Old 01-27-2006, 11:24 AM   #1
BoostedBoogie
Banned
BoostedBoogie's Avatar
My Ride: facelifted e46
bald tires wearing out brake pads?
I got my brake pad/sensor warning light come on for the 3rd time in under a year, and I suspect that my worn out front tires are causing me to brake harder than normal just so I can stop normally. does anyone know if worn tires play a role in the life of your brake pads?
BoostedBoogie is offline   Reply With Quote
Old 01-27-2006, 11:34 PM   #2
leej323
leej323's Avatar
My Ride: '00 323i
If you're braking harder than normal then yes, your brake pads will take more abuse. You also should know that having larger diameter rims without taking into account an upgraded brake system means you'll be putting more strain on your stock brakes. Why? Plus-sizing also means you're creating more rolling mass that you inevitably have to slow down. This can cause your brakes to wear much faster.
It's easy to check if your pads are really bad or if it's a faulty sensor. If you're lazy you can check just your outer pads, but if you want the whole picture, take off each wheel and check both the inner and outer pads for wear
Lastly, having bald tires is inexcusable man. Tires with adequate tread are just as important as having a properly maintained brake system. There's competitively priced tires for practically every size. Drive safe!
leej323 is offline   Reply With Quote
Old 01-27-2006, 11:42 PM   #3
BMWintoxication
Taiwan/Vancouver/Shanghai
My Ride: Jet Black02' 325ci
Send a message via AIM to BMWintoxication Send a message via MSN to BMWintoxication
it's the tires that stops the car.. not the brake discs... so.. if you think in that logic.. yes, it plays a big role.
Orz
BMWintoxication is offline   Reply With Quote
Old 01-28-2006, 10:08 AM   #4
jmsanders78
My Ride: 328i, Z4
Originally Posted by BoostedBoogie
...I suspect that my worn out front tires are causing me to brake harder than normal just so I can stop normally. does anyone know if worn tires play a role in the life of your brake pads?
I don't think this makes sense. If your tires are worn out, then you have less grip available to brake. That would imply that you could only use, for example, 70% of your available braking power before you got into the ABS. At that point, you wouldn't be able to brake harder than normal to stop any faster.
jmsanders78 is offline   Reply With Quote
Old 01-28-2006, 06:34 PM   #5
vmwerks
Past Site Sponsor
vmwerks's Avatar
My Ride: 330zhp Super Coupe
Send a message via AIM to vmwerks
Worn out tires will not cause accelerated brake wear. Worn out tires will also not cause you to brake harder.
vmwerks is offline   Reply With Quote
Old 01-28-2006, 06:43 PM   #6
UnBreakable
My Ride: OB E46 328i
may be youre ridding the brake
UnBreakable is offline   Reply With Quote
Old 02-01-2006, 06:37 PM   #7
Bim Growl
Banned
Bim Growl's Avatar
My Ride: E86 3.2
manual or step car?
Bim Growl is offline   Reply With Quote
Old 02-01-2006, 11:55 PM   #8
BoostedBoogie
Banned
it's a steptronic car. just got the brakes serviced today and they replaced both front pads.
apparently they will either check front or rear rotors, front or rear pads, and replace only what needs replacing on both sides IE front L/R pads or rear L/R rotors.
Old 02-02-2006, 05:20 PM   #9
777
My Ride: E46 Silver 325ci
Quick question related to this.... was getting an inspection on my car and the mechanic tells me that my front brake pads and front rotors are worn....
Now I thought that I would get the warning light come on the dash if this was the case, but it hasnt? How does the warning system work?
777 is offline   Reply With Quote
Old 02-02-2006, 05:35 PM   #10
vaio76109
My Ride: Race Cars
Warning light is for pad thickness, not rotor thickness.
vaio76109 is offline   Reply With Quote
Old 02-02-2006, 07:15 PM   #11
GIO_21
My Ride: Active HKS Blown
Send a message via AIM to GIO_21
GIO_21 is offline   Reply With Quote
Old 02-02-2006, 07:29 PM   #12
jmsanders78
My Ride: 328i, Z4
The indicator is for when the pads are really thin. I'm not surprised that someone told you that they are worn before the light came on.
Old 02-02-2006, 07:59 PM   #13
GIO_21
Yes when the light comes on the pads are literally gone they have NOTHING left in them so that is true
Old 03-02-2006, 11:25 AM   #14
Iaut
Banned
My Ride: 2000 BMW 328i
I just did my pads and my brake light sensor wont go off, do i have to buy a new one?
Iaut is offline   Reply With Quote
Old 03-02-2006, 11:46 AM   #15
jmsanders78
My Ride: 328i, Z4
Not unless it's destroyed. Turn the key to the on position, but don't start. Leave it there for 30 seconds (maybe 60? Don't remember...) and it should go off.
Old 03-02-2006, 12:05 PM   #16
vaio76109
My Ride: Race Cars
Yes, once its been tripped the sensor is ruined.
Old 03-02-2006, 01:22 PM   #17
jmsanders78
My Ride: 328i, Z4
Oh right... For some reason I was thinking that you had disconnected it and the light was on. Yeah, if it lit because your pads are worn, it's toast.
Old 03-02-2006, 04:41 PM   #18
stapler12345
My Ride: Mineral White F30
yea i just redid all the rotors, brake pads and shims. cost me 800 something dollars. you probably have the same miles as my 325i. in the mid 50's.
Originally Posted by Penguin Koolaid View Post
I've never heard of a woman wanting more than she actually deserved. Never.
stapler12345 is offline   Reply With Quote
