Thread Tools Search this Thread Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
Old 11-29-2005, 03:14 PM   #1
quazyboi
My Ride: 00 328Ci steel grey
RPM idle is dancing???
Hi fellow e46 fanatics, I recently purchased a 00 328Ci, and everything is great. Found this website to be the best so far for learning new things about my car and i love the DIY section. Well my problem just started as winter is coming in. Now that the morning temp. is in the 40's, i some times have trouble with my idle staying constant. Seems like when its cold the idle jumps from 800 down to aournd 300 or 400 hundred then pops back up. Its like the car is SHIVERING...lolz But the other day, i started it up and then went back inside to get my coat, then when i came back out, the engine was off. I'm guessin the idle dropped too low and it shut. I tried changing the Sparks, but that didn't work....n e help would really help guys. Don't really want to take it to BMW itself, cuz thats gonna probably put a nice hole in my pocket. =( By the way, the car is totally fine after it is warmed up...no problems
quazyboi is offline   Reply With Quote
Old 11-29-2005, 03:24 PM   #2
mikemartin9
My Ride: 2000 328i
Idle issues on cold start
This can be intake cam the Vannos Solenoid, parts 2,3 &4 in the diagram, around 100 bucks at the dealer.
mikemartin9 is offline   Reply With Quote
Old 11-29-2005, 03:55 PM   #3
KrzyBum420
My Ride: E92 M3
Send a message via AIM to KrzyBum420
i got the exact same problem. also when im in reverse the rpms drop below 500 and the car just dies
KrzyBum420 is offline   Reply With Quote
Old 11-30-2005, 10:27 AM   #4
hal88
My Ride: e90 330i
Your problem is not isolated, many of us here have the same exact same problem, i have the same car u have and guess what? mine does the same thing when is cold out, I took mine to the local auto zone for a scan read and it came back with a intake crankshaft sensor code and a vanos stuck code, i have not changed either one of them for lack of time. I read some posts where guys just live with the problem, they just warm up the car and that's it......do a search on cold idle issues and you'll find a few posts. Keep us posted please.
00 328ci, X5 4.4
hal88 is offline   Reply With Quote
Old 11-30-2005, 10:50 AM   #5
driftinsequence
My Ride: waiting to be modded
Send a message via AIM to driftinsequence
intake/exhaust camshaft sensors?
driftinsequence is offline   Reply With Quote
Old 02-18-2006, 04:42 PM   #6
bimmer88
My Ride: 06 Lexus GS430
Send a message via AIM to bimmer88
yeah.. same problem here.. just been living with it for the past few months...
bimmer88 is offline   Reply With Quote
Old 02-18-2006, 05:06 PM   #7
sheefo2k
sheefo2k's Avatar
My Ride: vrm psh - 02 325ci
youi live with a lot of problem
Performance BMW car
Sponsored by :
www.euro-spec.net
www.bimmian.com
BMW Motorwerks
support:
www.vmwerks.com
www.esstuning.com
www.my330i.com
sheefo2k is offline   Reply With Quote
Old 02-18-2006, 05:30 PM   #8
bimmer88
yup! looks like you're having your share also...hehehhe..
Old 02-18-2006, 07:06 PM   #9
sheefo2k
sheefo2k's Avatar
loool shut up that hurts
Performance BMW car
Sponsored by :
www.euro-spec.net
www.bimmian.com
BMW Motorwerks
support:
www.vmwerks.com
www.esstuning.com
www.my330i.com
Old 02-18-2006, 10:21 PM   #10
328I99E46
My Ride: BMW
Hi i have the same problem with my car 328i 1999 e46 damn its pisssing me off so bad i did check icv,intake,plugs,voltage regulator itc ... been to dealer and nutting no code anything like that and it cant be vanos i had that done too it used to stall when it was cold out i reallyy dont know whats the deal !!!!! i am going to change one more think even if i dont see any code there it will be intake camshaft sensor and see from there if there is any change ..... If anyone find it out please let me know !!!!!! lol thanx
328I99E46 is offline   Reply With Quote
Old 02-19-2006, 12:05 AM   #11
hal88
My Ride: e90 330i
I changed intake camshaft sensor and no help, I have a fault code which says it's my crankshaft sensor, but havent changed that yet. Take it to autozone for a code read.
