Old 11-19-2005, 11:22 PM   #1
umnitza
877•486•6489
umnitza's Avatar
My Ride: E39M5, Sequoia
••ü•• World's Brightest Flashlight - Luminos FireLight™
Title:
Luminos FireLight™
"Now you're playing with fire!"
Flashlight Picture
Standard Package Includes (see pictures below)
Battery Charger with Overcharge Protection
SoftGrip
Power Outlet Charger 12/24VDC
Carrying Strap
Flashlight
Canvas Carrying Case
Description:
The most illuminating, powerful, and easy to use flashlight ever made. The Luminos FireLight™ is capable of illuminating objects at over 1500ft away, using a proprietary compact HID technology found nowhere else.
The sharp contrast of the extra cool 6000K light from the full sized HID capsule creates a powerful, contrasting light at night or even day time. The narrowly focused beam doesn't spread like other high power flashlights, and is only 2' in diameter at 1000ft, producing more lumen per watt than any incandescent bulb on the market.
The fully integrated and rechargeable lithium ion battery (from SONY) delivers power almost immediately with a small 10 second startup time and 20 seconds to 100% illumination.  Unlike other flashlights that use standard batteries and have to be recharged for hours and lost only a short time, the Luminos FireLight™ works for up to 2 hours continuously on a charge and takes only 60 minutes to fully recharge.  Lithium ion batteries hold their charge longer than alkaline or metal hydride batteries, allowing the Luminos FireLight™ to be used immediately even after prolonged storage.
The design criteria for this light are based the needs of law enforcement, border patrol, fire departments, marine/coast guard, and other public and private security organizations. However, the needs of the average person are not overlooked - whether you're camping, hiking, exploring, or even if you are in an emergency situation - the Luminos FireLight™ ideal for all recreational use.
The ruggedly powerful aluminum casing is sturdy and touch, but not heavy. The rubberized end caps and overall strength of the headlight construction means that even if dropped or mishandled, you'll likely receive many years of uninterrupted use. The easy to handle and heuristically ideal size of the flashlight allows it to be used in self defense, whether shining the powerful light into an attacker's eyes, deflecting any blows, or as an aggressive self-defense weapon.
Application(Please consult your owner's manual for your application fitment type):
Security, Self-Defense, Personal Recreational, Public Safety, Many More...
Engineering Detail:
Dimensions: Ø 2.25 in. (at base) x 15.25 in. length
Weight: 2.50 lb
Lens: Hardened Glass
Bulb: HID Capsule
Color Temp: 6000K
Lumens: 1300-1750 (depends on wattage)
Battery: 12.0V / Lithium ion
Features:
  • Spot Focus - Direct Beam
    15 sec. to full brightness
  • Hot Restrike
  • End Cap Rechargeable Outlet
  • Rubberized Carrying Strap Rings
  • CNC Machined Aluminum Outer Shell
  • Shock Absorbing End Caps
Operating temperatures:
Operating: 0° - 40°C
Storage: -20° - 35°C, RH 45-85%
Charging: 10° - 30°C
Battery charger: 100/240VAC, w/automatic over charge protection, 2 hr., charge.
Tips:
  • Fully Charge Unit Upon Receipt for 2 Hours
  • The headlight cannot be driven over, and is not indestructible.
  • Keep glass lens clean and free of debris as this does affect light pattern
  • DO NOT SHINE DIRECTLY INTO ANYONE'S EYES
  • Exercise caution when pointing beam at motorists, bicyclists, or any other moving vehicle.
Flashlight PictureFlashlight Picture
Flashlight Picture
CLICK THIS FOR VIDEO
http://www.umnitza.com/product_info....roducts_id=309
Old 11-19-2005, 11:38 PM   #2
jEEliX
My Ride: 2000 323i
Send a message via AIM to jEEliX
Wow.. anyone who buys that thing has WAY too much money....
jEEliX is offline   Reply With Quote
Old 11-19-2005, 11:43 PM   #3
umnitza
877•486•6489
umnitza's Avatar
CLICK THIS FOR ANOTHER VIDEO
Old 11-19-2005, 11:58 PM   #4
TCoville
My Ride: 02 330i
looks like a lighsaber
TCoville is offline   Reply With Quote
Old 11-21-2005, 05:37 AM   #5
gmhl10
Resident CF Whore
My Ride: '05 A08 M3
Send a message via AIM to gmhl10 Send a message via MSN to gmhl10
Hmmm... not an E46 product... but still interesting.
Then again, there's a guy on the forum selling tortilla chips....
I was looking for a flashlight too.
Only thing is that it's a bit pricey for a flashlight and it doesn't have like an extra mini flashlight like those maglite kits.
'05 Silbergrau M3 - mfg date: May '05
Modifications: WAY too much to list
gmhl10 is offline   Reply With Quote
Old 11-21-2005, 09:53 AM   #6
umnitza
877•486•6489
umnitza's Avatar
Compare it to the cost of other HID flashlights in the handheld variety on the market.
