Old 11-29-2005, 11:06 AM   #1
slique
My Ride: 2002 330I
Question Tail light problem
I'm hoping someone here can help me. I have a 2002 330I and the tail lights have been acting peculiar. The drivers side keeps going dim as if there is a poor connection some where. I suspect maybe an oxidized contact or something. Any help would be greatly appreciated.
-Slique
slique is offline   Reply With Quote
Old 11-29-2005, 11:34 AM   #2
hummer
My Ride: 2001 330CI
Try wiggling the bulbs out then back in to clean the contacts.
This happened several times on my car when it was new though.
Old 11-29-2005, 11:48 AM   #3
slique
My Ride: 2002 330I
Hmm... I think I found the problem. When I pulled the connector off the tail light assembly I noticed that one of the wires had melted the plastic around it. I read an earlier post that said something about grounding the wire somewhere else. Is it always the ground wire that does this? If so, is there a recomended place to relocate that wire?
Old 11-29-2005, 03:45 PM   #4
m3cabrio
My Ride: convert m3
connection
m3cabrio is offline   Reply With Quote
Old 11-29-2005, 04:41 PM   #5
winter_baby
My Ride: e46
I noticed the same thing but mine gives a "replace bulb light' with passenger side rear tail light.
Funny thing is that it goes away when I apply brake then returns as soon as I release it. No bad connection or anything from checking it.
BTW, it started doing that after I installed oem alarm kit. Any help would be appreciated...
2003 330i Titanium Silver / Black - [Sold]
2000 Z3 M Titanium Silver / Imola Red+Black Nappa
2001 330cic Metallic Steel Gray / Gray - [Sold]
2000 Z3 2.8 Topaz Blue Metallic / Beige - [Sold]
1997 Z3 1.8 Atlanta Blue Metallic / Beige - [Sold]
winter_baby is offline   Reply With Quote
Old 11-01-2006, 12:39 PM   #6
az-03-325xi
My Ride: 3 guesses...
I'm with slique in that the tail light wire harness has been melted surrounding the ground wire. It now shorts with its neightbors and random times and leaves me without any rear lights.
My local dealership is not all that helpful so far. I need the plastic peice that has 2 rows of 4 pins each. Thier system tells me I need part # 61138369702 which is a flat 6 pin connector. They had that in stock and it was obviously wrong so they guessed and ordered # 61138369712 which is also a 6 pin harness.
Anyone have any idea of the part number for the 8 pin harness?
az-03-325xi is offline   Reply With Quote
Old 09-30-2007, 03:44 AM   #7
skybmw
My Ride: 330XI 2003
I need the same thing.....mine is melted....it gave me the warning light on....
skybmw is offline   Reply With Quote
Old 09-30-2007, 12:44 PM   #8
az-03-325xi
These pretty much sum up a lot of the info on the board
http://forum.e46fanatics.com/showthread.php?t=472357
http://forum.e46fanatics.com/showthread.php?t=418836
http://forum.e46fanatics.com/showthread.php?t=425784
Old 09-05-2008, 06:03 PM   #9
J.R. de Veer
My Ride: 2004 M3
I've had problems with my wife's car since it was new. Tried replacing the bulbs but none were burnt out. Finally noticed after removing the wiring harness that one of the connectors was melted. Replaced the entire unit light bulb socket unit. Now months later the other tail light is also melted inside the connector. Purchased another socket assembly including new connectors. Anybody out there fixed the problem to final resolution?
J.R. de Veer is offline   Reply With Quote
