Old 11-08-2005, 04:24 AM   #1
Mike@Modbargains
ModBargains CEO
Mike@Modbargains's Avatar
My Ride: 2008 BMW 135i
ModBargains | BRAKE UPGRADES - We have everything! Pads, Rotors, SS lines, Fluid, BBK
Hey everyone,
This thread will feature some of the great products that we offer you to help upgrade the brakes on your E46 3 series or E46 M3. As always, you can count on dedicated customer service for all of your purchases from ModBargains. We have other braking products available, but these are the ones that I wanted to feature here. There are too many options on the Big Brake kits, so if you want a BBK please e-mail me for pricing. If you have any questions about these products please feel free to ask your question by posting in this thread. Thanks!
CLICK HERE TO VIEW ALL BRAKE PRODUCTS
Brake Pads:
Axxis Deluxe Plus Brake Pads: These organic brake pads are specially manufacturerd to produce little to no brake dust, while at the same time NOT sacrificing the ultimate braking performance of your BMW. If you're sick of washing the brake dust off of your wheels all the time, this is the product for you. Benefits: LOW brake dust, Very quiet, no squealing, Work up to temperatures of 716 degrees, Stopping power comparable to OEM pads, Affordable Pricing Starting at $28.95 per pair Click here for more info and prices, and easy ordering.
Axxis Ultimate Brake Pads: The AXXIS Ultimate is the newest high performance street pad to be introduced into the North American market from Bendix Mintex in Australia. Building on years of success with their world class Metal Master pads, Bendix Mintex formulated the Ultimate pad compound to compete with the best performance street pads in the world. The AXXIS Ultimate pads feature a special Kevlar® and ceramic strengthened formula with a high co-efficient of friction and very high temperature fade resistance. As with all AXXIS pads, the Ultimate pad is a non-asbestos formula. Designed for extreme high performance street driving and hard braking applications, Ultimate pad users will benefit with extreme stopping power and high resistance to brake fade at high temperatures. Consistent throughout it’s operating temperature range, you’ll get dependable, predictable stops time after time.Pricing Starting at $44.95 per pair Click here for more info and prices, with easy ordering.
Axxis XBG (Metal Master) Street Performance Brake Pads : The Metal Master is a semi-metallic pad that exhibits perhaps the most balanced operating characteristics of all three Axxis pads. With performance characteristics, dust levels, and noise levels in between the other two Axxis pads, the Metal Master can be thought of as a happy compromise between the squeaky clean Deluxe Plus and the all out performance of the Ultimate. It also provides low rotor wear and good pad longevity. Street only. NOT for track use. Axxis Metal Master brake pads use a semi-metallic formula that reduces brake dust, fade and squeal. They provide excellent stopping power under all conditions. Metal Master pads work at temperatures up to 752°F. Pricing Starting at $36.95 per pair Click here for more info and prices, with easy ordering.
Brake Rotors:
Stoptech SportsStop Cross-Drilled Direct Replacement Rotors : SportStop direct replacement rotors fit stock calipers. Drilling or slotting helps wipe away the debris that forms between the pad and the disc, adds more bite, and can help the rear brakes to match the aesthetics of a front Big Brake Kit. The rotor finish helps prevent glazing of the pads, and improves wet and dry braking performance. StopTech rotors have a durable black coating on the non-swept areas of the rotor to prevent unsightly corrosion. These direct replacement rotors are not StopTech AeroRotors. The internal vane structure is identical to stock rotors, but they are available slotted or drilled. Pricing Starting at $95.00 per rotor Click here for more info and prices, with easy ordering.
Stoptech SportsStop Slotted Direct Replacement Rotors : SportStop direct replacement rotors fit stock calipers. Drilling or slotting helps wipe away the debris that forms between the pad and the disc, adds more bite, and can help the rear brakes to match the aesthetics of a front Big Brake Kit. The rotor finish helps prevent glazing of the pads, and improves wet and dry braking performance. StopTech rotors have a durable black coating on the non-swept areas of the rotor to prevent unsightly corrosion. These direct replacement rotors are not StopTech AeroRotors. The internal vane structure is identical to stock rotors, but they are available slotted or drilled.
Stainless Steel Brake Lines:
Stoptech Stainless Steel Brake Lines for BMW E46 3 Series and E46 M3: StopTech Stainless Steel Brake Lines provide a quicker pedal response, maintaining consistent brake pressure and precision brake modulation, especially during threshold braking. All StopTech Stainless Steel Brake Lines are manufactured to meet DOT Compliance Standards, and every line is 100% tested in-house to a pressure of 4500 psi. StopTech brake lines consist of a Teflon® inner line, which is then covered with a layer of stainless steel woven braid. The Teflon tube is very resistant to expansion under pressure and will not degrade from exposure to brake fluid. The stainless steel braid provides support for the Teflon and the weave is extremely durable against incidental impact and abrasion. Finally, StopTech brake lines are coated with a Clear Abrasion Resistant Cover for maximum protection against chaffing. All necessary brackets and fasteners are included with each line kit. Adding a set of StopTech Stainless Steel Brake Lines to your performance vehicle will provide an immediate improvement to brake performance and pedal feel from the very first stop. Pricing Starting at $59.99Click here for more info and prices, with easy ordering.
continued in next post....
