Old 01-19-2006, 02:31 PM   #1
sandman512
My Ride: 2005 325I
Help With Install
Ok, just went to install my front clear corners, OEM. The pass. side went in like a charm, went to do the drivers side and there is a gap between the lens and the headlight. Probably a 1/4 inch. Any and all advice is appreciated.
Sandy
sandman512 is offline   Reply With Quote
Old 01-19-2006, 02:36 PM   #2
JCsE46
(oOO \ (||||)(||||) / OOo)
JCsE46's Avatar
My Ride: 03 E46 JB, 08 MBE350
Send a message via AIM to JCsE46 Send a message via MSN to JCsE46
Sandy
It probably wasn't installed properly. There's like a "tongue and groove" interface between the headlights and turn signal lens that should need be connected exactly or else it will have the gap like you've said.
JCsE46 is offline   Reply With Quote
Old 01-19-2006, 02:38 PM   #3
preppy
My Ride: 2002 BMW 325i
The corner and the headlight have a groove that lines them up together. Double check your install. Good luck.
preppy is offline   Reply With Quote
Old 01-19-2006, 02:39 PM   #4
sandman512
My Ride: 2005 325I
Just went out there again, deep breath and BINGO slid right in. Thanks everyone!!!!!!! OEM FIT!!!!
Old 01-19-2006, 05:16 PM   #5
sandman512
My Ride: 2005 325I
Ok, it did go in and looks great, BUT where the curve (facelift) meets the fender there is some play, it doesn't look like a gap, but play. So, I unscrewed it, pushed it in a little further and still a little play. Is this normal? Once again, thank ahead of time!!!!!!!!!!
