Old 01-30-2006, 08:40 PM   #1
whizbang
My Ride: '03 TiAg 325i
Help with removing piece under radio/AC unit
Can anyone please tell me how I can remove this piece? I'm installing the Aux Radio Input and I want the wire to come out here. I know it can be taken out without removing anything in front of it but I can't get it to budge and I don't want to damage the dash trying. Please help!
whizbang is offline   Reply With Quote
Old 01-30-2006, 08:52 PM   #2
Ack
Bavarian I.C.E.
My Ride: 2002 330Ci
Open the cover and pull straight out by the two corners. It slides straight out by itself.
Ack is offline   Reply With Quote
Old 01-30-2006, 09:05 PM   #3
whizbang
Nope...not budging at all. All I can really pull on is the door but I'm scared I'm gonna rip it off. How hard do I have to pull? Is there a trick to this?
Old 01-31-2006, 03:44 AM   #4
Titansilber330D
My Ride: 330D Sport
Remove the radio and the climate control then you can push it out from behind.
Titansilber330D is offline   Reply With Quote
Old 01-31-2006, 04:51 AM   #5
paraklas
My Ride: ESS TS2 320ci
Kinda weird question.. but can you fit a radio in the place of that piece? I want to use the actual radio slot for a motorized tft...
Old 01-31-2006, 05:24 AM   #6
10bmw10
My Ride: 2003.5 M3
buy an all in one, u will just be dissappointed if u have a seperate screen.
I believe if u push in the center while pulling straight out is the easiet way to get it out.
10bmw10 is offline   Reply With Quote
Old 01-31-2006, 07:23 AM   #7
Ack
Bavarian I.C.E.
My Ride: 2002 330Ci
It is not screwed in at all. It takes a bit of pressure to get it out. It might feel as though its going to break, but it won't.
Removing the radio will not help remove that peice. Removing the radio is used to get the HVAC controls out only.
Old 01-31-2006, 07:23 AM   #8
paraklas
I'm actually building a car pc and I need the TFT for the pc part. Unless I can find a radio with motorized TFT / Touchscreen with VGA input in a reasonable price .. which I haven't so far.
Old 01-31-2006, 11:46 AM   #9
whizbang
Finally got it!! Thanks Ack, you were right! just had to pull hard. I found it helped to put my fingers behind the door and pull upwards and out.
Old 01-31-2006, 01:55 PM   #10
Ack
Bavarian I.C.E.
My Ride: 2002 330Ci
Glad it worked out for you.
I've taken that part out more times then I want to remember while working on my system.
Old 01-31-2006, 10:26 PM   #11
jfischetti
My Ride: 06 M5
I just installed sirius in the same place. The starmate fits great. I used a small screwdriver to pry it out, much safer than "pulling hard".
Pops right out, although you already did it, a bit late...
J
jfischetti is offline   Reply With Quote
Old 02-01-2006, 06:53 AM   #12
paraklas
I was hoping someone to tell me if a normal radio fits in there though..
P.
Old 02-01-2006, 07:50 AM   #13
ca1242
My Ride: 2003 330i
P.
too shallow. The only place where you will get a radio is in the existing radio location (unless you modify the air ducts behind).
Old 02-01-2006, 06:35 PM   #14
paraklas
Thanks for the info
Old 02-13-2006, 01:06 PM   #15
winston smith
My Ride: 2002 330Ci
J
I just got a Starmate and was thinking of installing it in the same place. How did you mount the unit? Did you just velcro it in there? I wish I didn't have to use a cigarette adapter either.
winston smith is offline   Reply With Quote
Old 02-13-2006, 10:46 PM   #16
jfischetti
My Ride: 06 M5
It just kind of wedges in there when you have the bracket clipped on the back of the starmate. I have the BMW aux input in the glovebox. I would highly recommend having the dealer install that aux input in the glovebox, then you run the wires from the glove box up through the back of where the door is. When you take out the door tray thing drill a hole in the back and feed the wires through.
Good Luck,
J
Old 02-13-2006, 11:09 PM   #17
l4zy
My Ride: 95 M3, 13 X3
Send a message via AIM to l4zy
you can move the ac controls down. there is a oem bracket for that
P.
l4zy is offline   Reply With Quote
Old 02-14-2006, 01:38 PM   #18
WishIHadAStick
My Ride: 2003 330xi
I bought an converter for my XM and wired it into cigarette lighter so I don't need the plug.
WishIHadAStick is offline   Reply With Quote
Old 02-14-2006, 09:20 PM   #19
Tutankhamon
My Ride: 2017 M2, 2002 330ci
Send a message via ICQ to Tutankhamon Send a message via AIM to Tutankhamon Send a message via MSN to Tutankhamon
don't pull by the door
this works for me, just needs a bit of finess, i had to remove it a few times when i was installing my icelink
What will work is open the door, press with your fingers out on each side, this will push the tabs off its holders and you will be able to get it out, needs a bit of force, but just push out on the sides from inside the compartment.
Tutankhamon is offline   Reply With Quote
