Thread Tools Search this Thread Rating: Thread Rating: 29 votes, 4.97 average. Display Modes
Old 04-12-2002, 02:33 PM   #1
mission836
My Ride: 00' 323i
Send a message via AIM to mission836
how do you reset the oil change milage meter?
thank you.
mission836 is offline   Reply With Quote
Old 04-12-2002, 02:44 PM   #2
phxarchitect
My Ride: 1999 323i Sport
Send a message via Yahoo to phxarchitect
I got this from emi323i a while back, didn't work for me becuase my car was built before 06/2000, but it might work for you.
Subject: if your car is build b4 06/2000 you need a tool
otherwise, hold the trip reset button down, turn the key to "on"... hold it
down for about 15 seconds, and the display will change to something like
"reset" something... release the button... and click it again... something
like that...
phxarchitect is offline   Reply With Quote
Old 04-12-2002, 02:48 PM   #3
phxarchitect
Wait these instructions are better than the last ones I sent you.
-switch off ignition
-press the daily miles button and keep it pressed for the next two steps below
-switch on ignition (dont start)
-wait for display to show "reset"
-let go the daily miles button and press it once again
Old 04-12-2002, 02:50 PM   #4
sgv321
My Ride: 328
ohh i did not know that. Why did they do away with the reset tool? BMW has used that thing forever....
sgv321 is offline   Reply With Quote
Old 04-12-2002, 03:00 PM   #5
mission836
My Ride: 00' 323i
my car was made before 6/2000 so i'm gonna need the reset tool..
where can i get the reset tool and what is it called exactly?
thanks for the reply.
Old 04-12-2002, 03:10 PM   #6
joe330ci
My Ride: 330ci
this is cool! i'll try it out the next time i change my oil. :smile:
joe330ci is offline   Reply With Quote
Old 04-12-2002, 03:16 PM   #7
ism409
>:P
My Ride: 2000 328i
Send a message via AIM to ism409 Send a message via Yahoo to ism409
Re: my car was made before 6/2000 so i'm gonna need the reset tool..
You can find it here
Tit Silver 2000 328i. sp/pp/5spd.
oem clears, DIY silvervisions, hamann shadow grille, gen 2 DAE's, silver headlight trim, UUC RKIII..more to come.
ism409 is offline   Reply With Quote
Old 12-20-2007, 03:14 AM   #8
green1
My Ride: ox grn 02 325i
Oil Change Service Reset
Guys,
I tried this on my car (ignition off, hold odo, ign pos 2, reset appears let go, press once, done.) but it didn't work on mine... am i doing something wrong, also now... i can't see the current temperature... any help out there.
green1 is offline   Reply With Quote
Old 12-20-2007, 03:56 AM   #9
SBREM2
My Ride: 2000 328CI
I have a 00" 328... i tired this out but the words "reset" did NOT pop up... however, the words " test" did. It would flash back from "test to my current mileage every couple seconds. If I clicked it once again when "test" was displayed... a sequence of numbers would pop up? The sequence would change ever time I press the reset button. Any ideas? I've been searching but no luck. I just changed my oil too... and dont want to go to the dealership to reset my stuff if I dont have too.
SBREM2 is offline   Reply With Quote
Old 12-20-2007, 06:41 AM   #10
dblockboy
My Ride: 328ci
you can rest it by the engine, if you hold down the number 7and 19 for 3 seconds it will reset the oil if you hold it for 9 sec it will reset the inspection , ill try to find the page again it shows you how its done
dblockboy is offline   Reply With Quote
Old 12-20-2007, 06:46 AM   #11
dblockboy
My Ride: 328ci
File Type: pdf service_resetfor 99-00e46.pdf there nit is it shows you how to do it
Old 12-20-2007, 06:46 AM   #12
dblockboy
My Ride: 328ci
http://forum.e46fanatics.com/showthread.php?t=530667
click on this link and everything is there
Old 12-20-2007, 05:24 PM   #13
SBREM2
My Ride: 2000 328CI
OKay well for some reason my oil service indicator ahs been stuck at -4950 for the past 2 months.... even tho i know im not over on my oil change. I did the pin reset in that pdf attachment and it reset my inspection to 15XXX. but not the oil service doesnt pop up anymore when i first start the car or turn it to position 1 or 2... just the inspection pops up. is this normal? i never really noticed it before because BMW always serviced my car. They wanted to charge me $66 to reset it... i just said F it.
Old 01-28-2008, 10:25 PM   #14
Shannon C
My Ride: Fern Green 318i exec
Having gone through this "Pin 7" procedure I seem to have created a display problem. Prior to attempting this re-set I was also fiddling with the mileage knob and I think I must have changed the display sequence as now "Inspection" and "25,000" shows instead of details for the oil service.
