Old 12-04-2005, 03:07 PM   #1
phamman
My Ride: Dinan3 02 325CI
What is the brighest H7 bulbs without any blue or gold reflection?
Hello fanatics,
Just trying to find what is the brighest H7 bulbs out there, something that compares to our xenons. Since one of my bulb burned out, I figure now is a good time to upgrade my DRL, H7 bulbs.
Any suggestions on name brand, model and any vendors here that sell them.
TIA for your replies.
phamman is offline   Reply With Quote
Old 12-04-2005, 03:16 PM   #2
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
I love nokyas H7 bulbs... they are 8500K halogens but put out an almost xenon looking light... They will run you about 50 bucks a pair in the store or 35+ shipping on ebay...
If you can spend more, I have also heard good things about PIAAs plasma spark blue bulbs in terms of xenon look.. hwoever, they will run you about 100 bucks a pair
| 435 HP 328Ci | RRT Racing | Designer Wraps | Active Autowerke | Vorsteiner | STATUS Racing |
Timeless Motor Group
Old 12-04-2005, 03:22 PM   #3
phamman
2000_328CI, thanks for the quick reply, I just searched ebay and it seems that most of them have a blue or gold glass. Therefore it will have a reflection when someone looks at it head one. Do you know any other name brands that doesn't give a reflection.
Thanks.
Old 12-04-2005, 03:33 PM   #4
phamman
Piaa H7 Xtreme White Plus
PIAA H7 XTREME WHITE PLUS: I think these will work. From the picture, the glass is clear, but looks like there is a slight shade of blue. Anyone has these and knows if these will give off a reflection or not?
http://cgi.ebay.com/ebaymotors/PIAA-...QQcmdZViewItem
TIA
Old 12-04-2005, 03:39 PM   #5
2000_328CI
2000_328CI's Avatar
Thanks.
you will get the blue or gold look from pretty much every brand. Unless you get xenon bulbs, the company will have to tint the glass in order for you to get a bluish white look... I don't know of any companise that sell halogens capapble of blue light output that won't have the blue eyeball effect... oh and most people actually like the eyeball effect
Old 12-04-2005, 05:12 PM   #6
deutsch325
My Ride: xi
Hello fanatics,
First of all, no halogen even comes close to factory or aftermarket HID(in terms of intensity).
When you say "bright", do you mean higher color temperature(degrees kelvin) or higher light intensity(lumens)?
If you are looking for the best possible light output(lumens), then the answer is the Osram Silverstar H7 +50% halogen capsule; they were featured in a summer article of Roundel. Get them on ebay. The only problem with them is the color temperature is close to stock with slightly less yellow. I think they are rated just below 4000k.
If the color of the light is important to you, PIAA extreme white and sylvania silverstar will give you 4150K and 4000k respectively, both give off a noticebly whiter light.
If you don't do a lot of night driving and don't care about the reduced safety margin, you can easily find bulbs that give off a "xenon-like" color.
As for the color reflected by the bulb when off, heavily tinted ones or those with colored caps on the top will reflect that color during the day. If you want them to blend with the reflector, get bulbs with silver caps on top.
This is how the silverstar looks when off.(osram silverstar low beam, synvania silverstar high beam)
This is how the PIAA extreme white looks in my fog light.
deutsch325 is offline   Reply With Quote
Old 12-04-2005, 05:41 PM   #7
BlackChrome
No more E46 :(
BlackChrome's Avatar
My Ride: 2001 3.0L Ci
What he said.
I read the same article in Roundel and from all the graphs and testing, these have the highest lumens.
You can also purchasse them from Powerbulbs.com.
BlackChrome is offline   Reply With Quote
Old 12-04-2005, 06:42 PM   #8
phamman
thanks deutsch325 for the awesome explanations and links.
Old 12-04-2005, 06:51 PM   #9
deutsch325
My Ride: xi
no problem
Old 12-04-2005, 08:49 PM   #10
joe_323
My Ride: 323iT + MKII MR2
Here ya go - bright H7s
Hello fanatics,
Don't get the lame blue tinted bulbs. Adding tint to bulbs makes them DIMMER. Yellow tinting also makes them dimmer, but this tint has its uses for fog lights.
Also note that as the H7 bulbs (or any incandescent bulbs) age they slowly build up a film on the glass that makes them both dimmer and yellower. The so called "xenon" halogen bulbs use xenon gas to slow this process, not to actually create light the way HID bulbs do.
