Old 12-06-2005, 05:54 PM   #1
langxjai
My Ride: 2000 323i
need help w/ trim/door removal 2000 323i
can someone point me to a do it yourself for removing a door off a 2k 323i i had all my side moldings painted and when i got the car back there's a rattle in the door so i need help removing the door panel so i can get into the inside of the door to fix the rattle....thanks
langxjai is offline   Reply With Quote
Old 12-06-2005, 09:52 PM   #2
bimmer07
Banned
bimmer07's Avatar
My Ride: //////////M
Send a message via AIM to bimmer07
its as simple as using a tork screw driver 20 i believe removing the trim then the 2 screws behind that, under the armrest there are 2 screws in the armrest. and then you have to pop off the window up/down control and unscrew the screw there. Then all you have to do is pull it off. It takes some work and you can't break the clips very easily.
bimmer07 is offline   Reply With Quote
