Old 12-09-2005, 07:04 PM   #1
Ali Baba
My Ride: 2005 CLK 320
****Disconnecting My Battery!****
alright i want to disconnect the battery on my 2005 clk 320 because the radio/cd player stopped working and i want to reset it. i can't find the fuse for the stereo or amp or anything so i was going to just disconnect the battery and reconnect it... i wanted to know if this will be safe.
This is the whole battery
Image hosted by Photobucket.com
this is the negative terminal on the battery
this is the positive terminal
Which one should i disconnect... and can i use just a regular socket wrench to take this off?
Thanks in advance.
Ali Baba is offline   Reply With Quote
Old 12-09-2005, 07:18 PM   #2
Nico3k
The R1 makes it fun
My Ride: Yamaha R1 + 325i
disconnect the positive, and yes you can use a regular socket... just make sure you dont touch the frame or anything (ground)
Nico3k is offline   Reply With Quote
Old 12-09-2005, 09:02 PM   #3
voerman
My Ride: 06 MZ4, 06 325XI
Disconnect the NEGATIVE
Always disconnect the negative battery lead. It is much safer than disconnecting the positive because of the potential for your wrench or socket to contact ground - shorting the battery. I know of a guy who lost a finger because his wedding ring came between a socket he was using on the positive terminal and ground (with the negative still connected).
To repeat - always disconnect the negative lead. If you need to disconnect both, do the negative first then the positive. When reconnecting do the positive first, then the negative.
Lou
voerman is offline   Reply With Quote
Old 12-09-2005, 09:05 PM   #4
xmltok
My Ride: 2014 Carrera 4S
Send a message via AIM to xmltok
lol the positive
xmltok is offline   Reply With Quote
Old 12-09-2005, 09:05 PM   #5
BlumberB18
/// YoU LoOsE
BlumberB18's Avatar
My Ride: Fast E Fourty 6
Send a message via AIM to BlumberB18
NEGATIVE! - Black one
~* UNDER CONSTRUSTION *~
BlumberB18 is offline   Reply With Quote
Old 12-10-2005, 01:04 AM   #6
niL
is on da floor
niL's Avatar
My Ride: 2001 330i
Send a message via AIM to niL
Lou
i 110% agree! i had this happen to me with a tool before however it was insulated, just a slight burn on my finger! always disconnect negative first!
2001 330i rebuilt from the salvage yard
From start to finish...
niL is offline   Reply With Quote
Old 12-10-2005, 01:17 AM   #7
TravsM3
TravsM3's Avatar
My Ride: 05' 545i, ZSP
TravsM3 is offline   Reply With Quote
Old 12-10-2005, 01:26 AM   #8
Gir
My Ride: .
Lou
Fvcking negative.
Gir is offline   Reply With Quote
Old 12-10-2005, 01:46 AM   #9
Cobra
My Ride: '00 328i & '06 R6S
interesting, i never knew this...
i didn't pay much attention in science class, so can someone explain to me why you should disconnect the negative first(i know so it doesn't shock you, but why?)?
and what exactly is a "ground"?
Cobra is offline   Reply With Quote
Old 12-10-2005, 02:35 AM   #10
Lexie330ci
ILCUTAWOOTIE
Lexie330ci's Avatar
My Ride: 330ci
Send a message via AIM to Lexie330ci
disconnect the one with the minus sign
Need brakes? Bother Anthony Here!
Lexie330ci is offline   Reply With Quote
Old 12-10-2005, 08:56 AM   #11
voerman
I'll try to make up for your not paying attention in science class.
The negative terminal of you battery is connected to the chassis of the car. This referred to as a "negative ground" system. Almost all car manufacturers do this (there were a few positive ground cars but they are old and very hard to find).
So - almost any bare metal in your car will be connected to the negative terminal of your battery. The effect of this is that if you use a wrench on the positive battery terminal (with the negative still connected) and it touches any bare metal, you will short the battery through the wrench. This is extremely dangerous since the battery can provide a large amount of current. The wrench will get very hot and could seriously burn you. In the worst case, the battery could explode.
If you have a wrench on the negative terminal and it touches bare metal, no harm is done since the negative terminal is already connected to ground. So when working on your battery, disconnect the negative terminal first and make sure the cable you remove can't accidently make contact with the negative terminal.
Lou
Old 12-14-2005, 01:49 PM   #12
FlzRider
My Ride: AW 1M
Lou
Everything made sense here except for the end, did you mean to say "and make sure the cable you remove can't accidently make contact with the *POSITIVE* terminal."?
FlzRider is offline   Reply With Quote
Old 12-14-2005, 02:10 PM   #13
Nuori
_
Nuori's Avatar
My Ride: A 323 mule pepe
I was like my battery terminal doesn't look like that, but then I noticed it's a Mercedes and NOT a BMW.
So, by now you should know to disconnect the negative first.
Nuori is offline   Reply With Quote
Old 12-15-2005, 08:26 AM   #14
voerman
I meant the NEGATIVE terminal. The wire is fairly stiff and will try to "return" to the terminal after it is disconnected. I usually wedge it behind or under something so it can't accidently make contact with the negative terminal. If it did, and you didn't notice, it could ruin your day.
Lou
Old 01-01-2008, 02:17 PM   #15
BMW04E46
My Ride: 2004 325Ci SMG
i always forget which one has to be disconnected first LOL, thanks!
2005 Acura TL A-Spec
2004 325Ci SMG M-tech II (Sold and got 2005 Acura TL A-Spec) :-(
2002 530i Sport
1997 Mercedes Benz C280 Sport (Sold and got 2002 530i Sport!) :-)
2007 Yamaha VX Cruiser (WaveRunner)
see my garage for pics
How a Rogue IKON should look on a M-Tech II Coupe
http://forum.e46fanatics.com/showthread.php?t=537372
BMW04E46 is offline   Reply With Quote
Old 01-01-2008, 03:33 PM   #16
Xcelratr
My Ride: 04 330Ci ZHP
It would also be bad for the Negative cable to make contact with the Positive terminal. However, as Lou indicated, the cables are pretty stiff and there usually isn't a lot of slack in them, so it would be difficult for the Negative cable to accidentaly reach the Positive terminal.
But if the Negative cable isn't pinned out of the way as Lou described (or sheathed with an insulator, or the terminal is covered) it's actually likely to "wander" back and lay against the Negative terminal, re-closing the circuit. If you start to do some work on the car, the realization that there IS, in fact, electricity being supplied by the battery circuit (when you thought there wasn't) is often surprisingly painful and impressively destructive.
We will not tolerate intolerance.
Xcelratr is offline   Reply With Quote
