///M3 Forum
Closed Thread
Old 11-19-2005, 06:16 PM   #1
Domm
My Ride: 2002 M3
I ****ed up bad. camshaft-oil problem
if all you are going to do is flame me, just leave the thread and thats that. I ****ed up badly the other night. The oil light came on, i got oil, put it in and accidently dropped the oil cap down below the engine. heres where i ****ed up- i temporarily plugged the uncapped oil hole with a sock and the sock got sucked into it after about 5 mins of driving. its wrapped around the cam shaft-im pretty sure thats what it is... and i need some advice on how to get it out without shelling a shitload of money out to bmw to take it in there. should i unbolt the top piece there and cut it out and then flush the whole thing with some stuff at kragen or just try to cut it out piece by piece through the hole with a sharp razor and take the pieces out with needle nose pliers and then flush it?
please any advice or help on this crap move i made would really really really help me out.
thanks to anyone who replies
Domm is offline
Old 11-19-2005, 06:29 PM   #2
Quick M3
My Ride: 04 E55
I would think the best way is to remove the cover.
Quick M3 is offline
Old 11-19-2005, 06:30 PM   #3
Tschmale
My Ride: '00 328 Ci
you will need to remove the valve cover and get it all out. The Question is why didn't you retrieve the oil fill cap from under the car? BMW supplies you with all the neccesary tools to do remove your scratch panel.
"Your not really drunk if you can lay flat on the floor without holding on" Unknown
Tschmale is offline
Old 11-19-2005, 06:30 PM   #4
Noodle555
My Ride: M3 Cabriolet
That really sucks man!
I am not sure about the fix, but I would think that there a fibres that must be floating around in the oil even when you remove the sock. A solid drain and flush are essential. Good luck.
M3 Vert TiAG/Blk - with every option
Mods: Clear Bra | Tints | Hardwired Passport SRX | Painted Bumper Reflectors | Keyhole Cover | 6000k Predator Chromiums | 6000k Philips Ultinons | 6000k HID Fogs | Philips Silvervision Corners | OEM LED Tails | Trunk Lip Spoiler | Eisenmann Race | CSL Diffuser | CD/DVD Swap | Small Antenna | Blackout Grille and Gills | Smoked Corners
Mods ready to install: Paddle Upgrade | ZCP Rotors | CF Interior Trim
Noodle555 is offline
Old 11-19-2005, 06:34 PM   #5
Domm
My Ride: 2002 M3
thanks for the reply. it was dark and i couldnt see anything at the time, i just wanted to get home to where i would have some more light and things just didnt go as i thought. im a total dunce. so taking off the valve cover would be my best bet?
edit: then towing the car to a spee dee oil change, definitely not drive it, right?
Domm is offline
Old 11-19-2005, 06:41 PM   #6
Domm
My Ride: 2002 M3
ok, ive given this a little more thought. like i said i am very tight with money right now, but i have a few resources that might help me out. i have my moms AAA card for a free tow, i have a chevron card that my dad thankfully lets me use and spee dee oil change takes chevron cards. im gonna go down there right now to see if they'll be able to help me with the problem
Domm is offline
Old 11-19-2005, 08:34 PM   #7
Commander FAT
Network Analyst
My Ride: 2002 330Ci
A quick lube place will not be able to help you with your problem. You need to take it to a real shop.
Because the B isn't for bling.
Commander FAT is offline
Old 11-19-2005, 09:08 PM   #8
joedaddy
My Ride: OCTA
take it to a certified mechanic.. a german/BMW if u can find one..
tell them to take the socks out..
and not sure if SPEE D OIL place would have oil for an M3.. i doubt it
joedaddy is offline
Old 11-20-2005, 01:33 AM   #9
gimpyviper
My Ride: 2003 BMW M3 - PYM
Send a message via AIM to gimpyviper
Dude, that just sucks, there's no easy way around it. You gambled and unfortunately got bit. I think you shouldn't chance it and make it worse by finding a cheap solution to the problem. I would get the car to a certified BMW repair mechanic either a dealer or wherever. A sock wrapped around the camshaft is some serious sh1t. I would be more worried about making it worse than saving money at this point. Suck it up, find the money and get it done right. Don't chance it on making it worse and do real damage.
