Thread Tools Search this Thread Rating: Thread Rating: 20 votes, 5.00 average. Display Modes
Old 12-01-2007, 10:31 PM   #101
grafiksguy
My Ride: 2010 328xi
Originally Posted by reynaldo View Post
Need Help. I live in Fort Lee. I need to replace Front Control Army Bushing . Do I need to replace Comtrol Arm too? Can you post a DIY? thank
Rey
In answer to your first question, no, you don't necessarily have to replace the CAs. The bushings wear out much faster than the ball joints on the arms. But check the arms while your down there and if you've got over 60K on them you might want to think about that. As for DIY's do a search in the DIY forum, there are many to choose from.
grafiksguy is offline   Reply With Quote
Old 12-02-2007, 11:42 PM   #102
neck
My Ride: 02' 325ci
Rey
you can just replace the control arm bushing but the stock bushings always have a little play.. if your suspension is clunking.. it might be something else.
neck is offline   Reply With Quote
Old 12-03-2007, 02:10 PM   #103
vPanya
My Ride: 01 325CI
Control arm and bushings
doest the control arm come with bushings frrom pelican parts?
vPanya is offline   Reply With Quote
Old 12-03-2007, 06:40 PM   #104
alvocado
My Ride: 2002 330CIC Sport
There is extensive information on this if you take the time to read the threads. You can also go to the Pelican parts sites directly to answer your question above.
alvocado is offline   Reply With Quote
Old 12-05-2007, 04:00 PM   #105
raptorman5174
My Ride: 330i ZHP
LOL your sig! Funny Shite Man!
18 VMR CSL's
Koni
Eibach Sport Spring's
UUC Power Pullies
Sprint Booster
CCV Delete
3:38 rear diff
raptorman5174 is offline   Reply With Quote
Old 12-09-2007, 08:38 PM   #106
Flying Kimura
My Ride: '01 330ci
Send a message via AIM to Flying Kimura
Hello all
Just ordered the CA pakage with powerflex bushings from BW.
Thanks for all the tips on this thread. I'm gonna do both sides next weekend and I'm excited to do it myself.
Before this I've only done brakes and oil changes on my cars
Flying Kimura is offline   Reply With Quote
Old 12-09-2007, 08:43 PM   #107
Hopz
My Ride: 06 ZHP
Originally Posted by Flying Kimura View Post
Hello all
Hey I just did mine. It wasn't that hard, I just had probably with some stuck ball joints but I doubt your situation will be the same. Other than that issue, it was pretty easy and straightfoward. Thats funny, where in Stamford are you?
Hopz is offline   Reply With Quote
Old 12-09-2007, 08:46 PM   #108
saucey
My Ride: 2002 325i
Send a message via AIM to saucey
haha I work in Stamford CT. and I need to replace my control arms. Would you guys be willing to change them for me in the parking lot of my work?
saucey is offline   Reply With Quote
Old 12-09-2007, 10:33 PM   #109
Flying Kimura
My Ride: '01 330ci
lol.. it's the middle of winter dude
Call ICS and drop it off in the morning and pick it up after work if you don't have the time or place right now
Hopz, I'm in the Cove
you?
Old 12-09-2007, 11:54 PM   #110
saucey
My Ride: 2002 325i
what is ICS?
Old 12-10-2007, 12:08 AM   #111
Flying Kimura
My Ride: '01 330ci
Imported cars of Stamford
try icsperformance.com
Old 12-10-2007, 11:44 AM   #112
saucey
My Ride: 2002 325i
A co-worker of mine said they are crazy expensive.
Old 12-11-2007, 12:57 AM   #113
Flying Kimura
My Ride: '01 330ci
Diy
Old 12-13-2007, 09:04 PM   #114
Flying Kimura
My Ride: '01 330ci
Thumbs Up
Took a snowday today and changed my control arms. It took me 4 hours taking my time, eating a sandwich, and going back to the dealer for more bolts. I only bought eight but I needed twelve.
