Old 11-11-2005, 04:19 PM   #1
sconroy325
My Ride: '01 325xi
Coolant Light???
My coolant light keeps comming on when I start to drive. When I stop at light or start the car, there is no light. I checked the fluid, and the dipstick says full. I'm just curious if any one might have any ideas as to why this is happening.
thanks
sconroy325 is offline   Reply With Quote
Old 11-11-2005, 04:24 PM   #2
deutsch325
My Ride: xi
thanks
Maybe you need a new radiator cap? The cooling system needs to be under high pressure, if the cap is not functioning properly, that could be the cause. Have you ever had your water pump replaced? e46 water pumps have a bad reputation for failing early.. I think it has to do with the use of plastic impellers that degrade over time
deutsch325 is offline   Reply With Quote
Old 01-18-2006, 07:32 PM   #3
1edyson
Yoda Rocks!
My Ride: 325CI
Send a message via AIM to 1edyson
this sounds exactly like the problem im having...risking sounding like a noob, where exactly is the coolant resevoir? nm just found a thread on it.
2004 325Ci 2004 - current
2002 B5.5 1.8T 2001-2005
1edyson is offline   Reply With Quote
Old 01-18-2006, 11:09 PM   #4
nEVERCLEAR
My Ride: 323
Drivers side US spec cars, it is the thing with the cap on top that has the floating rod inside to tell you if it is full.
Have you checked your coolant level?
Thinking about a Honda or VW Dont buy from East Coast Honda - VW Read about my experience here
Some people dream of speed-others create a damn jet powered shopping cart.
Curious about VoIP and Vonage click here
nEVERCLEAR is offline   Reply With Quote
Old 01-19-2006, 12:21 AM   #5
kevmo
kevmo's Avatar
My Ride: vDubDizzle
Send a message via AIM to kevmo
i had that happen to me a few days ago... havn't seen it since... kinda scared... been keeping my eye on the temperature gauge....
kevmo is offline   Reply With Quote
Old 01-19-2006, 12:02 PM   #6
hummer
My Ride: 2001 330CI
If you're sure the level is good, it's most likely the sensor that turns the light on. Probably on it's way out.