Old 11-21-2005, 10:04 AM   #7
jtkun
My Ride: OrientBlue on CHs
Here's a HID flashlight from Surefire that's brighter, although I'm sure the one from Umnitza is a lot cheaper:
The HellFire target illuminator is designed for use on .50 caliber machine guns , and can also be used as a vehicle-mounted or hand-held spotlight (vehicle mounting hardware sold separately). Its shock isolated 35W HID lamp has an output of approximately 3500 lumens, and is powered by either the included cigarette lighter/power plug adapter, or two 5590 military batteries. The machine gun operator can select between momentary and constant-on activation by using an included hand grip which replaces the trigger grip on the machine gun handle. Because of its small size (8 inches) and light weight (10 lbs.) HellFire also can be used as a portable, hand-held light by detaching it from the included mounting sleeve and using the integrated carry handle. HellFire’s runtime when used this way (and powered by two 5590 batteries) is approximately 8 hours. HellFire’s body is built from an aluminum alloy with a hard-anodized MIL-A-8625 type III finish. A 5mm thick multi-coated Pyrex® window protects the HID lamp, and an amber filter on a pivoting mount protects the window during severe weather or while in storage. HellFire’s aluminum comes in a hard-shell storage case that is weatherproof and lockable.
* Power source 12V DC: Auto battery (adaptor included) or two 5590 military batteries
* Runtime: Auto battery: continuous; 5590 batteries: 8 hours
* Mount: HellFire slides onto T-slot mount, which attaches to machine gun sleeve. Picatinny rail also incorporated into mount.
* Length: 8” (body and bezel)
* Weight: 10 lbs. (light and mount combined)
* Bezel diameter: 4.1”
* Finish: Hand anodized “NL” gray MIL-A-8625 type III, class 2
* Water Resistant: O-ring seals and rubber gaskets at critical mechanical mating surfaces
jtkun is offline   Reply With Quote
Old 11-21-2005, 10:11 AM   #8
umnitza
877•486•6489
umnitza's Avatar
You're absolutely right.
But "Brightest Handheld - MagLite sized - Thine Profile Flashlight" didn't fit on the title bar
In all seriousness, in the class that this particular flashlight plays in, it's at least 5X brighter than anything else.
Old 11-21-2005, 04:14 PM   #9
tdevil
My Ride: 03 325i
Send a message via AIM to tdevil
Hrmmm can you get the ones the police carry? i think those are brighter than normal too. or am i wrong?
tdevil is offline   Reply With Quote
Old 11-21-2005, 04:16 PM   #10
DANTHEMAN
Banned
My Ride: X5 4.4/ M3
Why would anyone want that
DANTHEMAN is offline   Reply With Quote
Old 11-21-2005, 04:18 PM   #11
umnitza
877•486•6489
umnitza's Avatar
We just finished our proposal for a Sheriff's Dept. Hopefully, once they commit (already ordered 2) we'll be seeing more of these at various locations
Old 11-21-2005, 04:47 PM   #12
guest1017
Banned
guest1017's Avatar
My Ride: M3
Send a message via AIM to guest1017
i was actually considering it because i work for the NYPD.. but 275?? probably a good price but i cant pay that much for a flashlight
guest1017 is offline   Reply With Quote
Old 11-21-2005, 04:58 PM   #13
gmhl10
Resident CF Whore
My Ride: '05 A08 M3
I'm with you on that one.
I just want a mini one to store in my glove compartment cause the oem bmw one is weak sauce and one so I could use to manuever around my house at night (sometimes, i can't find the lightswitch in the dark lol).
Don't really need a flashlight to go stop crime vigilante style or something.
Old 11-21-2005, 05:03 PM   #14
JC7727
JC7727's Avatar
My Ride: 01 330i
Send a message via AIM to JC7727
Sponsored by Jlevi StreetWerks
FOR SALE: http://forum.e46fanatics.com/showthread.php?t=417026
JC7727 is offline   Reply With Quote
Old 11-21-2005, 09:04 PM   #15
BimmerDude18
My Ride: 1998 528i
Originally Posted by JC7727
Is that difficult to understand??
-Tyler
1998 528i 5-speed Work in progress
1988 Toyota Pickup (4WD 5-speed) daily
2007 San Marino Blue 350z 6-speed sold
1996 328i 5-speed sold
www.e46nonM.com - www.precision-sport.com - www.flyingwindowtinters.com - www.techniquetuning.com
BimmerDude18 is offline   Reply With Quote
Old 11-21-2005, 09:14 PM   #16
TCoville
My Ride: 02 330i
coming from the guy who was asking what to do when you get egg on your car because his friends threw some at another car before he could stop them it is.
Old 11-21-2005, 09:22 PM   #17
PYRITE
My Ride: 1965 Ford Mustang
Why would they buy from a reseller and not the source?
PYRITE IS SOLD!!
Welcome "KRYPTONITE"...
PYRITE is offline   Reply With Quote
Old 11-21-2005, 09:25 PM   #18
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
Send a message via AIM to JonJon
CLEANS TOILETS ^^^^^^^
JonJon is offline   Reply With Quote
Old 11-21-2005, 09:33 PM   #19
swiftss13
808///Member
swiftss13's Avatar
My Ride: 05 325i, 135i
Send a message via Yahoo to swiftss13
Try to get this to the miltary market. I know I sure could of used a brighter flashlight in Iraq. Is there a way to mount this on a M4?:
05 Alpin Weiss 325i
swiftss13 is offline   Reply With Quote
Old 11-21-2005, 09:34 PM   #20
BimmerDude18
My Ride: 1998 528i
NVM - I'm not in OT enough here to have caught that one.
-Tyler
