Old 12-05-2005, 01:02 AM   #1
shsiao
My Ride: 2001 E46 330CI
Talking How to replace my trunk?
Hi fanatics fellows,
My car is 2001 330CI and I want to replace my OEM trunk with a replica CSL trunk. Can anyone guide me on the trunk removal procedure?
shsiao is offline   Reply With Quote
Old 12-05-2005, 01:18 AM   #2
daytonaviolet
My Ride: 2004 M3
Send a message via AIM to daytonaviolet Send a message via MSN to daytonaviolet Send a message via Yahoo to daytonaviolet
1) remove carpet kit
2) remove all lights and wiring
3) remove latch and key mechanism
4) remove the upper shocks and rubber stoppers
5) remove 4 bolts which hold down bootlid
now.. install the new bootlid in the reverse order.
depending on which replica you have.. you will have to dremel the following areas.
1) area for key mechanism - the CF/FG is too thick .. thin it out
2) area for reverse lights - the CF/FG is too thick .. thin it out
3) area for rubber stuppers - the CF/FG is too thick .. thin it out
4) area for carpet push pins - the holes are too small .. make it bigger
5) area for tool kit - cut out a square hole, then dremel the oem plastic square. make the the gaps bigger.
daytonaviolet is offline   Reply With Quote
Old 12-05-2005, 03:14 AM   #3
shsiao
Thumbs Up
Thank you!!
I will find a sunny day to do this and perhaps, I will have some pics to you fellows
Old 12-05-2005, 03:25 AM   #4
daytonaviolet
My Ride: 2004 M3
Thank you!!
good luck if this is your first time.. it may take up to 8hours or more so plan accordingly
Old 12-05-2005, 03:34 AM   #5
BMWintoxication
Taiwan/Vancouver/Shanghai
My Ride: Jet Black02' 325ci
Send a message via AIM to BMWintoxication Send a message via MSN to BMWintoxication
a DIY write up of this would be cool.. TIA
Orz
BMWintoxication is offline   Reply With Quote
Old 12-05-2005, 12:14 PM   #6
daytonaviolet
My Ride: 2004 M3
i have another bootlid install coming soon. i'll take pics this time
