Old 01-06-2006, 12:18 PM   #1
benzfreak
My Ride: my ride
How to clean engine?
I was wondering how would I go about cleaning my egnine area?
Right now since I don't know anything I am just using a damp towel to wipe down dirty areas.
any real ways of cleaning it?
Life, the only thing worth dying for.
benzfreak is offline   Reply With Quote
Old 01-06-2006, 01:09 PM   #2
leej323
leej323's Avatar
My Ride: '00 323i
You can buy an engine degreaser spray. Basically you just warm up your car, turn it off, then spray the dirty or greasy areas down with the degreaser. Then use a spray bottle and spray water over the same areas. Let your car dry and you're done.
I picked some up from the local AutoZone a couple weeks ago.
leej323 is offline   Reply With Quote
Old 01-06-2006, 01:18 PM   #3
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
does the above info really work? Seems like it might hurt or corrode stuff Also, would that be a bad idea given I have the ECIS intake which is very open?
Timeless Motor Group
Old 01-06-2006, 01:29 PM   #4
kpeng
Banned User
My Ride: E46 330 and E30 325
By far the best method I have found, and one that would not be risky enough to possibly cause harm to your electronics is to just take a damp terry cloth and wipe down the engine bay. Then go over it again with a dry one. After that, take an applicator pad and apply some Black Magic Trim Shine Gel all over it. Makes it look as good as new.
-Ken
kpeng is offline   Reply With Quote
Old 01-06-2006, 02:12 PM   #5
leej323
leej323's Avatar
My Ride: '00 323i
Yeah, it works. I don't use it on my bimmer, though.
It's contains/is made from a petroleum distillate... so I believe it only reacts with grease.
The directions on the can say to avoid intake openings.
Old 01-06-2006, 02:13 PM   #6
russ330
Mod Squad
russ330's Avatar
My Ride: Motorsport III
Send a message via AIM to russ330
http://forum.e46fanatics.com/showthr...&threadid=7086
russ330 is offline   Reply With Quote
