Old 11-16-2005, 04:10 PM   #1
bunnykiller67
Modded ///328i
bunnykiller67's Avatar
My Ride: 328isold-->E36 M3
Send a message via AIM to bunnykiller67 Send a message via MSN to bunnykiller67
Best Tires for Solo2 STX
I dont post at all in this part of the forum, so Im gonna ask all the experts out there who run Solo2 events to help me out. I dont know if the rules differe from region to region (Im in SF region) but Im looking to put some GOOD tires on my stock 16s.
I think the size is 205/55/16
I dont want to spend tooooo much, but I still want to be competitive.
I dont have suspension yet either
gotta get some moooe monaayyy
Thanks,
Alex
-Alex
bunnykiller67 is offline   Reply With Quote
Old 11-16-2005, 08:30 PM   #2
GeorgeE46
My Ride: '03 325i
That's a tough size it seems like. These are decent for the price
No first hand experience though
GeorgeE46 is offline   Reply With Quote
Old 11-17-2005, 01:45 AM   #3
bunnykiller67
Modded ///328i
Thanks,
Im not sure what the tred wear rating means, but I know STX needs a minimum of 140 tread wear rating. Is lower better?
The hankook ones you recommended are 200 tred wear, and the falken azeniz are the same, but 15 dollars cheaper per tire.
http://www.edgeracing.com/tire/669/
How is the hankook better?
-Alex
Old 11-17-2005, 10:12 AM   #4
TwoE46s
My Ride: Dinan 330ci & 325it
Originally Posted by bunnykiller67
Thanks,
In theory, a 400 wear tire will wear 4X longer than a 100 wear rating tire, But I understand it's really only valid within each manufacturers line of tires.
In any case, a 100 wear rating tire will usually wear out before a 200. My Toyo RA1 (R compounds) for the track are 100 (unshaven) and my Toyo Proxes 4s "all season performance tires" on the wagon are 300.......... My PS2s on the coupe I think are 240.
For high performance you usually give up tire wear, so you'll need to look between the 140 limit for the class and what you can find that will fit the car in your budget that's as sticky and therefore generally lower wear rating that you can find.
You could also check out Grassroots Motorsports, as they have a lot of focus on AutoX, and you may be able to get some good input there http://www.grassrootsmotorsports.com
TwoE46s
01-Dinan3/330ci (sold); 03-325it; 07-E92/328; 06-Cayman S
Wagon:
17X8 BBS RXs & 225/45 Toyo Proxes 4s
Coupe:(sold)
Dinan "S" plus Throttle Body & Stg 3 Software
Dinan Stage 2 Suspension
UUC Shifter
UUC Underdrive Pulleys
Goodridge Braided Brake Lines
Michelin Pilot Sport PS2s on factory M Double Spoke 68s
Track Stuff - 17X8 OZ SuperLeggeras & 235/40 Toyo RA1s; Shroth Harnesses
TwoE46s is offline   Reply With Quote
