Help with control arm re-installing - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-14-2006, 12:43 AM   #1
Hung@Fiber-D
Past Site Sponsor
Hung@Fiber-D's Avatar
My Ride: Car with Silver CF
So I got myself the 66mm powerflex front control arm bushing.
I already got the oem rubber out, and popped the new powerflex poly in.
Now I'm having a hard time putting it back onto the control arm and bolting it back up.
It looks like I need to push about 1cm more into the arm to get it to line up right to the bolt section, but the material is too tought.
I tried using a hammer but that thing just slowly slide off the end.
Is there a tool I can use for this? If not.. how did you guys end up re installing yours.
Am im suppose to have gease between the black and puple poly only or poly and the metal control arm too?
Hung@Fiber-D is offline   Reply With Quote
Old 02-14-2006, 12:26 PM   #2
Hung@Fiber-D
Past Site Sponsor
Old 02-14-2006, 12:35 PM   #3
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
You should have some sort of lubricant (I used white lithium) between the black/purple part but NOT on the control arm itself. I just wiggled the entire thing (alum carrier, with the black/purple bushing installed) onto the control arm. You could try using a mallet but be careful you don't drive the inner purple part too far on the arm so that it sticks out beyond the black part facing forward (it is longer than the black part and should stick out on the back side).
Hope that helps,
Tim
tim330i is offline   Reply With Quote
Old 02-14-2006, 12:38 PM   #4
tim330i
E46Fanatics Owner
tim330i's Avatar
Here is my DIY link -
http://forum.e46fanatics.com/showthread.php?t=140066
Tim
