Old 02-08-2006, 03:33 PM   #1
CurE
My Ride: 2002 325CI
Send a message via AIM to CurE
Corner Delete Mod.
How do i go about hooking up the corner lights to the side markers so that the corner lights only come on when i use the indicator...
CurE is offline   Reply With Quote
Old 02-08-2006, 04:31 PM   #2
Asterisk*
Banned User
My Ride: gives me blue balls
Send a message via MSN to Asterisk*
Rule #1: Search before you post.
Asterisk* is offline   Reply With Quote
Old 02-08-2006, 04:39 PM   #3
bgsmith
bgsmith's Avatar
My Ride: No longer an e46
Searched because I wanted to know as well and found this
http://forum.e46fanatics.com/showthread.php?t=267800
bgsmith is offline   Reply With Quote
Old 02-09-2006, 10:04 AM   #4
bimmer07
Banned
bimmer07's Avatar
My Ride: //////////M
Send a message via AIM to bimmer07
Beware though a few people who've done this have ended up with a bad LCM cause of the side marker needing more power or something.
bimmer07 is offline   Reply With Quote
Old 02-09-2006, 03:47 PM   #5
ca1242
My Ride: 2003 330i
If you want to be safe, use a relay on the corner light to be "clicked" by the side light power. Don't forget to add a diode on the relay contacts to eliminate feedback when the relay is "released" (the surge could damage the LCM). The diode should be connected "backwards" on the relay contacts (line side goes to contact getting a positive signal.) You can get power for the relay from either the corner light, or another 12v source. This can also probably be done with a transistor.
Old 02-09-2006, 07:22 PM   #6
Canuck328i
My Ride: 09 Altima Cpe
And this thread: http://forum.e46fanatics.com/showthr...=278132&page=3. Read nearer the end where it discusses LCM failures and the associated costs. Plus there's the heat issues with the resistors.
The ONLY way this should be done is as ca1242 described. Personally I wouldn't recommend it period, but hey it's your car.
Mark
Canuck328i is offline   Reply With Quote
Old 02-09-2006, 07:50 PM   #7
MPossible
MPossible's Avatar
My Ride: track star
uhh couldnt you just put a resistor where the front turn bulb would be and problem is solved
MPossible is offline   Reply With Quote
Old 02-09-2006, 09:01 PM   #8
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
Or you could use LED turn signals since they draw less current than the OEM bulbs, this would further reduce the chance of LCM failures..
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 02-09-2006, 09:09 PM   #9
Canuck328i
You've lost me...how is this going to solve the problem of LCM output channel overloading??
Mark
Old 02-11-2006, 03:51 PM   #10
guest1017
Banned
guest1017's Avatar
My Ride: M3
Send a message via AIM to guest1017
i know of 1 person who had a problem, and hes the one that told everyone that ur LCM willgo bad.. thats bs in my opinion
guest1017 is offline   Reply With Quote
Old 02-11-2006, 08:07 PM   #11
Canuck328i
It is more than 1, it is at least a couple that I've read about. And from an electical design standpoint, it is NOT BS. You are asking an unfused transistor controlled circuit to produce and sustain a 26 watt output (front and side marker combined) when it is only designed to provide 5 watts (side marker only). It is like overloading as house plug circuit 5 times over.
If you don't want to listen to the warnings, go nuts and install this mod, can't say no-one here warned you. These warnings aren't just opinions. And I wouldn't be willing to risk to assume the known failures were random unrelated issues, especially considering the price of an LCM.
Mark
Old 02-11-2006, 11:27 PM   #12
Activ3
I've had it installed for almost a year now, and I've had no problems. If you really want to be safe, use LED bulbs in your corners...
Old 02-12-2006, 11:23 AM   #13
Canuck328i
Good idea.
Mark
Old 02-13-2006, 04:03 AM   #14
yamashek
My Ride: PYM3 6MTCoupe
i bought another bulb and use this bulb as a "resistor" and wrapped it with aluminum foil. hooked up the signal light to the side indicator, seems to do the job well after 6months+
yamashek is offline   Reply With Quote
Old 02-14-2006, 06:43 PM   #15
guest1017
Banned
guest1017's Avatar
My Ride: M3
i have LED corners, it could be different my bad
Old 02-15-2006, 11:02 AM   #16
CurE
My Ride: 2002 325CI
thanks for all the help...
Old 02-15-2006, 11:20 AM   #17
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
Could you list out the parts you would suggest to do it this way? I was thinking along the same lines but don't know what parts to use.
Thanks,
Tim
tim330i is offline   Reply With Quote
Old 02-15-2006, 12:43 PM   #18
ca1242
My Ride: 2003 330i
To do it this way, you would need a relay and diode on each side. You can buy the parts at radio shack. Use a normal 1-amp recifier diode and an "automotive" type relay (single pole, single throw). This is not the most elegant way of doing it, but it would definitely work.
Probably the best option is, as suggested to use LED corner light bulbs and do the mod as everyone else does it. Since the LEDs draw so little current, it won't cause problems.
If you are using light bulbs, you could also do it with transistors. No mechanical components to go bad (such as a relay). Just needs a little engineering design to figure out which parts to use.
Old 02-15-2006, 01:05 PM   #19
tim330i
E46Fanatics Owner
tim330i's Avatar
I thought even with LEDs there was still a potential problem because the front signal bulbs use 21 watts vs the 5 watts for the side markers. So even with no load from the LEDs that is 16 watts more load that the circuit should have on it.
How would you wire the transistors?
Tim
Old 02-15-2006, 01:20 PM   #20
Canuck328i
Tim
I think the idea is to use LEDs in the front corners, eliminating the 21 watt extra load of the regular front corner bulbs on the side marker circuits. It would only add maybe 1 watt or so.
This may be repeating the obvious, but something that gets confused here is there really are two "mods" being done. One is moving the front corner bulbs to the side marker circuit to change the lighting configuration (removing the parking light feature), the other mod is adding the resistors to the front circuits that the front corner bulbs used to be connected to. The resistors are only there to remove the "bulb out" warning - that step could be skipped but you'd have bulb-out warnings on the dash. All that said, the overload issue is with the "bulb" circuit not the "resistor" circuit.
Mark