00 328ci, X5 4.4
Old 02-19-2006, 12:45 AM   #12
RedBarron
My Ride: Porsche
Send a message via AIM to RedBarron
My car has the idle drop no matter how hot or cold it is. The BMW tec said I sould replace my idle control valve and he said it seemed that my DISA was sucked in and pre 2002 have prob with it.
RedBarron is offline   Reply With Quote
Old 02-19-2006, 03:08 AM   #13
spyder
My Ride: S54 Sedan, IB 328i
Send a message via AIM to spyder
Have the same problem, idle would go up and down when its really cold, after 3-4 minutes the car warms up and its fine. Sometimes it will stall out though.
spyder is offline   Reply With Quote
Old 02-19-2006, 08:24 AM   #14
328I99E46
My Ride: BMW
My idle go up and down within 900 to 500 when i change gear from N to D or P to R itc thats when it jumps all over and it wasnt like that before i have this car for almost 4 years now and dealer actually trying to tell me thats how they work bs... ok i know myself something is not right and i do check codes myself almost everyday and nothing ...
Old 02-23-2006, 09:25 PM   #15
BMW04E46
My Ride: 2004 325Ci SMG
I got a 04 325Ci and when stopped at a stop light, usually during the night, my idles fluctuates from around 800 rpm down to almost 400 rpm and back up and down, but no check engine light. If I take it to the dealer with no light on do you guys think they can find out what the problem is??
Steven
BMW04E46 is offline   Reply With Quote
Old 02-24-2006, 12:44 AM   #16
bigboy4074
My Ride: 323Ci
Send a message via AIM to bigboy4074 Send a message via MSN to bigboy4074
I had a similar problem with mine around new years. Jumpy idle then one night went out to drive back to school car would start then just die. Idle control valve was the part that died on mine.
bigboy4074 is offline   Reply With Quote
Old 02-24-2006, 12:52 AM   #17
UnBreakable
My Ride: OB E46 328i
Many of us have this problem and here they talk about it, read up: http://forum.e46fanatics.com/showthread.php?t=340572
UnBreakable is offline   Reply With Quote
Old 11-26-2007, 04:53 AM   #18
Martin Benca
My Ride: BMW 325ci E46
Hmm, as this year's winter arrived I had the very same problem with my E46 325ci (M54B25 engine), though my engine at least didn't die (yet) and if I pressed gas a bit it usually returned back to normal. Nevertheless since it happens only rarely and engine service LED doesn't go on I think it doesn't even make sense to go to the repair with it since I'm pretty sure according to Murphy's law everything would work flawlessly there and break right after again.
For the time being I think I'll just live with it unless it gets worse but any advice would appreciated. Fortunatelly it really seems to happen only when engine is not fully warmed up.
It happens rarely for me (and seemingly only in cold weather plus it is "fixable" by pressing gas shortly) so it is not a big problem but I worry that ignoring it might affect also performance or longevity of the engine.
Martin Benca is offline   Reply With Quote
Old 11-26-2007, 08:18 AM   #19
mechanic_101
My Ride: 2005 325I
I don't have any idle problem with my BMW. But in the past I had worked on many vehicles, and 90% turned out to be the idle control valve. During idle, the control valve is the only source supplying air, if not enough air the RPM will drop. The reason it is difficult to diagnose cuz it does not set code...I'd gamble on this part.
Note: I don't know whether BMW idle control air set code, but big 3 vehicles do not set codes.
mechanic_101 is offline   Reply With Quote
Old 11-26-2007, 09:57 AM   #20
tripalthreat
My Ride: 2005 300xi
Do you ALWAYS run premium gas in your car? If so, drop a 50% tank of regular in once a month. It causes the computer to recalculate the octane - it gets "lazy" if you always use premium, so any imperfections in the gas mess up the idle.
My dad had this problem with his Cooper S and was told it's an issue with BMW computers. I've tried it and it works, as dumb as it sounds.
2005 330xi
6-speed | Sapphire Black Metallic | Beige Leather
M3 Lip Spoiler | BMW Aluminum Pedals | Valentine 1 | TomTom GO 720
Summer: 17" Type 137 | Winter: 17" Type 73 w/ WinterSport 3D
Coming soon: Full OEM clears
tripalthreat is offline   Reply With Quote
