Old 11-17-2005, 08:49 AM   #1
hemant
My Ride: 323i
Oil change (from regular to synthetic)
Hi folks, I got myself a 99 BMW 323i before a couple of weeks. Looks like the previous owner has been using regular oil in the car and I would like to switch to synthetic. I've heard that one should gradually shift to synthetic by using a regular + synthetic mix for a few times before using full synthetic. May be you guys can throw some light into this, what should be the proportion of the mix and how many times and how often should I do this before switching to full synthetic.
Considering the cost, I guess I'll DIY. I was thinking about using a oil pump extractor but was unable to locate a store that sells one. Has anyone purchased it from the local stores and how much does it cost?
hemant is offline   Reply With Quote
Old 11-17-2005, 08:53 AM   #2
hamann99
X-Hamann99
My Ride: 323i->350Z->87 325is
Send a message via AIM to hamann99
I have no idea what's going on, but all e46 should've came with synthetic to begin with. Mine did. If the previous owner was dumb enough to use mineral oil, then I really want to slap him for being that stupid. Only thing I can think of now to going back to synthetic si actually flushing the system first with synthetic oil and then do it like a regular oil change.
Any fool can drive in a straight line
hamann99 is offline   Reply With Quote
Old 11-17-2005, 08:54 AM   #3
hamann99
X-Hamann99
oh and as for a pump extractor here you go www.griotsgarage.com you'll find it on there.
Old 11-17-2005, 09:05 AM   #4
Canuck328i
My Ride: 09 Altima Cpe
I have read that synthetic and mineral oil should not be mixed. I'd suggest going straight to the synthetic oil - if you really want to be safe, do another change maybe 500 to 1000km later. That might be overkill though.
Mark
Canuck328i is offline   Reply With Quote
Old 11-17-2005, 01:00 PM   #5
hemant
My Ride: 323i
How do I flush the system? should I do it myself.
Old 11-17-2005, 01:34 PM   #6
xmltok
UCLA
My Ride: Boosted 330Ci
Send a message via AIM to xmltok
i would call a bmw shop (not a dealer) and ask them what they think is a good idea
xmltok is offline   Reply With Quote
Old 11-17-2005, 03:07 PM   #7
Kmhmuboy
My Ride: 323i
It's not really going to be a problem. When you do switch from synthetic back to non is when you'll have problems. It's hard to explain why, but basically the seals get use to the synthetic and when you go back sometimes they bust causing leaks which then creates the problems. Hope i've helped you some.
Kmhmuboy is offline   Reply With Quote
Old 11-18-2005, 09:36 AM   #8
Tom Busby
My Ride: 2001 325i, 1995 318i
Oil is oil when you put it in; the difference is that synthetic lasts longer, all other things being hypothetically equal as to detergent level, initial viscosity and viscosity extenders, etc.
Check out bobistheoilguy.com for actual tests and a much more scientific explanation.
Tom Busby is offline   Reply With Quote
Old 11-18-2005, 09:41 AM   #9
PYRITE
My Ride: 1965 Ford Mustang
Is Mobile 1 Synthetic a good choice for our cars?
PYRITE IS SOLD!!
Welcome "KRYPTONITE"...
PYRITE is offline   Reply With Quote
Old 11-18-2005, 03:06 PM   #10
deutsch325
My Ride: xi
ONLY the 0w-40 grade
deutsch325 is offline   Reply With Quote
Old 11-19-2005, 03:00 AM   #11
still
My Ride: 01 R6
i used 10w40 Castrol full synthetic,on my 63k miles 01 325i.. is that bad?
damn, my sig is too big again
still is offline   Reply With Quote
Old 11-19-2005, 03:18 AM   #12
rooneym
My Ride: 2001 E46 325I
Send a message via AIM to rooneym
Make sure the oil is BMW LL approved. Look on the back of the bottle for "BMW Longlife 01" approved
rooneym is offline   Reply With Quote
Old 11-19-2005, 11:07 AM   #13
hemant
My Ride: 323i
Ok, so I guess I'll buy the PELA oil extractor and change oil (Mobil 1 OW 40) once now and again after 500/1000 miles.