After reading the "jacking points" thread, I didn't want to crush ANYTHING!!! So, I used two 3.5 ton floor jacks from work. Once the car was at the height I wanted, I put the jackstands in front of them with a 4' steel bar between them and lowered the car until the bar just touched the car. I locked the jacks and went to work.
my stearing wheel is a little off center but going for an alignment tomorrow.
to this thead
Old 02-09-2008, 06:41 PM   #115
wluk
My Ride: 330Ci
I can't remove the xenon leveler from the right control arm. It's like welded on. Did anyone have the same problem?
wluk is offline   Reply With Quote
Old 02-10-2008, 01:02 AM   #116
FSUmac
My Ride: 2001 330i
Originally Posted by bamafanatic View Post
3. The most challenging part of this whole project is the inner ball joint nuts. The only way that you are going to be able to tighten the left side is by using extensions and a pivoting ratchet joint (weird angle on the nut) to attack the nut from up top (you can see the nut if you look down next to the dipstick). You have room underneath on the right side to work, but it is still tedious.
Can anyone post a picture of what this pivoting ratchet looks like that will allow me to access the driver's side inner ball joint nut from the top?
Also, how many extensions (length) am I going to need to get at this thing?
Thanks!
FSUmac is offline   Reply With Quote
Old 06-16-2008, 02:14 PM   #117
Chris3Duke
Yuck. Lots of noise coming intermittently from the front end of the car, usually only after driving at highway speeds then slowing down in parking lots and stuff.
Dealership originally said it was Sway Bar links, but that didn't fix the problem. Just got a call saying it's the outer ball joint on the left front control arm. If you look back in this thread, I replaced my CA's in June of 2006, and did a write-up. I used the BW arms and powerflex bushings. Bushings are fine, and so is the right control arm.
Isn't two years way too early for a CA ball joint to be failing? Symptoms started a few months ago, actually, so it was more like 20 months. I would guess the car has "maybe" 18-20,000 miles during that time...
Chris3Duke is offline   Reply With Quote
Old 06-16-2008, 03:24 PM   #118
Nathan323i
My Ride: 1999 323i
Tackled this on the weekend. Replaced both arms and bushings with Meyle's - took about 4.5 hours. I will be taking it in for an alignment tomorrow. Everything went quite smoothly actually - thanks to all the useful comments in the forum, I was very well prepared.
A couple of points:
-definitely use the ball joint puller - took 3 minutes to remove the outer ball joints from the subframe (per side). The inner ball joints just required a couple of small taps with the hammer and they dislodged. No need to touch the pickle fork.
-if you can avoid removing the ABS speed sensors and still get at the inner ball joint nuts, do so. I broke one of the sensors - rotating it back in place as I was finishing up.
-Soak the ball joint (nuts) with WD40 or equivalent well in advance. The inner ball joint on the driver's side started to rotate as it was half way open - I retightened it, sprayed it down, waited and attacked it again, constantly opening and closing until it came out. I used the jack underneath the control arm and accessed it from the top with extensions and UJ joint, as was suggested.
Ended up changing my rotors and pads while it was at it.
Next DIY - fix the leaking power steering reservoir......
Nathan323i is offline   Reply With Quote
Old 06-17-2008, 04:46 PM   #119
jlamb
My Ride: 2003 325i
I just did this over the weekend, + 1 day. I had a horrible, awful time getting the ball joints separated at the wheel; we actually broke the first pickle fork I bought (cheap China import that looked like poured aluminum), even took a blowtorch to the knuckle, it just wouldn't budge.
Eventually I tried using a Pitman arm puller per some suggestions, but it was too big to fit under the shocks. Luckily the kit included a pair of much more solid pickle forks, and after turning the steering wheel for some additional clearance, I knocked the arms off with a few good wind-ups. After finally getting the old CAs off (2 solid days of fiddling), it only took 30-40 minutes to stick the new Meyle + Powerflex bushings on.
I feel very silly, actually; I'd been attempting both prying and wedging actions with the fork since neither was directly specified. The pickle fork I'd bought had a very rounded handle tip which made it hard to hammer on, and didn't make its proper function very obvious. As soon as we saw the one in the loaner kit (with a wide, flat striking surface) it became obvious what to do.
So just to save anyone else failing to connect the dots, make sure you are hammering the fork in between the arm and knuckle like a nail, not simply setting it in and cranking it like a lever.
jlamb is offline   Reply With Quote
Old 06-17-2008, 05:13 PM   #120
328iBMW
My Ride: C320
My CA outer ball joints only lasted a year and a half. Meyle sent me new CA's for free.
What makes you come alive?.........Go do it.
328iBMW is offline   Reply With Quote