From http://www.danielsternlighting.com/p.../products.html
H7 bulbs
* 55W Ultra High Efficacy Plus 50 (Narva RangePower+50, Osram Silverstar, Philips VisionPlus or Tungsram Megalicht*): $17.50/ea
* 65W Osram Ultra High Output (2100 lumen, H9 burner on H7 base, race and special-purpose use): $24.00/ea
joe_323 is offline   Reply With Quote
Old 12-04-2005, 10:42 PM   #11
THATS FRESH
My Ride: SSHNIPER
Send a message via AIM to THATS FRESH
and how do you order from them ^^?
THATS FRESH is offline   Reply With Quote
Old 12-04-2005, 11:20 PM   #12
deutsch325
My Ride: xi
I was intrigued by reading the above post describing the H7 65 watt Osram high output bulb, but 500 hours seems like a very short life.. Maybe it's worth it for the +80% output.
BTW the 55 watt H7 Osram Silverstar +50% bulbs are on sale right now on ebay for $30 per pair(there is only one seller who carries this bulb, he's legit.) http://cgi.ebay.com/ebaymotors/OSRAM...QQcmdZViewItem
He sells the 65 watt too, it's $50
Old 12-05-2005, 09:32 AM   #13
joe_323
dastern@torque.net
Tell him what you want and he will reply. I don't know why they don't have a shopping cart or something. I want a set of the 65 watt bulbs myself. I don't see anything about a short lifespan. These are really H9 bulbs on H7 bases. Here is a description of the H9s and they don't mention a 500 hour lifespan and are used in some new cars as OEM headlights. I guess the "extremely white light color" maybe a clue to a shorter lifespan. If you run the bulbs hotter you get more light and a higher color temperature. Maybe I will just do highbeams with these and lowbeams with the +50s. BTW, don't bother with the GE high output H7s. I got one to replace a blown lowbeam and it mainly just distorts the pattern of the light. Waste of $12
These new single-filament 65w bulbs are rapidly gaining popularity amongst automakers for use primarily in high-beam headlamps, often in conjunction with H11 bulbs for the low beams. H9 is an extremely high output design (2100 lumens) with an extremely white light color. As with H8 and H11, these are currently tough to find in the aftermarket.
Old 12-05-2005, 04:39 PM   #14
Staszek
Are we there yet??
Staszek's Avatar
My Ride: Now a daily drive
Send a message via AIM to Staszek
Originally Posted by BlackChrome
What he said.
You are correct the Silverstars (euro version) have the best lumens out of any H7 Halogens I have seen to date.
Do not get the American Version they have the blue coating. Do not get any bulb with a color coating on them, you loose Lumens I dont care what the marketing says.
Euro Delivery Thread
///M3-6MT:dance:
Staszek is offline   Reply With Quote
Old 08-19-2006, 10:05 AM   #15
Porterhouse
My Ride: '99 323i 5spd
Ive been looking at the Osram Cool Blue and SilverStar bulbs for a while now and I can't seem to find what the Color Temp is for the Osram SilverStars. I've found that the Cool Blues are 4000k, and the Sylvania "SilverStar is up to 4000K". Both of these 4000k bulbs have a blue coating, which I don't really want. Also does anyone know the temp of the SPP Superwhites?
"A fanatic is one who can't change his mind and won't change the subject." - Sir Winston Churchill
Porterhouse is offline   Reply With Quote
Old 08-19-2006, 11:39 AM   #16
franz
My Ride: 03 330i
I have some really nice Phillips VisionPlus that I picked up in Germany, they are 50% more light and still 55w, no tint to them at all. I would sell them for $30 shipped because I can't use them in my car. They have never been out of the box.
franz is offline   Reply With Quote
Old 08-19-2006, 01:14 PM   #17
easyman
My Ride: MKV GTI 4 Door
anyone know if they sell these bulbs in a 9006 size
2007 GTI 4 Door (MKV)- Current
2010 Acura TSX (cu2) - Retired
1987 BMW 325i (e30) Vert - Burned Down
2002 330i (e46) - Retired
ZPP - ZCW - ZSP - Nav - Bi-Xenon/85122+ - Mtech - 18" CSL - FSD's - 4300k Fogs-
Sig courtesy of fskarboe
easyman is offline   Reply With Quote
Old 08-19-2006, 05:35 PM   #18
dmblongo
My Ride: 01 330i
same question..this post ws started a year ago...just looking to see what the best and brighest is now?? any suggestions
dmblongo is offline   Reply With Quote