Can anyone help with the sequence to get the dispaly back to oil service.
1999 318i
LED Tails / LED Plate Lights / LED Interior Lights / Angel Eyes / Smoked Corners / Smoked Side Indicators / Low beams - Narva Arctic Blue / High beams - Narva Plus 50 / Gauge Rings / Black Grille / Roof Spoiler / Boot Lip Spolier / Licence Plate Holder Deleted / Tinted windows / Style 44 Wheels/Coilovers.
Shannon C is offline   Reply With Quote
Old 01-29-2008, 08:26 PM   #15
Shannon C
bump
Old 01-29-2008, 09:34 PM   #16
sivitec
My Ride: 2002 BMW e46
SBREM2 and Shannon C,
Nothing to worry about it. The sequence is correct. After the oil service, the inspection routine would come next.
Oil Service->Inspection (I)->Oil Service->Inspection (II)
Please take note that Inspection I & II includes Oil service as well. Try searching this forum to find out what's being done during Oil Service, Inspection I, and Inspection II.
Regards
sivitec is offline   Reply With Quote
Old 01-29-2008, 09:38 PM   #17
Shannon C
Thanks sivitec.
Old 04-18-2008, 04:53 AM   #18
boudi24
My Ride: BMW 328i e46
i have a 328i 1999 e46 i am trying to figure out how to reset the oil change mileage meter now it's like -2000 miles so if anybody can help plz hit me up thank you
boudi24 is offline   Reply With Quote
Old 04-18-2008, 05:02 AM   #19
Owtlaw333
My Ride: 2009 Mazdaspeed 3 GT
Did you read the thread at all?
Bringing it back for the new people...
productionof1.com
|||_Buy my photos?_|||
Owtlaw333 is offline   Reply With Quote
Old 04-18-2008, 05:06 AM   #20
freerider
My Ride: 03 320i, 98 328i ind
you might find this interesting:
Instrument Cluster tests...
To
access a whole slew of data and the instrument cluster test on an e46:
1. with the ignition off, hold the left instrument button
2. turn the key to position 1 (radio)
3. If you let go of the button and press again you will cycle through the following 20 tests.
4. If you want to acess the submenus, release the button while a test menu number is being diplayed, within a second, you will see Test number.0. You can then click again to cylce through the submenus. To get back to the main menu, press and hold the left key until you see the test number without the ".0".
5. Note, you can only access tests 1 and 2 without unlocking-- to unlock the other tests, go to test 19 and wait for the display ot say "l-off", then click again. Now you can cycle through to the other tests
Test 1 (Vehicle specific data)
Sub Menu Sample Output Meaning
1.0 12345 VIN
1.1 4812 Body number
6_1.2 834762 Part number of cluster
1.3 010203 Coding/diagnosis/bus index
1.4 3499 Build date (week/year)
1.5 04_600 Hardware/software version of cluster
3_1.6 415_06 Injection status
Test 2 (instrument cluster test) as discussed already
Test 3 Service INterval data
3.0 1500 Liters
3.1 0 Periodic Inspection days (NA to US)
Test 4 (Fuel consumption data)
4.0 0267 26.7 liters/1000km
4.1 0073 7.3 liters/hour
Test 5 (Fuel consumer/ distance traveled)
5.0 0195 9.5/liters / 100km
5.1 226 Distance left to go
Test 6: Fuel level sensor input in liters
6.0 237415 Fuel level: Left side fuel sensor 23.7 liters RIght side: 41.5 liters
6.1 0652 Tank level: 65.2 liters
1_6.2 0667 Indicated value and tank phase 1- both sensors ok 2- one sensor fault 3 implausible input
Test 7 Temp and speed
7.0 032 Coolant temp input = 32 C
7.1 245 outside temp: 24.5 C
7.2 5283 Engine SPeed 5283
7.3 058 Vehicle speed
Test 8
Input vaues in HEx code
8.0-8.3 XXX Hex code, instrument cluster inputs
Test 9 Batter voltage
9.0 125 12.5 volts
Test 10 Country coding
10.0 02 US (=02)
Test 11 Cluster code
11.0 0000003 Cluster code
Test 12 Not used
Test 13 Gong test Activate gong by presing button (gong response is delayed)
Test 14 Fault memory
Test 15-18 not used
Test 19 Lock/ unlock other tests
Test 20 Avg fuel consumption correction
20.0 Pressbutton when correc 1s position in attained
20.1 Press button when correct 10s position is attained
20.2 Press button when correct 100s position is attained
Test 21 Software reset
freerider is offline   Reply With Quote
