Old 12-05-2005, 01:30 PM   #1
wrooster
My Ride: 1999 323i / E46
voltage regulator HOW-TO? anyone done it?
folks,
looking to replace the voltage regulator module on my 1999 e46 323i sedan.
anyone done this?
from http://www.realoem.com/bmw/ ...
VOLTAGE REGULATOR BOSCH 1 12311713491 $111.32
thanks
jim / wrooster
ps:
my symptom is a very slight dimming of headlights when driving. car starts fine, just this morning it was about 20'F outside and no problem getting going.
wrooster is offline   Reply With Quote
Old 12-05-2005, 06:33 PM   #2
K:^P
My Ride: 00 323//65 Fastback
The regulator is on the alternator. Most of the time if the regulator is bad, it would over charge. You can simply check the voltage by attaching a voltmeter to the battery while the car is running. Reading 14v-15v would good. Below 12v, not good. 18v, not good either.
The alternator is held by two bolts, I believe one of them is at the idle pulley. Have not done it, but heard it's not that differcult.
K:^P is offline   Reply With Quote
