Old 11-30-2005, 06:11 PM   #1
delta
My Ride: A4 2.0TQ 6MT
Question about DSC
Hello. I recently got a 00' 328ci and noticed something weird about my DSC. To disable part of the system, press the DSC button briefly. This works fine on my car. Now if I want to disable the whole system, I press the DSC button for 10 seconds. Yet when I do this, the "Brake" lights never come on, and I can't turn on DSC again. The little symbol stays lit. The only way to engage DSC again is by turning my car off then turning it on again. Anyone know what's up?
delta is offline   Reply With Quote
Old 11-30-2005, 06:17 PM   #2
van_basten
My Ride: M3
The 2-stage DSC started in the middle of 01' model. 328 has 1-stage DSC. As why you can't turn on DSC after you turn it off, that part I don't know.
van_basten is offline   Reply With Quote
Old 11-30-2005, 06:36 PM   #3
delta
Ahh I see. So when I press it, that means that its fully disabled?
Old 11-30-2005, 06:37 PM   #4
driftinsequence
My Ride: waiting to be modded
Send a message via AIM to driftinsequence
^^^ interesting, never noticed that when i drove my cousins bmw
driftinsequence is offline   Reply With Quote
Old 11-30-2005, 06:40 PM   #5
nameci
My Ride: bmw
my car does the same exact thing. i thought it was broken, but there must be a reason for it not being able to turn off. let me know if you find out.
nameci is offline   Reply With Quote
Old 11-30-2005, 08:05 PM   #6
jamenrock21
My Ride: 2004 325i jet black
04 325i
So if i hold my DCS button for 10 sec. it will turn if off completely. When i press it once the light turns on...what happens when you hold it for 10sec.
jamenrock21 is offline   Reply With Quote
Old 11-30-2005, 08:06 PM   #7
van_basten
My Ride: M3
Originally Posted by jamenrock21
04 325i
yellow brake light turns on
Old 11-30-2005, 08:10 PM   #8
jamenrock21
And what does that do to the car thats different? can you turn it back on?
Old 11-30-2005, 08:22 PM   #9
BmwMan325
My Ride: 2011 Infiniti G37s
04 325i
It also disables brake assist, turn the complete system off if you want to get the most wheel spin around corners or whatever, even lauching
BmwMan325 is offline   Reply With Quote
Old 11-30-2005, 08:50 PM   #10
delta
So for 2000 models, does it disable everything if just pressed once? Or there is no way to disable all systems on a 00' vehicle?
Old 11-30-2005, 09:06 PM   #11
jamenrock21
What does it do to the car when preses only once?
Old 11-30-2005, 10:26 PM   #12
BigBS1115
My Ride: 328Ci SP 5MT
Send a message via AIM to BigBS1115
My '00 328Ci does the same thing. When I press the button normally the DSC is turned off, but I can turn it back on again. When I hold the button in for 10 seconds and then release the light stays on and I am unable to turn DSC back on unless I restart the car. Must be like that on all 00's.
BigBS1115 is offline   Reply With Quote
Old 12-01-2005, 09:57 AM   #13
luckysnafu
My Ride: 03 ZHP|90 332(s52)
My '00 323i does the same thing as your car. I never get the yellow brake light to come on.
luckysnafu is offline   Reply With Quote
Old 12-01-2005, 10:13 AM   #14
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
Early cars, before mid 2001 production have the single stage DSC system (press the button once quickly and it shuts the system off). Starting around 01/01 production 2001s the system is two stage and requires that you hold the button for about 5 sec to turn the entire system off. If you have an after 01/01 production and you simply push the button without holding it only turns off the DSC and not the active braking (which is just as annoying).
Tim
tim330i is offline   Reply With Quote
Old 04-14-2008, 10:44 AM   #15
dblockboy
My Ride: 328ci
got the same problem with mine got a 328ci , so i tryed to make a little chirp when taking off in 1st and than a small chirp in second but nothing happens in 1st why? is the dsc not off or a sensor is broken or is it my clutch?
dblockboy is offline   Reply With Quote
Old 04-14-2008, 04:38 PM   #16
delta
Not enough power to chirp maybe, or you're launching too low? I never got to chirp my 328ci, but I had an auto. Now that I have a stick, I still can't chirp lol, awd ftl, but not really.
Old 04-14-2008, 08:48 PM   #17
dblockboy
My Ride: 328ci
i mean when i bought the car i tested it it chirped in 1st and second without any problems, not it doesnt even chirp in 1st when drop the clutch at 5000rpm. it wierd, my dsc light is on the dashboard. but i cant chirp it something is wrong it has to be . i got one question tho .
we 328ci owner yr.00 have stage 1 dsc which menas press the botton and it lights up it shut off the whole system right? when i press the botton again it shuts the light off
But my other question is , why is it when i hold the dsc botton for a longer period 10sec the light comes on and stays on , i cant turn it off anymore , only if i shut off the car and turn it on again. does that maybe mean than the whole system is off?
Old 04-14-2008, 09:03 PM   #18
Xeek
My Ride: 2000 328ci, 2010 328
Send a message via AIM to Xeek Send a message via Yahoo to Xeek
I have an 00 328Ci as well, you cannot turn it completly off on these models. I've tried to hold it down in the past and it did seem to stick on, it kinda felt like a bug. I turned the car off and on again and back to normal. I did find out the buttons on the consoles need a good press, its not bad, but sometimes I have to press the buttons with good pressure (not too much).
2000 BMW 328Ci
2010 BMW 328i LCI
Xeek is offline   Reply With Quote
Old 04-14-2008, 09:07 PM   #19
dblockboy
My Ride: 328ci
our models just have that one light right not the brake light also likes the 01 models, but how is it that i could chirp in 1st and 2nd before and now eventho i drop the clutch at 5000rpm it doesnt even do anythin in 1st , can you chirp in 1st and 2nd?
Old 04-15-2008, 04:50 AM   #20
dblockboy
My Ride: 328ci
why is it when i hold down the dsc for about 10 sec i cant shut off the light anymore, i have to restart the car for the light to shut off., but if i just press it quick the light comes on and press it quick again it shuts off? why is it like that?
