Go Back   E46Fanatics > Tuning & Tech > Bavarian Soundwerks' Mobile Electronics Forum
Sponsored by Bavarian Soundwerks
Old 06-07-2006, 03:50 PM   #61
guest0202
Banned User
My Ride: Car or Truck
UGH I still cant figure out how to take off the sedan door panel
guest0202 is offline   Reply With Quote
Old 06-07-2006, 04:13 PM   #62
SrCsTc
Banned
My Ride: 00 323Ci
Send a message via AIM to SrCsTc
You still can't figure out how to search either.
http://www.e46fanatics.com/howto/how...hp?howto_id=27
SrCsTc is offline   Reply With Quote
Old 12-11-2006, 02:15 AM   #63
big_ham
My Ride: 330Ci
I'm new to German autosound, but not to Car Stereo
Has anyone ever taken the time/effort to harden the interior door panel with fiberglass or similar, then build a pod around the speaker (still attached to the panel) with an AP mat at the back? This should yield low resonance and decent low frequency response through the use of the mat.
I really want to put something better than stock into my car, but I just can't bring myself to cut her up so soon ...
big_ham is offline   Reply With Quote
Old 12-11-2006, 09:13 AM   #64
ca1242
My Ride: 2003 330i
I have done this in the past, but not on E46s. Results would vary depending on speaker you use. Most speakers are designed for free air operation, so they work relatively well using the door cavity as an enclosure.
Old 12-11-2006, 10:32 AM   #65
bigjae1976
bigjae1976's Avatar
My Ride: A car
The door panel is held in place with 5 screws and a bunch of plastic clips. I would think that you would have to devise a way to securely mount the panel to the door. As it is, you are limited by the plastic clips that hold the door panel down near the speaker.
You could make the door panel a much sturdier surface if you could find a really strong friction fitting.
Not to mention that you don't have a lot of mounting depth.
You could mount the speaker on the front side of the door panel and modify the panel to get more depth.
Old 12-18-2006, 04:40 PM   #66
alpina527
My Ride: E46 M3
Could the tubes be made from billet aluminium, machined to size, and with some matting in the bore?
alpina527 is offline   Reply With Quote
Old 12-18-2006, 09:14 PM   #67
ca1242
My Ride: 2003 330i
I don't see why not. The only problem is that the door metal is an irregular surface. Wood is easy to grind to shape it, but aluminum is a bit harder.
Old 02-20-2007, 05:59 PM   #68
flightz71
My Ride: 04 330ci coupe
bumping an awesome thread.
So if i were to buy the rings...what size would i need for a coupe (i'm thinking of putting in Focal K2P's). How many rings, how thick each of them need to be, and inner and outer diameter of each ring?
Thanks in advance!
-Calvin
flightz71 is offline   Reply With Quote
Old 02-20-2007, 09:29 PM   #69
ca1242
My Ride: 2003 330i
Thanks in advance!
-Calvin
You can make them yourself! Inner diameter depends on the speaker size. Outer diameter depends on inner diameter (I usually make it about 5/8" wide, you can probably get a way with 1/2" is the speaker is fairly large. How many also depends on the speaker. If your speaker is for example 2-1/4" deep, the you would need 5 rings @ 1/2" thick
Old 02-21-2007, 04:27 AM   #70
bigjae1976
bigjae1976's Avatar
My Ride: A car
I wouldn't make the rings thicker than 1/2" or less than 1/2" wide with MDF. I ended up splitting the rings even after I drilled pilot holes.
Old 03-29-2007, 05:40 PM   #71
DarXide
DarXide's Avatar
My Ride: Slammed on F2's
Send a message via AIM to DarXide Send a message via MSN to DarXide
What would u guys recommend to cut the doors?
I don't wanna even try with the dremel it seems too weak but its all I got..
Any input?
Anybody that did it with a dremel?
TIA
-Al
FS 20'' Avus 3 piece wheels with tires 80% thread $2,000 + shipping
FS Brembo BBK 4 Piston 380mm front 345mm rear (silver) $3,800 + shipping
DarXide is offline   Reply With Quote
Old 03-29-2007, 05:45 PM   #72
330cia
330cia's Avatar
My Ride: M3
Is there any way to install speakers using the stock bracket without cutting the hole?
-Anton
330cia is offline   Reply With Quote
Old 03-29-2007, 06:26 PM   #73
boce
My Ride: 2002 325i
This being a sedan, is one 3/4" thick ring enough to allow the speaker to sit flush with the door panel?
boce is offline   Reply With Quote
Old 03-30-2007, 02:12 AM   #74
bigjae1976
bigjae1976's Avatar
My Ride: A car
Any input?
TIA
-Al
I recommend using a diamond cutoff wheel for a dremel or a small diameter angle grinder wheel. The diamond dremel wheel is about $15 but it will cut the metal. It will give you a good amount of control as well.
Tin snips work but you have to be careful not to twist the metal if you have a coupe/vert.
If you watched too much Home Improvement...go with the reciprocating saw.
The stock speaker is 6", not a 6.5" so the stock ring won't fit most speakers. The only true 6" speaker that is common available is the Diamond Audio Hex 6" mid.
Otherwise, you'll need to create some sort of mounting ring which is not hard to do.
Depends on the depth of the speaker. You'll probably need to cut enough rings to equal the depth of the speaker.
Old 03-30-2007, 06:58 AM   #75
ca1242
My Ride: 2003 330i
I use tin snips.You could do a dremel with fibeglass cutoff wheels, but you would go through several wheels and would take a while.
Any input?
TIA
-Al
Old 03-30-2007, 08:52 AM   #76
dan4081
My Ride: 2000 323i
With my (shallow) speakers, one 3/4" wasnt enough. The magnet hit the glass when the window rolled down. If I remember right (been a long time) I ended up with about 1.5" in rings
dan4081 is offline   Reply With Quote
Old 03-30-2007, 08:53 AM   #77
dan4081
My Ride: 2000 323i
Any input?
TIA
-Al
I used a jig saw. Just hold it tight against the door, use a metal blade of course, and take your time. I drilled a big hole to start the blade. And make sure you have a few blades to start.
Old 03-30-2007, 09:00 AM   #78
ca1242
My Ride: 2003 330i
You do have to be careful on coupes - don't want to cut the window rail behind. No problems on sedans.
Old 03-30-2007, 09:24 AM   #79
Timbo126
My Ride: 2004 330xi
Hey ca1242 would you be willing to do this install for other people. I go to school in FL right now but ill be home this summer and I live in Damascus MD. I am looking for a speaker instlal like this.
Tim
Timbo126 is offline   Reply With Quote
Old 03-30-2007, 09:31 AM   #80
dan4081
My Ride: 2000 323i
Good catch there! I do have a sedan.
