Sponsored by BAVSOUND
Old 01-23-2006, 11:32 PM   #1
bimmer88
My Ride: 06 Lexus GS430
Send a message via AIM to bimmer88
Can someone confirm that this is where REVERSE sensor wire is????
I already have confirmation on speed sensor.. can anyone confirm this is where the reverse sensor is? Thanks!
bimmer88 is offline   Reply With Quote
Old 01-24-2006, 12:28 AM   #2
Audiomotive
Past Site Sponsor
Audiomotive's Avatar
My Ride: 2001 330Xi, 2005 STi
If you are doing a nav install you can tap your reverse light wire on the taillight.
Audiomotive is offline   Reply With Quote
Old 01-24-2006, 12:50 AM   #3
bimmer88
that would be more work pulling the wire from the front to the back though.. and since i was already pulling 1 to the gauge cluster for the speed sensor, it'd be easier for me to pull just one more. I see no blue/yellow wires behind the gauge cluster. I see a blue/greenish yellow wire... anyone know if that's the one???
Old 01-24-2006, 01:36 AM   #4
bimmer88
ok... since i'm not sure of the wire behind the cluster, i'm not wiring it there. i'm now trying to do it through the glove compartment... i'm trying to follow directions that i found on here but i can't get access to this box in this picture... when i pull the fuse tray all the way down, that black box is pointed away from me... is there some clips that i press to release it???
Old 01-24-2006, 07:38 AM   #5
bimmer88
figured it out. Thanks!
Old 01-24-2006, 08:32 AM   #6
ca1242
My Ride: 2003 330i
For future reference, you can get both the reverse and VSS from that j-box over the glove box.
Old 01-24-2006, 04:28 PM   #7
bimmer88
actually, i was never actually able to get access to it like the picture showed... can't seem to find directions on accessing that box anywhere... i just saw a blue and yellow wire that was going into it and tapped right in..
Old 01-25-2006, 07:23 AM   #8
ca1242
My Ride: 2003 330i
Once you pull the fuse box down, you can the the box. It just pulls out, has a couple snaps holding it.
Old 12-07-2006, 11:17 PM   #9
Brian66D
Brian66D's Avatar
My Ride: facelift
bringin it back from the dead i know, im sorry...but what color wire in the "j-box" is the speed sensor...im not putting in a reverse camera so i dont care about the reverse wire....
and i know everyone well most on here do not hook the wire for the parking brake up to the actual parking brake....on previous installs i have done in the past it was just a ground wire...this one says "hook up to the positive feed on the parking brake" so to be able to watch movies in drive should i hook it up to a positive?? the whole thing about positive feed kind of confused me
2000BMW323i- gone
B6 Audi A4 - gone
G35 Coupe - current
Facelift 325i - current
Brian66D is offline   Reply With Quote
Old 12-08-2006, 08:17 AM   #10
ca1242
My Ride: 2003 330i
VSS is black/white. Don't get it confused with the tach wire (black).
The reverse wire, besides switching to rear camera is used by navigation units to know that the car isgoing backwards, so it is able to place the car in the map accurately. I would hook it up, you already have to run a wire there, might as well do two wires.
What radio do you have? If it is an alpine, you are supposed to hook up both the parking brake and real brake and go through a sequence to be able to view video/setup navigation information. If you get a PAC-TR7, it can be used to automatically bypass the safety, just don't do anything dumb if you bypass it while driving.
Old 12-08-2006, 08:31 AM   #11
silver330ciman
My Ride: TiAg 330CI TS1
So, the reverse wire is the blue/yellow one? Could anyone verify this, please?
Sig by hi its me alec
silver330ciman is offline   Reply With Quote
Old 12-08-2006, 11:38 AM   #12
ca1242
My Ride: 2003 330i
Look at the first picture. Same colors as the cluster location.
Old 12-08-2006, 02:26 PM   #13
Brian66D
Brian66D's Avatar
My Ride: facelift
i have the Pioneer AVIC D1....dont worry the only reason i want it hooked up while im driving is so others can watch movies, or play ps2 while im driving.... so if i hook up the reverse wire and the speed sensor though the j-box all i have to do is hook up the parking brake wire to a positive and that all will work?
2000BMW323i- gone
B6 Audi A4 - gone
G35 Coupe - current
Old 12-09-2006, 01:31 PM   #14
Brian66D
Brian66D's Avatar
My Ride: facelift
also, im not going to use my steering wheel controlls anymore, maybe i'll add the pac later but is it possible to still make the controlls light up?
2000BMW323i- gone
B6 Audi A4 - gone
G35 Coupe - current
Old 12-10-2006, 07:51 PM   #15
Brian66D
Brian66D's Avatar
My Ride: facelift
ca1242????
2000BMW323i- gone
B6 Audi A4 - gone
G35 Coupe - current
Old 12-10-2006, 08:16 PM   #16
ca1242
My Ride: 2003 330i
The steering wheel buttons will still light up if you remove the oem radio and use the pac.
Old 12-11-2006, 03:22 PM   #17
Brian66D
Brian66D's Avatar
My Ride: facelift
i dont want the pac, how can i bypass the e-brake thing w/o using the pac
2000BMW323i- gone
B6 Audi A4 - gone
G35 Coupe - current
Old 12-11-2006, 05:46 PM   #18
ca1242
My Ride: 2003 330i
google "avic-d1 bypass" If I remember correctly, you have to add a wire to the harness and ground it.
Old 12-11-2006, 08:14 PM   #19
Brian66D
Brian66D's Avatar
My Ride: facelift
THANK YOU!!
i dont want to use the pac, so im going to experiment tapping some of the steering wheel controll wires into th "illumination" wire on my harness to see if i can get the lights on the wheel to still light up.
i was a professional installer for an auto customs shop around here for quite some time...i feel like an amature asking all these questions....
2000BMW323i- gone
B6 Audi A4 - gone
G35 Coupe - current
Old 12-11-2006, 09:45 PM   #20
ca1242
My Ride: 2003 330i
One more time, the illumination of the steering wheel controls would still work if you replace the radio.
There are 4 wires going on the right side buttons (cruise control), ignition, ground, i-bus (audio/phone) and k-bus (cruise control). There are 4 wires going from the cruise control buttons to the left side (ignition, ground, vol/track-up/down and r/t+mute) The buttons on the left put out different resistance values. All the logic is on the cruise control buttons.
Both left/right buttons lights up from the ignition source (no illumination wire inside the steering wheel).
Hope that clears things up.
THANK YOU!!
