Old 02-08-2006, 04:08 PM   #1
honakerd
My Ride: '03 325ci
Brake Wear Indicator "on"
I replaced the front brakes and rotors this weekend... even replaced the sensor wire... however the Dashboard indicator is still on....
Anybody have a clue as to why?
honakerd is offline   Reply With Quote
Old 02-08-2006, 07:16 PM   #2
barzanv
My Ride: 320dA 2001
It may be from the back brakes. If those are fine , keep the key in the position before ignition (with all the lights on) for more than one minute, before starting the engine. the light should go off. Good luck
barzanv is offline   Reply With Quote
Old 02-09-2006, 12:31 PM   #3
honakerd
My Ride: '03 325ci
I looked at the rear sensor... it seemed fine...
I will try the process you mentioned... hopefully that will do the trick.
Old 02-09-2006, 03:11 PM   #4
schon weg
My Ride: 2001 325xi
Like barzanv said: turn key past accessory...half minute or so light should go out.
2001 325xi: Jet Black, Black leather, Premium package, 3.0L DIY engine swap, ESS software, BFP CAI, Technik headers, custom TSE3, RT cats, Stage II fw w/ M5 clutch, pulleys, EVO3 SSK, H&R springs/Koni Sports, 18 BBS w/ S-03s, CDV omit, cosmetic stuff, et cetera.
schon weg is offline   Reply With Quote
Old 02-10-2006, 03:40 PM   #5
locof4
My Ride: 01 330i
I had the same issue after replacing my front brakes. Funny thing is I was installing a deal under steering wheel and I unplugged the connector between the wheel and the collar, and after pluggin it, light was reset...WTF?!?!
locof4 is offline   Reply With Quote
Old 02-10-2006, 05:47 PM   #6
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
My Ride: Project 330xi
You have to do something to reset your ECU. Unplug your battery.
-Gary
DiscoStu is offline   Reply With Quote
Old 02-12-2006, 12:08 PM   #7
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
Unplug the battery for 15 seconds or so.
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 02-20-2006, 10:54 AM   #8
honakerd
My Ride: '03 325ci
Thanks to all who provided information.
I turned the headlights on... turned the key forward to the 'accessory' position... waited 1 minute.... and then started the car. The brake wear indicator light is out! Who would have known.
Thanks Again,
Dave
