Sponsored by BAVSOUND
Old 09-25-2002, 10:44 PM   #1
Staszek
Are we there yet??
Staszek's Avatar
My Ride: Now a daily drive
Send a message via AIM to Staszek
Wiring Question
Ok so if I have a 4 channel amp that can create 100 x 4@2ohms rms. How do I wire my speakers to be 2 ohms so that I get 100watts to each speaker. I have a pair of focal components, and a pair of Stealth boxes. If this is not possible do I just get a 2 channel amp?
Euro Delivery Thread
///M3-6MT:dance:
Staszek is offline   Reply With Quote
Old 09-26-2002, 03:33 PM   #2
Staszek
Are we there yet??
Staszek's Avatar
So I am a little confused.
This is what I have
A pair of Focal 136k's
and A pair of Stealth boxes
What would be the best way to power them with one amp?
I was thinking an amp with trimode capability, but what type of power and what type of amp should I use? I dont want to spend a ridiculious amount. Thanks!
///M3-6MT:dance:
Old 09-26-2002, 05:52 PM   #3
theJrod
My Ride: X5-sold, 330i, WRX
The easiest way to wire your setup would be one speaker per channel.
I'm not sure where the above poster is getting the 25W number. If your amp is rated at 100 watts per channel when running a 2 ohm load, then it's probably capable of 50W per channel into 4 ohms. 50W is easily enough for your Focals, and probably satifactory for the JLs.
Another option would be wiring the Focals normally using the amp's 2 front channels, then bridging the 2 rear channels into one, and running the JLs wired in parallel. The only problem is, the amp's rear channels would see a 2 ohm load while being bridged at the same time. It's almost like a 1 ohm load to the amp. Not many amps can handle that for a sustained period.
theJrod is offline   Reply With Quote
Old 09-26-2002, 08:10 PM   #4
Staszek
Are we there yet??
Staszek's Avatar
Thanks! This is one of the amps I was looking at.
Rockford Power 550x
Here are the specs
65 watts RMS x 4 at 4 ohms
137.5 watts RMS x 4 at 2 ohms
275 watts RMS x 2 in bridged mode at 4 ohms
2-, 3-, or 4-channel output
Tri-Way capable
MOSFET power supply and output devices
So could I run the focals on 2 channels and bridge the subs?
///M3-6MT:dance:
Old 09-27-2002, 01:10 PM   #5
theJrod
Yes, you could, but you might want to make sure the amp is rated to handle a 2ohm load when bridged. Rockford Power amps are very good - you shouldn't have a problem.
Old 09-27-2002, 05:59 PM   #6
Staszek
Are we there yet??
Staszek's Avatar
Ok so if I used the amp that I listed above the Rockford how would I wire the speakers?
///M3-6MT:dance:
Old 10-01-2002, 10:31 PM   #7
Staszek
Are we there yet??
Staszek's Avatar
Anyone?
///M3-6MT:dance:
Old 10-02-2002, 11:18 AM   #8
theJrod
Just wire the front speakers normally, and wire the rear subs in parallel to the bridged rear channels. Do a search - there are wiring diagrams floating around everywhere.
