Old 01-19-2006, 05:23 PM   #1
castel
My Ride: 00 e46 328i
Coolant level sensor DIY
Hi im new to this site, ive been searching the forum and couldnt find anything pertaining to a Coolant level sensor. Some of your forums more avid users are asking the same question. Id really appreciate if you guys could direct me to a site or suggest on the installation. Im doing this research for a friend..Tia
castel is offline   Reply With Quote
Old 01-19-2006, 06:33 PM   #2
K:^P
My Ride: 00 323//65 Fastback
should be on the bottom of the expansion tank where part of the upper rad hose connects. Might as well double check on that tank. Mine cracked and had to replace. The sensor twist right off from what I remember. But that lower hose on the tank is a different story if you're going to take it out. Anyway,
http://www.realoem.com/bmw/showparts...41&hg=17&fg=05
K:^P is offline   Reply With Quote
Old 01-19-2006, 06:46 PM   #3
castel
thanx alot for the help, the info provided should be very useful,
