Old 01-21-2006, 11:05 PM   #1
brucelee
My Ride: 1999 328I
Trans and Rear Diff fluids
Hi,
I just purchased a 1999 328I, in really nice condition. The car has 92K miles on it and I want to bring the lube services up to date.
In addition to an oil change, I was thinking of doing a trans fluid and read diff fluid change. Of course, the BMW manuals are not very helpful here.
My intent was to use Mobil one ATF fluid in the auto trans. and Mobil one 75-90 gear lube in the rear.
My question is whether these are the correct fluids and if so, what quantities are in each cavity?
Also, is there a way to check the Auto Trans fluid level?
Thank you.
brucelee is offline   Reply With Quote
Old 01-22-2006, 02:02 AM   #2
leej323
leej323's Avatar
My Ride: '00 323i
I've read that BMWs use lifetime tranny fluid. Supposedly you're not supposed to flush it.
leej323 is offline   Reply With Quote
Old 01-22-2006, 11:04 AM   #3
brucelee
My Ride: 1999 328I
Thanks. I find that totally hard to believe. How did this magical trans get produced anyway.
Who else is skeptical?
Old 01-22-2006, 11:15 AM   #4
papidog
My Ride: 328i Sharked, CAI
Many of us who plan to use (hope) to keep their cars beyond 100K miles are skeptical and have changed the fluids.
My only word of advice, get a professional to do the transmission...and that does not mean Jiffy Lube.
Do a search. You will find plenty on the subject.
papidog is offline   Reply With Quote
Old 01-22-2006, 12:18 PM   #5
Canuck328i
My Ride: 09 Altima Cpe
A lot of us are skeptical about this - as mentioned, do a search on the subject. I would have ignored this as well if it weren't for a number of respected mechanic-types here who have said NOT to change the fluid. Plus the method used to change/refill is somewhat unique.
BTW this advise only applies to the auto, not the manual.
As for your other q, many here (including myself) have opted for Redline 75w90 synthetic for the rear gear. Royal Purple is another name as well.
Mark
Canuck328i is offline   Reply With Quote
Old 01-22-2006, 03:01 PM   #6
brucelee
My Ride: 1999 328I
Thanks guys. I will do a search for more info!
Old 01-22-2006, 04:14 PM   #7
ADA
Banned
My Ride: 323ci
I chaned my transmission fluid and differential fluid too.
However, you only issue is that you have a very high mileage transmission.
P.S If you do decide to change out your transmission make sure you replace the transmission filter, gasket, and bolts too.
You either have a GM or a ZF transmission
ADA is offline   Reply With Quote
Old 01-22-2006, 05:21 PM   #8
delta
My Ride: A4 2.0TQ 6MT
Is it bad changing transmission fluid with a high mileage car? If so, is it still safe to change the fluid in a 70K mile car?
delta is offline   Reply With Quote
Old 01-22-2006, 05:34 PM   #9
ADA
Banned
My Ride: 323ci
That is your call. I changed my transmission fluid (filter, gasket, and bolts) at 76,000 miles. My car is at almost 85,000 and no problems so far =)
The rule of thumb is like 50,000 miles. the concept is that all the sludge on higher transmissions are holding all the gear into place. when you flush out a high transmission the sludge will go away but now you introduce "extra play/gap/movement" into your gear. therefore, your transmission might fail.
Again, the decision is yours. I did mine at 76,000 miles and I am happy. My next transmission change is going to be at 90,000
Old 01-22-2006, 05:50 PM   #10
delta
Thanks for the info
Old 01-22-2006, 05:50 PM   #11
Speeder
My Ride: '04 325i - '08 C300
I believe for my car (an 04 325i Step) the rear Differential takes 0.95 qaurts. To be on the safe side, I just picked up 2 quarts of 80-90 Castrol Gear Oil at Walmart (@$3.32 ea).
Speeder is offline   Reply With Quote
Old 01-22-2006, 09:45 PM   #12
Tom Busby
My Ride: 2001 325i, 1995 318i
I read a detailed post, I believe here, about changing the auto trans fluid. I believe the difficult part was to measure the temperature of the fluid, which had to be plus or minus 5 degrees, at some odd tempuratue like 55 degrees Celsius, when you check the fluid-level. If you get the temp wrong you get the fluid-level wrong, and you would have been better off doing nothing.
Tom Busby is offline   Reply With Quote
Old 01-23-2006, 12:10 AM   #13
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
You should get 2 quarts of rear end fluid unless the pump can get out every drop from the 1st quart. I had to run out and get another quart in the middle of the job.
Royal purple works good.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 01-26-2006, 10:53 AM   #14
brucelee
My Ride: 1999 328I
An update:
Replaced the diff fluid with about 1.5 qts of Mobil 1 75W-90 fluid. Easy to do this.
Re: the trans, I chatted with my BMW parts guy who is a real source (he wrenches his own BMWs),
On my particular car, all but one qt of fuid is drained when the pan is dropped. I am going to do this, buying the 8qts of flluid, filter, gasket etc from BMW.
He laughed out loud when I asked him about lifetime fill and then told me what his fluid looked like at 95K miles.
In short, I am changing soon!
Old 02-17-2006, 08:29 PM   #15
UnBreakable
My Ride: OB E46 328i
Hey im about to do a differential fluid change.. Are there any special tools that are needed? .. i heard something about a 10 mm hex and a 14 mm hex to remove the fill and drain plugs but i have no idea.. can anyone tell me which one is the right one for a '00 328i
UnBreakable is offline   Reply With Quote
Old 02-18-2006, 10:08 AM   #16
kbsilver
My Ride: 2000 328i
The differential drain and fill plugs have aluminum washers that should be replaced. Pick them up before you start the job. They are very inexpensive.
kbsilver is offline   Reply With Quote
