Old 12-08-2005, 11:53 AM   #1
nicdog
My Ride: 2002 330Ci
engine cover removal
hey, i searched but couldnt find it...how do i remove my engine cover on 330 ci to see if i have bremi or bosch coils for the recall...dealership said recall started with 03 but i know it started with 02 models. please help. thanks
nicdog is offline   Reply With Quote
Old 12-08-2005, 01:20 PM   #2
leej323
leej323's Avatar
My Ride: '00 323i
You start out by removing your microfilter housing. It makes reaching the back nut/bolt much easier.
To take out your microfilter, there's 3 twist knobs that keep it secure under the plastic shield. Don't twist too hard, it only takes about a half turn to get them loose. Also, they aren't meant to come out of the holes, so don't keep twisting.
Once you have those knobs loose, the plastic cover should pop up. Take out your microfilter and completely remove the plastic cover by gently pulling outwards. This will expose 4 star screws at the back, which secure the bottom part of the shield to the car. Once you remove those 4 screws, you can take out that entire bottom piece.
There are 4 bolts/nuts securing the engine covers (there's two different ones). Your coils are under the left engine cover, while your fuel rail/injectors are under the right engine cover. The bolts/nuts are under plastic pieces that first need to be removed with a flathead screwdriver. All the bolts/nuts you'll remove using a 10mm adapter.
Hope this helps.
leej323 is offline   Reply With Quote
Old 12-08-2005, 10:47 PM   #3
TitanSilber ZHP
TitanSilber ZHP's Avatar
My Ride: 08 E90 335i
Send a message via AIM to TitanSilber ZHP Send a message via Yahoo to TitanSilber ZHP
Hope this helps.
Skip the "bold" and squeeze a low-pro socket in there.
| Andrew | M Technik | BMW Performance | 3M | V1 | LUX 5.0 | Bilstein PSS9 | Precision-Sport |
FS: Camera Mount:http://forum.e46fanatics.com/showthread.php?t=694858
TitanSilber ZHP is offline   Reply With Quote
Old 12-09-2005, 12:04 AM   #4
leej323
leej323's Avatar
My Ride: '00 323i
A lot easier with the microfilter housing out of the way. Especially when it comes time to replace your spark plugs or coils. But it does save some time if you leave it there. Whatever floats your boat.
Old 12-10-2005, 11:18 AM   #5
nicdog
My Ride: 2002 330Ci
thanks bros...i also called the dealer and was told the recall started with 03 models...not true since my buddy's recall said 02, 03 and 04. I wanna check for myself.
Old 12-10-2005, 12:40 PM   #6
TitanSilber ZHP
Of course its easier to access plugs, ect with it out of the way, Im just lazy
Old 12-10-2005, 01:35 PM   #7
leej323
leej323's Avatar
My Ride: '00 323i
lol, lazy@$$!
