Old 12-16-2005, 12:33 PM   #1
BimmerDoc
My Ride: E46 AWD, ///M Coupe
Send a message via AIM to BimmerDoc
Stuck bolts
What is the best way to loosen a bolt that I can not get off with a socket, I want to take my seats out but it seems like they are tourqed too hard
BimmerDoc is offline   Reply With Quote
Old 12-16-2005, 12:41 PM   #2
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
Get some PB Balaster from AutoZone (or other automotive parts store). Otherwise get an extension for your socket.
Tim
tim330i is offline   Reply With Quote
Old 12-16-2005, 12:44 PM   #3
Pigeon
My Ride: 02 ///M3 & 06 750Li
Assuming you're turning them the right way you'll probably need a breaker bar - a longer non-ratcheting wrench you attach the socket to. You can also slip a short length of pipe over the end of the ratchet to give yourself more leverage. Once you break them loose they come out easy. If all else fails, put lots of protection (rags) around the area and use a penetrating oil like PB Blaster - it stinks something awful but will work to loosen rusted/stuck bolts.
Just be very careful reinstalling them; they're easy to cross-thread - don't ask how I know...
Scott
edit- Tim beat me to it but it's the same advice - use leverage first and then PB Blaster second.
Pigeon is offline   Reply With Quote
Old 12-16-2005, 01:05 PM   #4
ca1242
My Ride: 2003 330i
You could also use some WD40 if you have some in the house. That's what I normally use for loosening bolts.
Old 12-16-2005, 02:23 PM   #5
WishIHadAStick
My Ride: 2003 330xi
Sounds like you just need to get a longer ratchet. They shouldn't be rusted down or anything, but some penetrating oil woulnd't hurt.
WishIHadAStick is offline   Reply With Quote
Old 12-17-2005, 08:36 PM   #6
Ejonezee
My Ride: '02 330 CI
Impact Driver
http://buy1.snapon.com/catalog/item....store&tool=all
Ejonezee is offline   Reply With Quote
