005, 11:29 PM   #3
drummersam65
My Ride: 323i
http://m3.madrussian.net/diy_valentine_v1.shtml
i followed this diy, i think you tap into the homelink wire.
drummersam65 is offline   Reply With Quote
Old 11-14-2005, 08:56 AM   #4
ca1242
My Ride: 2003 330i
V1 drwas very little power, so it would be fine if tapped to the lights circuit. I would recommend tapping into the homelink harness though, that way the V1 will be switched on/off with the key.
Old 11-14-2005, 11:38 AM   #5
ylwmonkee13
Thanks for all the help! i follow the instruction at the madrussian site and after reviewing it, it only took me about 7 minutes to complete the install!
Awesome trick! thanks for all the help!
