Mass Air Flow Sensor Cleaner? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-12-2006, 03:02 PM   #1
bigbiggirl
My Ride: 323Ci
My check engine soon light is on. I went to the shop and they told me air flow sensor and idle control is dead. I read some posts here and they sugest to clean the sensor first. I went to pepboys and found lots of CRC cleaner but I could not find the thing called "CRC Mass Air Flow Sensor Cleaner". Where can I find the thing? If there is no such place to buy it, can I use some other cleaner instead?
There are air intake cleaner, QD electronic cleaner, carburetor cleaner. Which one should I use? Thanks a lot
bigbiggirl is offline   Reply With Quote
Old 02-12-2006, 03:07 PM   #2
Forcefed M3
My Ride: HPF Stage 2.75
don't waste your $$. MAF sensor works or it doesn't.
Forcefed M3 is offline   Reply With Quote
Old 02-12-2006, 03:42 PM   #3
bigbiggirl
My Ride: 323Ci
But most people say after cleaning it, the light will go off.
Just $10, why not just give it a try?
Old 02-12-2006, 04:13 PM   #4
Ivegotissues666
My Ride: 88' BMW E30 SETA
Send a message via AIM to Ivegotissues666
Do you have rough idle upon startup sometimes stuttering and very poor acceleration? And once you get driving everything seems A-Ok?
Ivegotissues666 is offline   Reply With Quote
Old 02-12-2006, 04:17 PM   #5
leej323
leej323's Avatar
My Ride: '00 323i
Did/do you have an aftermarket intake?
leej323 is offline   Reply With Quote
Old 02-12-2006, 04:20 PM   #6
Ivegotissues666
I'm with you, either that or it's another fault code. From my experience with a bad MAF sensor it is really noticeale other than just a CEL.
Let me ask this what shop did you go to and are they reputable I would get the code reread possibly somewhere else.
Old 02-12-2006, 04:24 PM   #7
bigbiggirl
My Ride: 323Ci
When I am driving, everythings fine. When I start the car, I cannot tell big difference.
But if I stop at a traffic light for too long, the car is shaking.
OR if I go into a store to buy something but leave the car running for several minutes, when I get back, the car will be shaking and after I drive at a higher speed, it runs well again.
Old 02-12-2006, 04:25 PM   #8
bigbiggirl
My Ride: 323Ci
I guess no. but I am not sure because of an accident.
Old 02-12-2006, 04:28 PM   #9
bigbiggirl
My Ride: 323Ci
bmw dealership.
Do you think I should try to clean it first instead of replacing it? Really don't want to pay $3xx to get a new one. Thanks
Old 02-12-2006, 04:29 PM   #10
Ivegotissues666
Could possibly be a bad MAF sensor go to a local autozone and get the PXXXX code I think the MAF sensor code is P0101. You could try using alcohol 100%. I've been meaning to try to clean my old one to see if it would work but never have gotten around to it.
Old 02-12-2006, 04:36 PM   #11
bigbiggirl
My Ride: 323Ci
I am pretty sure there is something wrong with the MAF sensor. I paid $100 and had it checked at the dealership on my birthday. The damn thing died right on my birthday! They told me the sensor is not sensing correctly. And they gave me a $1000 bill to replace the sensor and idle control. I felt like screw it and went to Atlantic city. That's the whole story.
Now lets go back to the cleaner question. I read about the CRC cleaner. I really have no idea which kind of cleaner I should use. Is there big difference among those cleaner?
Old 02-12-2006, 04:43 PM   #12
Ivegotissues666
I really have never tried the cleaner before so I can't be positive, but I would assume to use the "CRC electronic one" . You said there was one labeled that? The sensor is a little flimsy peice of metal, so I wouldn't spray it on there directly for it might damage it more. I would try the alcohol method rubbing alcohol if you can't find any of the 100% stuff people say is floating around. I would soak the MAF sensor in it. This is so I've read from somewhere sorry I can't remember the source.
You may also check on ebay for a used MAF sensor I picked one up for $50 one time. Been running fine ever since.
Old 02-12-2006, 04:46 PM   #13
bigbiggirl
My Ride: 323Ci
Have you ever cleaned the sensor your way? did it help? or you just bought a used one and replaced it? thanks.
Old 02-12-2006, 04:51 PM   #14
Ivegotissues666
I Just bought a used one and replaced it. I have my old sensor lying around here somewhere. I've been meaning to clean and test to see it would work again but havent gotten around to it yet.
Old 02-22-2006, 05:28 PM   #15
geoffct
My Ride: 330CIc
I have never heard of mass airflow cleaning, I was under the impression that the hot wires were simply too damn sensitive, but I guess I was wrong. With this information I would use this,
http://www.midwayautosupply.com/deta...tion.asp?19596
if I were going to try. Personally I would put a dmm on it and check the output before cleaning though.
geoffct is offline   Reply With Quote
Old 03-14-2007, 10:25 PM   #16
XKxRome0ox
Black and Proud
My Ride: RIP e46/'16 328i
does anyone have any PICTURES of how to get to the MAF sensor? ...
i'm thinking about replacing my air filter... and if i'm going to be doing that... i might as well take a look at the MAF sensor
because i'm getting fault code P1100 MAF Intermittant
2016 BMW 328i 6MT/M Sport Package/Track Handling Package/M Performance Exhaust/Injen CAI/Dinan Shockware
XKxRome0ox is offline   Reply With Quote
Old 03-14-2007, 10:30 PM   #17
Jelly335
My Ride: 2001 bmw 330I
Send a message via AIM to Jelly335
yea if u went to pepboys the cleaner is called crc QD Electronic cleaner that happened to my car and that worked thanks to another member on here do that first if that doesnt work get the maf. but remember disconnect the battery first and let the thing dry good i let it dry for like 30 mins to be really good and it worked
E46 330i retired
E92 335 current
<3 my one wheel wonder
http://www.cardomain.com/ride/2269710/1
-Jeremy
Jelly335 is offline   Reply With Quote
Old 03-15-2007, 07:11 PM   #18
buddy325i
My Ride: 2002 325i
If it's dead, then cleaning it won't help. If it's dirty, then I would recommend using the CRC cleaner as other people have suggested.
buddy325i is offline   Reply With Quote
Old 04-05-2007, 04:10 PM   #19
blacked_out
My Ride: 323i
i will deff try and clean it instead of paying around $600CAD for a MAF.
blacked_out is offline   Reply With Quote
Old 04-06-2007, 11:19 AM   #20
Mikeee46coupe
My Ride: IS ON DPE's
$300 USD from Crevier BMW, even after the tax, duty, UPS "ass rape" brokerage I paid just over $450 CDN.
DPE Wheels, H&R, M3 Interior...way too many mods to list.
Mikeee46coupe is offline   Reply With Quote