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you."
gimpyviper is offline
Old 11-20-2005, 01:48 AM   #10
m3lowrider
My Ride: In Progress _/_/_/
Send a message via AIM to m3lowrider
yo, screw the money factor, if i was u, get it properly done. i was really never in this position before... sock sorry but yea, get it done properly. where's ur car right now?? anyways best of luck
-Humza
***///M3 AW/IR: BBS CHs, PSS9s, RE RSMs, Powerflex RTABs, Depos, SS Race, SS X & S Pipes, CF gills and grills, V-CSL CF Diffuser, V-CSL Bumper, V-CSL Boot, V-CSL Console, LeatherZ IR, CF Emblems, 6000k Chromiums, 8000k d2s Bulbs***
m3lowrider is offline
Old 11-20-2005, 01:52 AM   #11
MrMotorwerk
Der Meisterstück
MrMotorwerk's Avatar
My Ride: '02 330Ci,'01 M3,M4
This thread is ...
both Ghetto and Funny.
Los Gatos and M3 = $$$$$, so why are you pinched for cash?
Honestly, take it to a mechanic.
MrMotorwerk is offline
Old 11-20-2005, 02:06 AM   #12
Skeeter
Skeeter's Avatar
My Ride: 2003 M3
Send a message via AIM to Skeeter
This is almost as good as the SRT-4 guy who tried to drain the engine oil by running the engine with the oil filter cover off.
I e-salute you in your misfortune.
Skeeter is offline
Old 11-20-2005, 02:16 AM   #13
iseedipp
My Ride: SMG II M3 and H2
Send a message via AIM to iseedipp
Originally Posted by MrMotorwerk
This thread is ...
i concur los gatos + m3 = $$$$$
los gatos + you = $$$
person living in los gatos + m3 + sock in engine = priceless
For Sale 2002 Topaz Blue Metallic Sequential Manual Gearbox M3 Coupe
CF front splitters|Gruppe M Ti exhaust|19" v715 Matte black with SS lip|Black out package|Phillips Ultinon 6k|6k Angel eyes|OEM LED tails|Pioneer Avic N2 and more
2003 White on Beige Hummer H2
33" toyo open country and dubs otherwise stock.
_________________
Coming soon
06 Yamaha R6
08 Jeep Grand Cherokee SRT-8
Myspace/vivaladipp
iseedipp is offline
Old 11-20-2005, 02:33 AM   #14
boxed
Banned
My Ride: M3
Send a message via AIM to boxed Send a message via Yahoo to boxed
try doing it your self first, unbolt the silver bolts on the valve cover, and see if u can get the sock to come out..PULLLLLLLLLLLLLLLL as fukin hard as u can...see what u can get it out of it...after that, do a full engine flush. remember USE 60W 10 Engine oil from BMW! NOT that jeffy lube ****!
you coulda drove the car home SAFELY without the oil cap off...i did that once. i checked the oil level and forgot to put the cap on. drove it pretty hard for 15mins and what do i smell afterwards? hmm oil burning LMAO ****ing stupid me. cleaned the oil and such added oil afterwards and found the cap under the car. learn form your mistakes man. gl
boxed is offline
Old 11-20-2005, 01:47 PM   #15
AEsco48
My Ride: E46 M3
Send a message via AIM to AEsco48
bro, if the sock got jammed in any part of the valvetrain...its not going to be as simple as just cutting it free....im sure something is bent....and work on the valve train is very labor intensive and expensive....
AEsco48 is offline
Old 11-20-2005, 02:30 PM   #16
gimpyviper
My guess is in the end they're gonna have to practically rebuild the engine to make sure no fibers or pieces of sock are stuck anywhere.
Old 11-20-2005, 05:02 PM   #17
55fanatic
My Ride: B5 Avant, 07 Denali
hahaha um yeah this is priceless... I worked in a family garage for the last two years... your def gonna wanna take that to at least an independent garage that specializes in BMW. Once you get in to your cam shafts if you dont know what your doing your going to kill your car. spending the extra money now will save you money from a full rebuild
55fanatic is offline
Old 11-20-2005, 06:32 PM   #18
MPM3
My Ride: 2005 BMW M3
Sorry for the picture but I couldn't help it. Tow it to a good local BMW shop like Rennworks and pay the money to do the repair right. Forget SpeeDee man. Your way beyond anything they can do. You screwed up, so now you'll have to pay.
2005 BMW M3 Jet Black/Black, Prem Pkg, 19" BBS RS-GTs, Continental VMax 2s, Eibach Pros, Magnaflow Exhaust, aFe Stage 1 CAI, Powerchip software, Xenons, UUC EVO3 SSK & DSSR, BMW B/T phone/cradle, CDV Delete, Clear Reflectors, 3M Clear bra
2000 BMW 740iL
2003 Nissan Altima 3.5
1999 Chevy Tahoe 4X4
1995 Impala SS
MPM3 is offline
Old 11-20-2005, 07:46 PM   #20
mtfour
Mooove, get out the way!
My Ride: 2004 S4, 2010 A6
Oh Man!!!
mtfour is offline
Closed Thread
