Old 12-17-2005, 01:09 PM   #1
Erick Sermon
My Ride: 2000 323Ci
Stock Radio - Business
I just removed mine. Hot damn the wires were very tight and I had to pull quite a bit to get the headunit out far enough to remove the harness.
For those who have removed their HU before. Is your wiring like that as well? Like there was no slack at all.
Another question...the harness has a bunch of wires coming from 2 looms. The top which has a thick loom with a tone of wires. The bottom is thinner and has an angled plug, that almost looks like a serial port on a computer.
When I applied pressure to that wiring loom, my speakers cut in and out...which is a problem I have intermittently. What is that bottom plug / wires exactly?
Erick Sermon is offline   Reply With Quote
Old 12-17-2005, 03:10 PM   #2
Canuck328i
My Ride: 09 Altima Cpe
The top one is for the power and signal, the bottom one is the CD changer cable to the trunk. And my cables had enough slack for the whole radio to basically come all the way out of the dash.
Mark
Canuck328i is offline   Reply With Quote
Old 12-18-2005, 12:37 AM   #3
Erick Sermon
My Ride: 2000 323Ci
Can I tug on the wiring to pull it forward a little. It is really short.
Its wierd that when I jiggle around the CD changer wiring, my speakers cut out on the one side. I guess, its cutting the input to the deck on the one side?
Old 12-18-2005, 05:10 PM   #4
Canuck328i
So is it cutting out on all sources or just CD? If it is just the CD, yeah for sure it could be that smaller connector (either the wire connector or the solder connections in the deck). Actually I had a eft channel problem with my changer but the problem was actually in the changer itself.
Mark
Old 12-18-2005, 06:27 PM   #5
gsxr mixxer
Wish it was an M3
gsxr mixxer's Avatar
My Ride: 03, 325i
connections. thats probably it...
Daily Driver
gsxr mixxer is offline   Reply With Quote
