Old 11-25-2005, 09:49 PM   #1
kyle808
My Ride: 00 328CI
sunshade lubricant for smoother sliding?
does anyone know what lubricant and where to lube it to make my sunshade slide back and forth smoothly.. it's works and all, but it sometimes get stuck and I have to use alittle force for it to slide back. thanks alot.
"I'm gonna die! Jesus, Allah, Buddha - I love you all!
-Homer Simpson
kyle808 is offline   Reply With Quote
Old 11-26-2005, 08:09 AM   #2
hemant
My Ride: 323i
I've the same problem.
hemant is offline   Reply With Quote
Old 11-27-2005, 05:54 PM   #3
Tom Busby
My Ride: 2001 325i, 1995 318i
I don't have this problem but if I did I would use silicone wax that comes in a stick, about the diameter of a quarter and 3 inches long is what it looks like in the package. It feels like surfboard wax but a little softer. It isn't greasy and it won't melt or run onto the headliner. You could rub it on the gliders and rails, and smooth it into the corners with your finger.
Tom Busby is offline   Reply With Quote
Old 11-27-2005, 10:28 PM   #4
kyle808
My Ride: 00 328CI
Good tip, I should be able to get some from Home Depot right? I'm gonna give it a try. Thanks.
-Homer Simpson
Old 11-28-2005, 12:53 AM   #5
Nuori
_
Nuori's Avatar
My Ride: A 323 mule pepe
Any gel grease for hydraulics should do (Lowe's or Home Depot will have it in a tube.) It has the same consistency as what BMW uses for their lubricants in seat tracks, sun roof tracks, etc. That's all you need.
Nuori is offline   Reply With Quote
Old 11-30-2005, 08:24 PM   #6
Flycaster
My Ride: '05 Z4 2.5, '13 ATS
What do you guys think of white lithium grease? Won't run, won't dry up, won't melt.
Flycaster is offline   Reply With Quote
Old 11-30-2005, 11:22 PM   #7
Nuori
_
Nuori's Avatar
It should be fine. I've seen it used on some cars.
Old 12-01-2005, 03:47 AM   #8
CortinaD
My Ride: lots
ive had good results with teflon and silicone spray but they have to be reapplied every few months.
CortinaD is offline   Reply With Quote
Old 12-06-2005, 10:14 PM   #9
kyle808
My Ride: 00 328CI
okay, I've used some red multi-purpose grease and it's works pretty good. I probably have to apply alittle more, but it's sliding a lot easier than before. It looks like gel. thanks for the tips guys.
-Homer Simpson
