Sponsored by BAVSOUND
Old 10-02-2002, 08:16 AM   #1
GhostRider
...and I'd be all shiny..
My Ride: 2001 Dinan 3, 5sp
Optima Yellow top battery
Does anyone know if the Optima Yellow top battery fits in the stock location in the rear trunk. What are the dimensions of the stock battery anyway?
GhostRider is offline   Reply With Quote
Old 10-02-2002, 09:11 AM   #2
Pmmeke
modder fokker
My Ride: E46
yes it does
http://forum.e46fanatics.com/showthr...hlight=battery
Pmmeke is offline   Reply With Quote
Old 10-02-2002, 12:39 PM   #3
mrzed
My Ride: X5
if your battery is in the trunk original it wil fit but you have to alter the bracket that holds the battery in place
mrzed is offline   Reply With Quote
Old 10-02-2002, 02:37 PM   #4
MCD007
Im The Man
My Ride: 325ci
Send a message via AIM to MCD007
When I had a yellow top in my trunk in order for the bracket to work I had to raise the hieght of the battery with a plank of wood.
MCD007 is offline   Reply With Quote
Old 10-02-2002, 03:09 PM   #5
GhostRider
ANyone know what these batteries run on average?
Would it be a bad idea to put this in without any upgraded ICE?
Old 10-02-2002, 04:00 PM   #6
99silvermissile
My Ride: 99 GS-T (400HP)
Send a message via AIM to 99silvermissile Send a message via Yahoo to 99silvermissile
Yes...on average they run $134
I have the blue top in the eclipse. Its a deep-cycle marine but I wanted the blue top to match my color scheme in the engine bay. I paid $145 for it.
You do not need to have a system to put one of these batteries in the car.
For more info check out this site >> http://www.optimabattery.com/
99silvermissile is offline   Reply With Quote
Old 10-02-2002, 07:26 PM   #7
jun14scr
booo for body roll.
My Ride: 2009 335i.
call me stupid but what's so great about these batteries?
jun14scr is offline   Reply With Quote
Old 10-03-2002, 08:03 AM   #8
99silvermissile
The unique design of the SPIRALCELL TECHNOLOGY. provides many features not available in ordinary batteries. The following is a summary
SPIRALCELL TECHNOLOGY PROVIDES:
More plate surface, closer plate spacing, ability to use high purity lead. RESULTING IN: Low internal resistance. This low resistance gives you more power in a smaller box, ability to recharge much faster, higher, cleaner voltage characteristics during discharge
Immobilized plates (locked in place). RESULTING IN: Improved vibration resistance, no shedding of active paste material, no gradual loss of power and capacity as the battery ages. This gives you a battery that lasts longer and performs better throughout its life.
and...
The main reasons the OPTIMA battery has a longer life are:
No shedding of active paste material. The SPIRALCELL design immobilizes the plates preventing the active past from working loose, which can cause plate to plate shorting
High purity lead-tin grid. Grid material in OPTIMA batteries is more resistant to grid degradation. A type of internal corrosion that affects the plates inside a battery as it ages
Sealed design prevents loss of water which can lead to plate dry out and failure.
Old 10-03-2002, 01:10 PM   #9
GhostRider
Having this battery wont do a whole lot in a stock setup but when you have a lot of ICE subs and amps then they really become more neccessary from what I understand. All their technology boils down to "the power is there when you need it" such as when you play a track with fast deep changing bass notes that crave power.
