Old 11-18-2005, 12:16 AM   #1
evm3
My Ride: horse
Help! how to remove a rear spoiler w/double sided tape
Help! how to remove a rear spoiler w/double sided tape without damaging the paint?Thanks!Ernesto
evm3 is offline   Reply With Quote
Old 11-18-2005, 01:19 AM   #2
vmwerks
Past Site Sponsor
vmwerks's Avatar
My Ride: 330zhp Super Coupe
Send a message via AIM to vmwerks
Are you referring to your OEM ///M lip spoiler? If so, you can try a heat gun and just peeling it up at the edge.
vmwerks is offline   Reply With Quote
Old 11-18-2005, 10:28 AM   #3
TwoE46s
My Ride: Dinan 330ci & 325it
Wouldn't a hair dryer work, and be safer to use (less chance of burning the paint for a "non expert")? Start with a cooler temp setting and genly work the temp up until the glue softens......... If it doesn't get hot enough, then go for the heat gun, carefully.
TwoE46s
01-Dinan3/330ci (sold); 03-325it; 07-E92/328; 06-Cayman S
Wagon:
17X8 BBS RXs & 225/45 Toyo Proxes 4s
Coupe:(sold)
Dinan "S" plus Throttle Body & Stg 3 Software
Dinan Stage 2 Suspension
UUC Shifter
UUC Underdrive Pulleys
Goodridge Braided Brake Lines
Michelin Pilot Sport PS2s on factory M Double Spoke 68s
Track Stuff - 17X8 OZ SuperLeggeras & 235/40 Toyo RA1s; Shroth Harnesses
TwoE46s is offline   Reply With Quote
Old 11-18-2005, 11:05 AM   #4
3rd_collective
ti-m-e
3rd_collective's Avatar
My Ride: Alpine White ///M
Send a message via AIM to 3rd_collective
Dental floss, cuts through the tape. No muss no fuss.
3rd_collective is offline   Reply With Quote
Old 11-18-2005, 11:15 AM   #5
evm3
My Ride: horse
Thanks 4 the good advice.
I am trading the car today so i hope i do not take off the paint
Old 11-18-2005, 11:55 AM   #6
FLVK
My Ride: 2002 330CI Stl Grey
so which car are you trading for?
FLVK is offline   Reply With Quote
Old 11-18-2005, 12:27 PM   #7
ca1242
My Ride: 2003 330i
Use WD40 to remove any glue residue. Works great and does not damage the paint.
Old 11-18-2005, 12:30 PM   #8
evm3
My Ride: horse
RRS
Old 11-18-2005, 12:54 PM   #9
FLVK
more pratical for you
Old 11-18-2005, 04:41 PM   #10
eBean
My Ride: '04 330ci
Send a message via AIM to eBean Send a message via MSN to eBean
To take it off, use a hair dryer if you dont have a heat gun and then use fishing line. Dental floss isnt strong enough and will break apart. After that, use some goo gone or whatever and make sure you clean it and then wax it. Should be good as new.
Sponsored By: Carrozzeria Design
eBean is offline   Reply With Quote
Old 11-18-2005, 05:02 PM   #11
3rd_collective
ti-m-e
Originally Posted by eBean
use fishing line. .
even better