Authorized Dealer of: Forgestar Wheels l KW Suspension l VMR Wheels l Miro Wheels
Hours: Monday - Friday 8am - 7pm, Saturday 8am - 5pm (PST)
We Specialize In: BMW Parts | BMW Rims | BMW Wheels | BMW Exhaust
Mike@Modbargains is offline   Reply With Quote
Old 11-08-2005, 04:24 AM   #2
Mike@Modbargains
ModBargains CEO
Stage Upgrade Kits:
Stoptech Stage 1 Brake Upgrade Kit: Perfect for the value minded enthusiast, StopTech Stage 1 kits are a great first step towards taking your car's braking performance to the next level. Front and rear stainless steel brake lines improve pedal feel and reduce the amount of time between applied pedal pressure and actual deceleration by preventing expansion of stock rubber flex lines. Axxis Ultimate front and rear brake pads provide you with higher resistance to fade, higher maximum operating temperature, and better initial bite to allow consistent deep braking into corners. To top off the package, we include three bottles of Motul RBF600 brake fluid to increase both wet and dry boiling points and prevent boiling even under the most severe operating conditions.
Pricing Starting at $269.00Click here for more info and prices, with easy ordering.
Stoptech Stage 2 Brake Upgrade Kit: An excellent choice for the enthusiast whose rotors are nearing the end of their service life, the StopTech Stage 2 kit includes all the components and benefits provided by the Stage 1 kit, but adds value through the addition of direct replacement drilled or slotted rotors at all four corners. For customers interested in attaining an aesthetic edge, we offer cross-drilled rotors that look phenomenal behind that new set of custom wheels as well as preventing glazing of the pads and improving wet and dry braking performance. Alternatively, for the more performance minded enthusiast we recommend slotted rotors that still retain an eye-catching look and provide all the performance gains of a drilled rotor, but are less likely to crack under repeated, severe usage. Regardless of drilling or slotting, all StopTech rotors have a durable black coating on the non-swept areas of the rotor to prevent unsightly corrosion, and quality is assured as the rotors are manufactured to meet or exceed all OE specifications. Pricing Starting at $599.00Click here for more info and prices, with easy ordering.
Brake Fluid:
Ate Super Blue Racing Brake Fluid: Ate Super Blue Racing Brake Fluid is a newly developed DOT 4 premium non-synthetic brake fluid with a wet boiling point of 400 degrees fahrenheit and a dry boiling point of 536 degrees fahrenheit (a full 20 degrees higher than regular DOT 5 synthetic). The high wet boiling point temperature prevents formation of vapor bubbles resulting from retardation of the drop in the wet boiling point. The Ate “Super Blue” allows up to 3 years of safe operation before changing.
Tip:
Use in conjunction Ate TYP 200.
Both products have the same characteristics, but have a different tint. Ate TYP 200 is gold in color while Ate Super Blue is, well Blue! Alternating between these two fluids will assist in identifying when your brake system has been completely flushed of old fluid.
Note:
Most driving schools recommend you flush your system at least once a year, preferably more frequent if your car has heavy track usage.
Price: $9.95 per bottleClick here for more info and prices, with easy ordering.
Ate TYP 200 Brake Fluid: Ate TYP 200 is suitable for extreme demands of racing and the weekend track car.
The original TYP 200 Ate brake fluid is a high-performance brake fluid with a dry boiling point of 280 °C/536 °F and a wet boiling point of 200 °C/392 °F. This top-of-the-range product lies 20 °C over the DOT 5.1 standard and surpasses this standard in nearly all the other requirements as well. This means that cars can go without a brake fluid change for up to 3 years while products with a lower wet boiling point have to be replaced considerably more often (e.g. DOT 3 products should be replaced annually).
Tip:
Use in conjunction Ate Super Blue.
Both products have the same characteristics, but have a different tint.Ate TYP 200 is gold in color while Ate Super Blue is, well Blue! Alternating between these two fluids will assist in identifying when your brake system has been completely flushed of old fluid.
Note:
Old 11-09-2005, 01:51 AM   #3
Mike@Modbargains
ModBargains CEO
Thanks for the interest guys, e-mails replied!
