Sponsored by The Tire Rack
Old 12-08-2005, 11:20 AM   #1
wolfe4life
My Ride: 2002 330I
Bad tire, Bad Wheel, Bad Valve stem?
Need help in figuring out what could be the problem! Have one tire that leaks 1 to 3 pounds of air a day. Had the tire checked for damage, none. Had it checked for nails, none. Had it filled to 55lbs and submerged in water, NOTHING, No LEAKS at ALL! Next step is to have it demounted and the valve stem checked and the wheel for damage.
Any suggestions or have anyone else experience this problem?
wolfe4life is offline   Reply With Quote
Old 12-08-2005, 02:50 PM   #2
dave12345
My Ride: 2003 ///M3 6MT
dude i got the same prob..... except i lose 2lbs a day
im startin to think slightly bent wheel
2003 BMW ///M3
Carbon Black/Cinnamon 6MT
dave12345 is offline   Reply With Quote
Old 12-08-2005, 03:53 PM   #3
byunts
My Ride: '06 330i
Try this when you have a chance. Get a bucket of soapy water. With a sponge or cloth, apply soapy water to your wheel/tire section by section. Look for bubbles carefully. You'll eventually find the leak.
byunts is offline   Reply With Quote
Old 12-08-2005, 04:46 PM   #4
BLK328Ci
My Ride: 2000 Black 328Ci
Send a message via AIM to BLK328Ci Send a message via Yahoo to BLK328Ci
I have the same problem. didnt know that my tire was getting flat, I had the inner side of my side walls pop'n out in two places. one was 12-14in long and stuck out about 3in and the other was about 6in and stuck out 2in. I would like some help as well.
BLK328Ci is offline   Reply With Quote
Old 12-08-2005, 05:54 PM   #5
ttenneb88
My Ride: S54B32 & EJ205
Leak could be happening under load. Just have the tire remounted and hope that fixes it.
06' M3 Alpine White / Cinnamon
Mods:Dixis Ti Exhaust, Rogue Rasp Pipe, Rogue SSK w/ WSR, UUC Tranny Mount Enforcer, AFE CAI, TMS Pulleys, TMS Rear Subframe Reinforcement Kit, TMS Rear Camber Arms, Powerflex RTABs, Brembo 355 BBK, 19" RACMonolites RG4s, 18" RACMonolites RS110s, Sharked...
ttenneb88 is offline   Reply With Quote
Old 12-09-2005, 08:32 AM   #6
wolfe4life
My Ride: 2002 330I
FOUND PROBLEM... After an hour of letting the wheel and tire soak in water at 55lbs of pressure, the dirt finally came out of the needle pin HOLE that was in the WHEEL and the bubbles began. Sending wheel back for new one today. Thanks to the Guys at DELTA WORLD TIRE in Gulfport MS for finding the problem.
Old 12-09-2005, 10:48 AM   #7
dave12345
how old was your wheel the one thats leaking i just bought mid july and its been leaking for 3 weeks now
2003 BMW ///M3
Old 12-09-2005, 11:34 AM   #8
wolfe4life
My Ride: 2002 330I
Had them on the car 5 Days.. Has to be a Factory Defect...
