Oil light comes on after oil change? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-05-2006, 08:51 PM   #1
tanev
My Ride: 2005 BMW 325i
Question Oil light comes on after oil change?
Hi,
I recently changed my oil using the posted DYI here as well as the info in my Bentley manual. I drained the old oil and added 6 qt of new BMW 5W-30 Synthetic oil. I also changed the oil filter, gaskets as described. I don't have any oil leak after the change. My oil level is close to the full line (should have added 5.5 qts) but not above it. The problem that I have now is that now and then AFTER I turn the ignition swith off and remove the key my oil warning light comes on for few seconds and then dissapears. No warning light comes when I trun the ignition on or while driving. Does anybody knows what causes this?
Thanks,
Peter
2005 BMW 325i, ZPP, ZSP, Retrofits: M3 SMG Steering wheel with paddleshift, OEM Bi-xenons +High beam+ Autoleveling, Predator Chromium, OEM (16:9/MKIV) Navigation, OEM TV/Video Module/Option, Assist/Bluetooth+ Voice Input Control, Universal Tranceiver, OEM Alarm, Alpine CHA-634 6CD/MP3 Changer, OEM Rear Side and Manually Retractable Rear Window Sunshades, Myrtle Wood emergency brake handle, OEM rear lip spoiler.
tanev is offline   Reply With Quote
Old 01-05-2006, 09:29 PM   #2
KevinB
My Ride: Silver 2002 330i
I have a 330i and the engine requires closer to 7 qts of oil. Does yours only take 6, or was that the mistake? Just my 2 cents
KevinB is offline   Reply With Quote
Old 01-05-2006, 10:03 PM   #3
rooneym
My Ride: 2001 E46 325I
Send a message via AIM to rooneym
Yellow oil light means the oil level is low. However, if you do have enough oil in the pan and the light still comes on, the oil level sensor is probably broken
rooneym is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-06-2006, 11:04 AM   #4
tanev
there is some residual oil left in the system when you darin it6. Therefore, it is not uncommon to add between 5.5- 7.0 qts during oil change. My oil level is close to the full mark.
The kick is that the light comes only sometimes after Iturn the ignition switch off and stays for few seconds and then goes off?
Old 01-06-2006, 03:38 PM   #5
Dev
PSHOPWERKS
My Ride: Yellow Porsche GT2
Same issue here.
PSHOPWERKS
Mods: 1 Inch Nail in Tire | Purple painted calipers (you know you like Purple calipers)
Current Hate Level: 10 | Previous Hate Level: 9
The hatin' level on the E46Fanatics.com board.
Dev is offline   Reply With Quote
Old 01-10-2006, 12:22 AM   #6
KingCC
My Ride: 1999 328i
I just purchased my car and i'm having the same problem.... i recently changed the oil.. The yellow oil light will come on and then back off again within a few seconds. I asked the dealer why this happens and he told me that its waiting for the oil to warm up, but for some reason i really don't believe that.
KingCC is offline   Reply With Quote
Old 01-10-2006, 11:24 AM   #7
deletedpenguin
deletedpenguin's Avatar
My Ride: is gone!
Mine has been coming on for a few seconds as well. I have an oil sensor that needs replacing. $150 or so.
Stefan | American by birth, Swedish by heritage, Australian by choice.
My current photo galleries.
deletedpenguin is offline   Reply With Quote
Old 01-10-2006, 11:55 AM   #8
EIAlfonso
My Ride: 2011 535xi M Sport
Maybe he thinks you own an M3, the tach lights yellow until the oil is warmed up, another stealer genius.
It's probably the low oil level sensor, $100 for the part and if you can get underneath your car it would be an easy DIY on your next oil change.
EIAlfonso is offline   Reply With Quote
Old 01-10-2006, 12:19 PM   #9
hummer
My Ride: 2001 330CI
Could also be a faulty dip stick. Don't laugh, it's happened.
Fill the engine with the proper number of quarts and then look at the dip stick to see if it's reading correctly.
Old 01-10-2006, 11:30 PM   #10
tanev
Thank you. I will be taking it to stealership soon for other items and would ask them to address this one.
Will let you know what explanation/remedy they offer for the problem.
Peter