Old 11-09-2005, 07:57 AM   #4
dogtorj
My Ride: About 23 minutes
Email sent. Gonna do the Stage 2 with cross-drilled rotors. Just gotta decide which pads to get.
J.
dogtorj is offline   Reply With Quote
Old 11-09-2005, 08:50 AM   #5
russ330
Mod Squad
russ330's Avatar
My Ride: Motorsport III
Send a message via AIM to russ330
Do you or anyone know if the holes are drilled or cast into the rotors?
russ330 is offline   Reply With Quote
Old 11-09-2005, 11:25 AM   #6
Will ZCPM3
Will ZCPM3's Avatar
My Ride: ///M3
could i get pricing on stoptech 332x32mm front only bbk w/ slotted rotors?
Will ZCPM3 is offline   Reply With Quote
Old 11-09-2005, 11:54 AM   #7
GlockMan
GlockMan's Avatar
My Ride: Suburban LT 4x4
Originally Posted by Mike@Modbargains
Hey everyone,
Brake Pads:
Brake Rotors:
I emailed you on the 7th and have not seen a reply. I am interested in high end silver colored cross drilled rotors for my 330ci with stock calipers for both the front and back.
!!! ROLL TIDE ROLL !!!
National Champs: 1925, 1926, 1930, 1934, 1941, 1961, 1964, 1965, 1973, 1978, 1979, 1992, 2009, 2011, 2012, 2015, 2017?
Ranting about Panny plasmas, Canon cameras, Glocks, BlueNile, and HDMI on a BMW board since 2005.
2016 Honda Accord Sedan V6 Touring (wife)
2007 Chevy Suburban LT 4x4 with Nav/Bose/DVD
1968 Ford Mustang with Polk/ADS (my first car)
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
GlockMan is offline   Reply With Quote
Old 11-09-2005, 12:21 PM   #8
netengwiz
My Ride: E46 330i
That Stoptech Stage 2 Brake Upgrade looks nice!
|KW V2|Volk LE37T|Dinan|Eisenmann|Rädenergie|FormulaOne|Stoptech|Evospor t|Eibach|
2010 Audi Q5 Premium Plus S-Line|H&R|
2012 Ducati Streetfighter|Termignoni|DP|Lightech|Rizoma|
netengwiz is offline   Reply With Quote
Old 11-09-2005, 02:07 PM   #9
Mike@Modbargains
ModBargains CEO
I e-mailed you yesterday with a link to this thread
Old 11-09-2005, 02:07 PM   #10
Mike@Modbargains
ModBargains CEO
J.
The stage 2 kits only come with the Ultimate pads... no substitutions are available. You can order the parts individually if you need a different type of pad.
Old 11-10-2005, 07:58 AM   #11
dogtorj
Confirmed. Thanks.
dogtorj
Old 11-12-2005, 12:32 AM   #12
Mike@Modbargains
ModBargains CEO
Confirmed. Thanks.
No problem
Old 11-12-2005, 02:32 PM   #13
gmhl10
Resident CF Whore
My Ride: '05 A08 M3
Send a message via AIM to gmhl10 Send a message via MSN to gmhl10
Just wondering if you sell Motul DOT 5.1 also?
'05 Silbergrau M3 - mfg date: May '05
Modifications: WAY too much to list
gmhl10 is offline   Reply With Quote
Old 11-14-2005, 03:19 AM   #14
Mike@Modbargains
ModBargains CEO
We recommend the ATE, but can source some of the Motul for you if necessary. E-mail me mike@modbargains.com and we'll work it out.
Old 11-16-2005, 10:18 AM   #15
jayy178
My Ride: 00 323i
Send a message via AIM to jayy178
i pmed u...please respond when i can do a pick up
- DDE Titaniums w/ Remote Kit
jayy178 is offline   Reply With Quote
Old 11-17-2005, 01:31 AM   #16
Mike@Modbargains
ModBargains CEO
Ok please e-mail for the fastest response next time
Old 11-17-2005, 01:59 AM   #17
ThisFlyGuy
ThisFlyGuy's Avatar
My Ride: A Car
can you suggest me some brake pads for my rear brembo caliper upgrade? my current ones are squeaking too much and i need a less noisier set....
ThisFlyGuy is offline   Reply With Quote
Old 11-17-2005, 02:54 AM   #18
Mike@Modbargains
ModBargains CEO
What size calipers?
Old 11-18-2005, 01:49 AM   #19
ThisFlyGuy
ThisFlyGuy's Avatar
My Ride: A Car
What size calipers?
its the caliper upgrade from brembo.....not sure what size....i think 12.9?
Old 11-19-2005, 01:49 AM   #20
Mike@Modbargains
ModBargains CEO
If you could confirm it for me I can try to see what pads we have that would work
