#1 |
HELP! Need a wire I can tap (for relay) only when xenon highs are on
Anyone know where one is in the car?
#2 |
Banned
Are you trying to wire your garage door opener to your high beams. Do you have xenon high beams i don't think they make them cause it takes a few seconds for it to reach the right brightness.
#3 |
no, I want to make my halogen highs (inner bulbs) come on with my xenon highs (outer bulbs). I'm going to wire a relay but I need something to trigger it off of.
#4 | |
My Ride: '04 325i - '08 C300
http://forum.e46fanatics.com/showthr...ghlight=garage Post # 19 might tell you which wire to use... |
#5 |
nope, that just tells me which powers the headlights, which I already knew.
#6 |
My Ride: 09 Altima Cpe
Sounds like you need to tap to the bi-xenon shuuter trigger. My xenons were a retrofit so I can't tell you the wire colour, but you are looking for the center pin of the smaller three pin connector going into the OEM ballast (this controls the shutter mechanism. It is positive trigger and should work fine with an extra relay load, but be sure to reverse-diode the relay to prevent spikes.
BTW this is the way I wired my high beam setup and it works great. Only problem is I believe you will loose flash-to-pass unless you get a bit creative with diodes. Mark |
#7 |
http://www.bimmerfest.com/forums/showthread.php?t=46813
http://forum.e46fanatics.com/showthread.php?t=296547
Thinking about a Honda or VW Dont buy from East Coast Honda - VW Read about my experience here ![]() Some people dream of speed-others create a damn jet powered shopping cart. Curious about VoIP and Vonage click here |
#8 | |
